Hello everyone, my pc has been running flawlessly for around 6 years now, and today while playing cs:go, after maybe 10 minutes in game, my pc suddenly completely froze, the image was still there, sound was gone, and nothing was responding at all, so i manually rebooted the pc using the reset button, which turned it off but not on again, so i pressed the power button upon which the pc tried turning on, but failed and turned off again, 4 times this happened, then it started seemingly normally, but it gave no input to my monitor, so i restarted it again and this time it worked and booted me back into windows normally, so i launched steam, launched cs:go, but before i could even press reconnect the pc froze again just like before, and now it completely refuses to boot, the motherboard gives me the error code 00, which apparently doesn't mean anything specific, and the only other indicator is a red light called CPU_LED is turned on, and I'm not sure that's normal.
To be more precise, everything does technically turn on like it should, all the fans are working, gpu is working, all the hard drives are making the usual noises, even my keyboard lights up, but my monitor gives me "no input" and goes to sleep, i tried leaving the pc in that state to see if by miracle it would boot again, but after an hour when i came back the pc had just turned itself off.
Something else worth noting, the reset button doesn't work anymore, neither on my case nor on the motherboard itself, pressing it doesn't do anything.
Here are my specs:
MB: Asus Maximus Hero VII
Cpu: Intel i7 4790k
Gpu: GTX980ti
Psu: Corsair RM850
Ram: 4x8gb hyper x something
Things i tried but didn't work:
Clearing CMOS (using the button on the motherboard) it did restart the pc but nothing else
Removing/changing positions of ram sticks
Removing gpu
Removing hard drives
Unplugging the water cooling
Plugging out and back in most power connectors
Changing the cpu power connector
I can't try to boot the pc using another cpu or psu as i only have those already in the pc, and I'm pretty sure the problem comes from either the motherboard or the cpu, because everything else seems to be working properly, question is, which one is it and can i do something about it without having to replace any parts?
Is it possible that my cpu just randomly died without showing any signs of it even though it's been working fine for years?
Could that be why the pc completely froze up? (this never happened before)
Could the issue be related to a motherboard failure? With the reset button not working I'm thinking this could also be it?
Reading other forum posts about this issue i found that it could maybe have something to do with the bios, is there any way i could access it with my pc not booting?
Since my pc failed to boot a couple times maybe something went wrong on the software side of things?
Whatever the problem is, i really need this pc to work, i can't do without, so any help is very much appreciated !
Thanks already for taking the time to read this!
And double thanks to whoever can help me with this issue!
Here are my specs:
Cpu: Intel i7 4790k
Gpu: GTX980ti
Psu: Corsair RM850
Removing gpu
