ASUS TUF B450-PLUS GAMING vs GIGABYTE AORUS B450 PRO
190 (0.05/day)
System Name Budget Gaming PC
Processor Ryzen 5 3600
Motherboard Gigabyte B450 Aorus Elite
Cooling ARCTIC Freezer 34 eSports DUO
Memory Corsair Vengeance 16GB DDR4 3200MHz CL16 ( 2 x 8GB )
Video Card(s) Gigabyte GTX 1060 6GB
Storage ADATA SX8200 PRO 256GB
Display(s) Acer V246HL
Case Zalman Z3 Plus
Power Supply Sirtec High Power Plus 500W
Software Windows 10 X64-Bit
Which one of these motherboards are better for
CPU : Ryzen 5 3600
Ram : Corsair Vengeance LPX Black 16GB DDR4 3200MHz CL16 Dual Channel Kit
GPU : 5700 XT
1,470 (0.21/day)
Processor Ryzen 1600AF @4.2Ghz 1.35v
Motherboard MSI B450M PRO-A-MAX
Cooling Deepcool Gammaxx L120t
Memory 16GB Team Group Dark Pro Sammy-B-die 3400mhz 14.15.14.30-1.4v
Video Card(s) XFX RX 5600 XT THICC II PRO
Storage 240GB Brave eagle SSD/ 2TB Seagate Barracuda
Display(s) Dell SE2719HR
Case MSI Mag Vampiric 011C AMD Ryzen Edition
Power Supply EVGA 600W 80+
Asus is generally better in terms of quality and customer service, notwithstanding the 2 boards you mentioned.
190 (0.05/day)
Case Zalman Z3 Plus
I m still not sure which one to go with :D
19,371 (3.56/day)
6 of one, half dozen of the other. Choose your poison.
So long as they have the features you need, it comes down to look and price. Why not wait a week and see what amd 550 boards have in store...
190 (0.05/day)
Case Zalman Z3 Plus
6,895 (3.05/day)
California
System Name His & Hers
Storage lots of SSD.
Just get the Tomahawk Max.... It's vrm/heatsink combination can handle any ryzen 3000 chip, it's well made, and has good memory compatibility.
It's better than all 3 of the boards you have listed here.
6,895 (3.05/day)
California
This one has the same VRM as B450 Tomahawk. And it is better than both Asus and Gigabyte ones that you mentioned. And it`s usually cheaper than Tomahawk. It is a way to go in my opinion.
I think due to the heatsink used it runs about 15-20C warmer on the VRMs otherwise yeah its pretty decent.
1,470 (0.21/day)
I found this one aswell : MSI B450 GAMING PLUS MAX
this is a f. hard choice
I have that, its a decent board (see my specs) though I preferred my previous Asrock B350M though there are no discernable differences for the average user, still recommend Asus over Gigabyte, search the number of complainants on here relating to Gigabyte and you'll see why
177 (0.08/day)
System Name My PC
Processor AMD 2700 x @ 4.1Ghz
Motherboard Gigabyte X470 Aorus Gaming
Cooling Zalman CNPS20X
Memory Corsair Vengeance LPX Black 32GB DDR4
Video Card(s) Sapphire Radeon RX 570 PULSE
Storage Adata Ultimate SU800
Case Phanteks Eclipse P500A
Audio Device(s) Logitech G51
Power Supply Seasonic Focus GX, 80+ Gold, 550W
Keyboard Roccat Vulcan 121
I got a X470 Gaming Plus (very sililar), if u go with GB don't overclock the VRM will heat up (maybe not that much for a 6 core -stock should be ok though) - also GB Bios is very limited for O/C.
The on-board audio AC1220 is pretty solid.
6,895 (3.05/day)
California
I'd go for GigaByte as it's offering the biggest bang for the buck.
Quick compare between them: https://www.newegg.com/Product/Productcompare?CompareItemList=13-119-142,9SIAGY9ABH1696,13-145-082
Considering it has the largest number of reviews on NewEgg, people seem to share my PoV.
its an ok board but the Tomahawk destroys it as far as VRM performance goes.
