asus p4p800 se boot up problems!!!
Weigy104
241 (0.03/day)
Glasgow
Processor AMD Athlon 4200+ X2 939
Motherboard MSI K8N NEO2 Platinum
Cooling Arctic Silencer 4 and Gigabyte G-Power Pro
Memory 1GB DDR400 value crap :(
Video Card(s) X800 Pro Modded to XT via bios flash
Storage Seagate Baracuda 160GB & Samsung Spinpoint T 500GB :)
Display(s) ACER AL1751
Case Thermaltake Tsunami Dream :D
Audio Device(s) Creative Audigy 4
Power Supply Enermax Liberty 400W
Software Windows XP Pro SP2, Ubuntu, Windows 2k3
i used to have my cpu overclocked using the jumper free config settings in my bios i had it set to 20% it was running fine untill one day i turned onmy comp and it came on for a few seconds then went off :( when i turned it on again it came up saying my overclock had failed so i went into the bios and reset all the default settings. then a couple of days later the same thing happened and absoloutely nothing is overclocked and is running all default settings. this is really starting to worry me so pls help :eek:
gerrynicol
758 (0.10/day)
Scotland, Falkirk
System Name Home built
Processor Core i7-920 4.0Ghz
Motherboard Asus P6t OC
Cooling Akasa Nero
Memory 6GB G.Skill DDR3 PC3-1348Mhz
Video Card(s) XFX GTX 285 SLi
Storage 160GB, 250GB, 320GB
Display(s) 24" dell(1920X1200)
Case Coolermaster HAF
Audio Device(s) Auzentech X-Fi Prelude, logitech Z5500
Power Supply Corsair HX 1K
Software 7 ultimate 64
I get that now and again with my asus board, even though it's for a athlon 64, I updated the bios to the latest version and it's only happened once in the 2 months I updated, before it happened like 3 or 4 times.
hope this helps,
Gerry.
Weigy104
241 (0.03/day)
Glasgow
yeh i was thinking about updating the bios but completely forgot about it :p but if anyone knows of anything i could do to get rid of this completely that would be nice :D
gerrynicol
758 (0.10/day)
Scotland, Falkirk
Cooling Akasa Nero
I second that, it is a pain in the arse, do you have to reset everything back to the way you had it or are some settings kept?.
364 (0.05/day)
USA
Processor X5470 @ 4.1
Motherboard Asus P5Q pro
Cooling Corsair H60
Memory 6GB corsair 1066
Video Card(s) HIS 6970
Display(s) 34" ultrawide
Case antec 700
Power Supply Corsiar 750 watt
Mouse Razer Taipan
Keyboard Razer Arctosa
Software Win 8.1 64 bit
Set bios to default and update to see what happens. I had a p4p800 deluxe and imo it's a piece of shit. Long story short the board eventually broke from the pressure of the heat sink. It will now only work if I use it without the heat sink.....HMMMM replace the cpu with a new one every few hours or get a new board it was an easy choice.
Weigy104
241 (0.03/day)
Glasgow
yeh i did restore all my bios settings to default and updated it successfully and the same thing still happened this morning :(
364 (0.05/day)
USA
Cooling Corsair H60
Case antec 700
Mouse Razer Taipan
Check your cpu temp and see whats your norm. May be a bad CPU, memory or mo bo. I suspect your mother board however trouble shoot cpu and memory first. memtest86 is a good tool to try. asus tech and rma suck. all they will tell you is is not their product.
Weigy104
241 (0.03/day)
Glasgow
well my cpu idles at like 40 and loads at 60 but not sure about the memory it's brand new and where can i get the memtest thing?
intel igent
4,640 (0.64/day)
Toronto, Canada
System Name old school / new school
Processor 3.0e C0 @ 3.6 / e5200
Motherboard p4p800e-dlx / p5q-DLX
Cooling custom water see sig / air
Memory 2x1g oczPC4000EbPl / 2x2g ocz2rpr1066
Video Card(s) 3850AGP / 4890vaporX
Storage 36g raptor+120g wd / wd 1001fals 1tb
Display(s) BenQ / sharpAQUOS LC-37D64U
Case modded antec plusview / generic
Audio Device(s) audigy 2zs / ASUS Xonar HDAV1.3
Power Supply fan/cable modded powerstream 520 / OCZ 700mxsp
Software Xp pro SP2 / VISTA ultimate OEM
ive owned two asus boards, a p4p800se and a p4p800e-deluxe and both of them were/are good boards, imo.
i would have to agree with the updating of the bios but also update all of you chipset/video/sound drivers as well. i would also reccomend oc'ing your comp manually as i found that i could not even get mine to run stable on a 5% oc using the automatic tools. ive had my chip (3.0e SL79L C0) up to 3.6 on stock hsf with manual ocing. will be pushing even farther when my order arrives ;) checkout www.extremeoverclocking.com they have intel/amd specific oc'ing forums, very informative and helpfull. with a bios update i think you might be able to unlock the cpu multi !!! not 100% though
364 (0.05/day)
USA
Cooling Corsair H60
Case antec 700
Mouse Razer Taipan
Not too bad on the temps just google for memtest86
457 (0.06/day)
System Name Mini ITX| uATX
Processor Intel Core i7 6700 | Intel Core i7 6700
Motherboard Asus B150-I Pro Gaming/Aura | Asus Maximus VIII Gene
Cooling Coolermaster i7C | DeepCool AG300
Memory Teamgroup Elite+ 3200 16GB (8x2) | Kingston HyperX 2400 16GB (8x2)
Video Card(s) XFX RX 550 ITX | Asus ROG Strix GTX 1050Ti
Storage Crucial P3 Plus 500GB + WD Scorpio Blue 1TB | ADATA XPG SX8200 Pro 512GB + Seagate Skyhawk 4TB
Display(s) Samsung 50" Smart TV| ASUS VZ239HR
Case Jonsbo U1 | Silverstone PS15
Audio Device(s) SupremeFX | ROG SupremeFX
Power Supply Seasonic SGX500 | FSP SFX Pro 450
i have an asus p4p800-e deluxe and so far i'm running stable @ 3.ghz (2.4A)...
the only thing i've noticed so far on this mobo is that, sometimes the mouse won't work and i have to restart the system once again... it happens randomly... this also happened to me on an intel mobo, but i think it was just once or twice... could it be my mobo or my mouse? :confused:
bcgone5150
38 (0.01/day)
Processor AMD Athlon XP 2700+
Motherboard Asus A7V8X
Cooling 2 80mm Intake, 3 80mm Out, Thermaltake on cpu
Memory 1 G
Video Card(s) ATI Raidon 9550
Storage 40G Maxtor 80 Western Digital
Display(s) Old 21 in Gateway
Audio Device(s) On board
Software XP 32-bit Pro
My guess is that it is not your mouse or your motherboard that it is the Windows OS if that is what your running. My computer locks up in the screen saver and power save modes. I am pretty sure it is the OS. I would suggest a format of your hard drive and a reinstallation of everything fresh. I can not varify that this will fix these problems, but it might be worth a try. Could try the latest mouse drivers as well. I have not gotten around to reformatting and reinstalling everything fresh on my computer.
Well good luck, maybe some one else here has a better suggestion for ya. :)
