ASUS Shows New NUC 14 Pro and NUC 14 Pro+ at CES 2024
GFreeman
1,483 (2.44/day)
While the ASUS ROG NUC was certainly the star of the show at CES 2024, ASUS is clearly serious about getting behind NUC design that it acquired from Intel since it had a few standard NUC designs, including NUC 14 Pro and NUC 14 Pro+. Both are equipped with Intel's 14th Gen CPUs and use a more familiar NUC chassis design in low-profile and taller option that has an internal expansion tray for storage options.
The NUC 14 Pro is based on a standard 4x4 NUC form-factor with low-profile or 14 mm taller option that has a storage expansion tray. It will be limited to Intel Core Ultra 7 CPUs, but still supports up to 96 GB of DDR5 RAM and has two M.2 2280 PCIe 4.0 x4 slots (one 2.5-inch SATA SSD support in taller chassis), Intel WiFi 6E, Bluetooth 5.3 and 2.5 Gb Ethernet. It comes with two Thunderbolt 4 ports, two HDMI 2.1 outputs, and a couple of USB ports, including 10 Gbps ones. The NUC 14 Pro+ is quite similar but can be equipped with up to Intel Core Ultra 9 CPU. ASUS actually went for a slightly different design with a whole new 5x4 NUC anodized aluminium chassis, mostly to give it a premium look but also give that Core Ultra 9 CPU a bit more room to breathe.
6,136 (1.52/day)
Over here, right where you least expect me to be !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
Bring on moar mini-me boxes with better & better specs & options, and..if they keep the prices reasonable, they'll sell a boatload of 'em :)
Unfortunately, this is NOT AsSus's normal MO, at least not for new stuff anyways :(