Maybe a 3950X isn't the most realistic comparison but better is better...
2,963 (0.84/day)
Long Island
Personally, I don't find most of the B series worth it because by the time you find one without a substandard audio abd LAn system, you could get a Z series
The MSI is very popular often sold out...some comparisions
MSI supported RAm speed goes to 4133, other 2 top out at 3200.
The Gigabyte has ALC 1220, MSI goes middle of the road w/ ALC992 and the SUS goes to th enottom of th ebarrerl w/ ALC 887
MSI supports more USB ports
The MSI Gaming Pro Carbon is $159 on newwgg but again that one is also often sold out. And the MSI X570 A-pro is also $159 and it has ALC 1220, goes to 4400 RAM speed
1,260 (0.30/day)
Artem S. Tashkinov
The person who asked for advice didn't intend to run the power hungry 3950X or OC his CPU. This comparison is void and nil. 3600 draws less than 90W, while 3950X can draw up to 150W. No point for overpaying for features and capabilities you're unlikely to ever use 'cause otherwise you'd be better off with a $1000 motherboard with all the bells and whistles and water cooling.
19,371 (3.56/day)
actually, the asus is 3400 mhz and giga 3600. Dont trust newegg specs. ;)
There's a difference between paying $70 more and $870 more, lol...
6,895 (3.05/day)
California
The tomahawk is typically around the same price and still vastly superior when it comes to vrm performance. Only the OP can decide if he wants a board that can easily handle every chip the socket supports or a board that approaches 100c depending on what chip you stick in it.
853 (0.33/day)
Asia
Processor Intel Core i5 4590
Cooling Intel Stock Cooler
Power Supply Corsair VS450
Mouse A4Tech N-70FX
AsRock B450-Pro is also a good choice. Avoid the Gigabyte board.
853 (0.33/day)
Asia
Mouse A4Tech N-70FX
Why should that Gigabyte be avoided?
AFAIK that board has 2 inductor for 1 phase and each phase has 1 Low side and 1 high side.
And this : (it is around 9:45 mark)
7,254 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
I personally choose the MSI B450 Gaming Pro Carbon-AC after watching Buildzoid video about VRM on the B450 line up and he has done others too.
His videos are really good to watch when he analyzes VRM he personally uses the MSI B450M Mortar Titantium which is equal to the Gaming Pro Carbon in VRM if I remember correctly.
19,371 (3.56/day)
Ty for the information. You should do this on every post... support your reasoning.
So with airflow, it's fine.............I don't understand why not to buy it unless it is in a passive chassis or zero airflow.
853 (0.33/day)
Asia
Mouse A4Tech N-70FX
The OP has option between motherboards and it is the least good one, thats is why I told to avoid it.
151 (0.04/day)
Get Strix B450-F Gaming if you can find it.
Good featureset. Paired it with a 3700x
silentbogo
5,540 (1.38/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 5700X3D
Memory 4x8GB Samsung DDR4 ECC UDIMM
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
B450 Aorus Pro is very similar to my x470 aorus ultra (same board, just swapped chipset). Solid board, but definitely needs some airlfow over VRM. My case had no exhaust fan, so I had to dig through my parts bin for a spare 120mm fan. Afterwards everything was perfect. The issue is not VRM itself, but a radiator design, which traps lots of air nearby. Without exhaust it would easily hit over 80C at full load, while after it never gets near 60C. Usually at full load with 20C ambient it's chilling at comfortable 55-58C.
BTW, I'm running R5-1600X, so a puny 65W from R5 3600 is nothing for that VRM.
1,192 (0.28/day)
Processor 11700
Motherboard TUF z590
Memory G.Skill 32gb 3600mhz
Video Card(s) ROG Vega 56
Case Deepcool
Power Supply RM 850
That Gigabyte board is very decent, ASUS has tendency do realease bios updatades once a full moon, and the price on that strix is shait. I wolud take the Gigabyte or MSI B450 Tomahawk max.
PS: If you take the Gigabyte it needs bios update to support Matisse you can let the local shop do it for you or do it your self if you know how to just make sure you follow the steps when you update.
