- Oct 9, 2007
- 47,499 (7.49/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
The specs sheet of the upcoming ASUS ROG Ally X handheld game console was leaked to the web, confirming many of the rumors that have been doing rounds for the past month. The Ally X is a definite step up from the ROG Ally Extreme. It was originally rumored to be just a design revision that relocates the microSD card slot away from a thermal vent on the original design, which was causing memory cards to fail. The specs sheet confirms that the ROG Ally X features a larger M.2 drive bay with support for M.2-2280 drives. You'll be spoiled for choice picking a drive to go with this device. The drive included is 1 TB—double the 500 GB of the original ROG Ally.
Next up, there had been rumors of a significantly larger battery, but we didn't have an exact capacity figure, until now. It turns out, that the ROG Ally X packs a massive 80 Wh battery, which works toward a roughly 40% battery life improvement. While the CPU is the same Ryzen Z1 Extreme, ASUS improved the memory, which is now 24 GB LPDDR5X-7500, compared to 16 GB LPDDR5-6400 on the ROG Ally Extreme. This is a 50% increase in memory size, and 17% increase in memory bandwidth. Lastly, ASUS is introducing USB4 type-C, with integrated DisplayPort 1.4 and PD 3.0 output.
![](https://www.techpowerup.com/img/C5DegeyAcBTdnWen_thm.jpg)
