ASUS RT-AX88U Pro cutting out for many different events
SuperHydro
1 (0.03/day)
Hello All,
I just bought a ASUS RT-AX88U Pro to replace my 8 year old Net Gear Nighthawk R7000 as the speeds were plummeting with my Version Fios. The speeds are great from the ASUS, but there are many circumstances to when the internet cuts out.
The first, is once a new device is added the 2.5G light (forth light from the left) turns red, so I have to restart the router.
The second is when I either download a game on my PS5 or use my PlayStation Portal, those two devices work, but the others are kicked off until I reset the router and the other devices will not work if either PS5 activity is going on. I read that this might be because the PS5 is an "access point" when using the PlayStation Portal, but I don't understand why downloading on the PS5 would make the rest of the devices go down.
Thirdly, sometimes the red light will come on randomly. Might work well for a couple hours or 30 minutes and then the internet cuts out.
I never had these problems with the R7000, so I was wondering if it was something with the setup or if its something with the modem. Any help would be great.
Thank you,
Alex
FreedomEclipse
~Technological Technocrat~
23,940 (3.75/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
A few suggestions...
1. Add some ventilation/cooling. - It looks like you have everything stowed inside a cabinet where there is little to no airflow and modems/routers do run hot and have ran hot since 54g days
2. FInd a better/stronger beefier power supply if you cant/dont want to improve airflow.
My personal experience is stock powers supplies start to fail the hotter the ambient temperature is. You can say they suffer from 'v-droop' and the power supply cant keep outputting the rated spec that keeps everything smoothly A beefier power supply will stand up to the heat a lot better than weaker stock power supplies.
Its not completely unheard of for manufacturers to cheap out on stock power supplies. Some fans pulling air through will help a lot.
12,935 (1.94/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Not sure what a bigger PSU will achieve. If the current one is faulty, then sure, it needs to be replaced with a good one. But name-brand makers don't generally provide underrated power supplies.
I agree totally, however, with ventilation. Do you normally close that cabinet door? If you do, don't - for now. If no problems with the door open, heat is probably your problem.
I will also note putting a wireless device inside a metal cabinet is a great way to block :( wireless signals. I would relocate and mount the wireless router outside the metal box.
FreedomEclipse
23,940 (3.75/day)
London,UK
less v-droop while pulling the same current/voltage etc. This worked for me with my own Netgear router at least.
4,461 (0.91/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
probably something up @TheLostSwede alley, I wonder if switching to merlin would help or is it a pure hardware failure?
12,935 (1.94/day)
Nebraska, USA
Mouse Logitech M190
If you were experiencing v-droop that affected performance with that last supply, that suggests a faulty/failing supply and not one that was under-rated in the first place. Or the device it was supplying was faulty and drawing too much current. Either way, I am glad your replacement worked.
17,327 (2.38/day)
Ok, that is not a good place for a router.
You want it out in the open, somewhere central in your home.
Putting a router in a utility cupboard like that is suffocating it and you're going to have awful signal strength as there's way too much metal and concrete in the way, which are things that shorten the WiFi range. If the door is also made of metal, I'm surprised you get a WiFi signal at all.
The antennas are also designed to point in a certain direction, which by mounting it like that, doesn't happen. This also reduces WiFi range, as the antennas have a "doughnut" type signal.
No idea what the "red light" is, that's not a helpful descriptor of anything.
I have a GT-AX6000 which is based on very similar hardware and it's been working flawlessly, but it's also not locked away in a utility cupboard.
I would do a full hardware reset of the router, as it sounds like something in the settings is wrong. Don't use the Ai Protection crap, it just puts a lot of strain on the router SoC and it doesn't really work.
Assuming your internet connection exceeds 100 Mbps, don't use QoS.
Disable smart connect, as it will force your devices to jump between the 2.4 and 5 GHz bands, it's not very smart.
Separate 2.4 and 5 GHz networks are better and it allows you to put bandwidth demanding devices on the 5 GHz network and everything else on the 2.4 GHz network, if you want to optimise for performance.
161 is an awful channel for the 5 GHz network, pick 36 or 149 unless you have a lot of neighbours who's 5 GHz networks you can see on your phone, then pick 100.
In the US, normally channels 1, 6 and 11 are the ones used for 2.4 GHz WiFi, to avoid interfering with your neighbours.
None of the other screenshots are providing any kind of useful information.
Can you check the logs and see if you get any errors when devices get kicked off?
13,959 (3.83/day)
Sunshine Coast
Processor AMD 5650GE
Motherboard Lenovo
Memory 32 GB DDR4
Mouse Lenovo
Keyboard Lenovo
Software W11 Pro 64 bit
Too much traffic on 2.4GHz during peak periods perhaps?
Try switching to 5GHz.
125 (2.16/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
+1 for mounting it not inside a metal box.
4th light from the left is WAN, if that is the one going red, I would hook something straight up to the Verizon box and see if the connection is stable. Make sure the cable is good too.
Other than that, LostSwede and Billbright have it covered.
