Hi, everyone I have a problem with my ASUS ROG STRIX RX 560. I am losing my screen randomly its turning full of grey and without no sign. No cursor or sound, all fans and lights working in the Case while this happens.
I tried almost all drivers none of them worked.
I tried HDMI, mDP and DP cable this didnt solved the problem either.
When this happens I pull out the cable from case and put it back display cant finding connection.
I even send it my RX 560 to ASUS Service for test they said there is no problem.
Test All RAMS one by one with memtest no error or fault.
Only solution is a Hard Reset from case.
This is my Spec;
Asus TUF Z390 (This is bought new)
Intel 9900K
ROG-STRIX-RX560-O4G-GAMING
A-DATA 1TB NVME
Cruial 64GB 2400Mhz Sports RAM
EVGA SuperNOVA 850 G2 Power Supply
Dell Ultrasharp U2718Q 4K IPS (Connection Type Original Dell mDP to DP Cable from the box)
Exact Link of my Graphic Cards
is there any solution for this issue or is it possible to flash my BIOS with different one?
This is my Spec;
Intel 9900K
A-DATA 1TB NVME
ASUS ROG STRIX RX 560 GAMING OC Specs
AMD Polaris 21, 1326 MHz, 1024 Cores, 64 TMUs, 16 ROPs, 4096 MB GDDR5, 1750 MHz, 128 bit
www.techpowerup.com
