Recently I bought the ASUS RX 6700 XT Dual graphics card from AliExpress (used).
When I click on "Look Up", I am redirected to this page, showing the OC model.
As you can see, the memories are from Micron, that made it very difficult to find a Bios that worked. I tried a samsung BIOS, but it has not worked properly.
The only BIOS I found with Micron memory support that I'm using at the moment was this.
But I think this BIOS doesn't work 100% correctly, considering that the fan sensor doesn't leave 0%, and the fans don't spin when under stress (I've seen them spin a few times, but it was pretty random).
I also disabled the 0 RPM function in AMD Software.
MSI Afterburner also shows like this (can't change fan speed).
I tried reinstalling the drivers (using DDU), disabling the IGPU, and nothing worked.
Do you know if another BIOS could solve the problem? Is there a possibility to use the BIOS from another manufacturer that also uses Micron chips? Or could it be a physical problem?
Thank you very much for your time!
