ASUS ROG STRIX RX5700XT power problem / PC doesn´t start when one power cable is plugged in
mbarma
4 (0.00/day)
hi everyone,
theres a problem with my RX5700XT and I´m asking you guys for ideas/ help:
the PC doesn´t start with GPU mounted and all cables pluged in. If I´m unplugging the left cable or both power plugs, the PC starts.
Seems there is a short circuit in the card.
Did anyone had same problems? What can I do to repair it?
thanks a lot
michael
2,858 (2.10/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
doesn't asus have a 3 year warranty?
Deleted member 24505
there is a lot of screws missing out of it, it's not that shorting it is it.
mbarma
4 (0.00/day)
the pics are made with backplate dismounted - the problem accurs with backplate on and all screws fixed
Asus doesn´t mind the warranty due to a local polish warranty (don´t understand but ok)
4,499 (0.82/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
What kind of accident did you have with liquid on that PCB?
mbarma
4 (0.00/day)
no liquid. The PC was running well, I was playing iracing when the PC suddenly switched off. For me it sounded like a broken power unit of the PC. I wasn´t able to restart the computer, no reaction by pressing the on button. By installing another graphic card the PC started without problems.
I plugged my 5700XT in another PC and the same problem appears...PC doesn´t start
866 (0.23/day)
Processor ryzen 5 5600x
Motherboard AB350m Pro4
Cooling custom loop
Memory TEAMGROUP T-Force TXKD416G3600HC18ADC01 16gbs XMP
Video Card(s) HP GTX1650 super 4gb
Storage MZVLB256HBHQ-000H1 PM981a (256GB)/3TB HDD
Display(s) Nitro XF243Y Pbmiiprx
Case Rosewill CULLINAN
Power Supply Corsair 750w
Mouse Best Buy Insignia
Keyboard Best Buy Insignia
Software Win 10 pro
2,858 (2.10/day)
Germany
41,755 (6.60/day)
hi everyone,
thanks a lot
michael
Obviously there's a problem with the card send it in for repair if it is out of warranty pay for the repair
4,499 (0.82/day)
Denmark
that's silicone oil from the thermal pads.
Could be, never say that before but I never had the need to look at my GPUs once installed.
mbarma
4 (0.00/day)
thanks everyone for participating the discussion.
Asus doesn´t offer a repair and they don´t accept any warranty. Even I don´t understand because the card is about one year old:
however...is there a technical idea to solve the problem or start an analysis?
9,897 (1.86/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
i just feel like overheat, or something related to the electric
less oil is ok but in your case it's not normal, it's way too much
