ASUS Upcoming ROG Swift OLED PG27UCDM is a 27-inch 4K 240 Hz Gaming Monitor
17,854 (2.43/day)
ASUS has published the product page for its upcoming ROG Swift OLED PG27UCDM gaming monitor, which will go head to head with the MSI MPG272URX on which will hit retail as the first 27-inch 4K 240 Hz display. The PG27UCDM sports a 26.5-inch panel using what ASUS refers to as 4th gen QD-OLED technology, which the company claims offer longer lifespan compared to previous generations of OLED panels. The panel sports typical OLED features such as a 0.03 ms response time, a peak brightness of 1,000 cd/m², 99 percent DCI-P3 colour space coverage and VESA DisplayHDR 400 True Black. The display also supports AMD FreeSync Premium Pro and NVIDIA G-Sync compatible, as well as a host of ASUS specific gaming features such as ELMB, GameFast Input Technology, Shadow Bost and a DisplayWidget.
Inputs consist of a DisplayPort 2.1 port with UHBR20 (80 Gbps) support, a USB Type-C with DP-Alt mode and USB PD up to 90 W and a pair of HDMI 2.1 ports. There's also a three port USB 3.2 Gen 1 (5 Gbps) USB hub with what we presume is a USB Type-B input and a headphone jack. The reason for the presumed USB Type-B input, is that the specs claim KVM support and this would only be possible if there was a USB input of some kind, but this isn't mentioned in the tech specs. The stand is your typical higher-end model with tilt, swivel, pivot and height adjustment, as well as ASUS' Aura Sync lighting and a tripod mount at the top. ASUS claims a power consumption of around 80 Watts, although this doesn't include USB PD. A big plus is that ASUS will bundle a DisplayPort 2.1 DP80 cable in the box, something for example Sony decided not to include with their INZONE M9 II which launched in September last year. There's no word on pricing for the ROG Swift OLED PG27UCDM, but expect it to be on the expensive side of US$1,000.
384 (0.24/day)
Texass
System Name EXTREME-FLIGHT SIM
Processor AMD RYZEN 7 9800X3D 4.7GHZ 8-core 120W
Motherboard ASUS ROG X670E Crosshair EXTREME BIOS V.2506
Cooling be quiet! Silent Loop 2 360MM, Light Wings 120 & 140MM
Memory G. SKILL Trident Z5 RGB 32MBx2 DDR5-6000 CL32/EXPOⅡ
Video Card(s) ASUS ROG Strix RTX4090 O24
Storage 2TB CRUCIAL T705 M.2, 4TB Seagate FireCuda 3.5"x7200rpm
Display(s) Samsung Odyssey Neo G9 57" 5120x1440 120Hz DP2.1 #2.Ulrhzar 8" Touchscreen(HUD)
Case be quiet! Dark Base Pro 900 Rev.2 Silver
Audio Device(s) ROG SupremeFX ALC4082, Creative SoundBlaster Katana V2
Power Supply be quiet! Dark Power Pro 12 1500W via APC Back-UPS 1500
Mouse LOGITECH Pro Superlight2 and POWERPLAY Mouse Pad
Keyboard CORSAIR K100 AIR
Software WINDOWS 11 x64 PRO 23H2, MSFS2020-2024 Aviator Edition, DCS
Benchmark Scores fast and stable AIDA64
All the wailing, crying and gnashing of teeth about the new video cards and their prices, the Display Port 2.1 seems to get lost in the tears and bowed heads.
My monitor supports DP2.1 therefore my new video card should support DP 2.1. Henceforth the RTX5090 is justified.
Please, wail away and carry on Team Sad.
5,488 (1.04/day)
I own an FO32U2P and honestly? not needing to use DSC is far from the top of my priority list for next generation. I wouldn't mind not needing to use it by the time this screen never turns on again
110 (0.02/day)
Germany
Since I'm about to buy the PG32UCDM, but it ‘only’ has DP1.4 so far (presumably an updated model coming soon?), I'm wondering what advantages DP2.1 should have with an RTX5090. Isn't HDMI2.1 completely sufficient?
573 (0.42/day)
System Name Jedi Survivor Gaming PC
Processor AMD Ryzen 7800X3D
Motherboard Asus TUF B650M Plus Wifi
Cooling ThermalRight CPU Cooler
Memory G.Skill 32GB DDR5-5600 CL28
Video Card(s) MSI RTX 3080 10GB
Storage 2TB Samsung 990 Pro SSD
Display(s) MSI 32" 4K OLED 240hz Monitor
Case Asus Prime AP201
Power Supply FSP 1000W Platinum PSU
Mouse Logitech G403
Keyboard Asus Mechanical Keyboard
costs more than the 32" MSI one we have but now it is inferior at 27" though
really needs to drop in price to $700 or less or 4k at 27" is not that interesting
384 (0.24/day)
Texass
This ROG SWIFT 360Hz is a few years old now but has been rock solid. It never saw any gaming but when I saw how the stand could be used as a clamp for my mobile computer desk sealed the deal for me.
I'm sure that made sense to you. me? not so much...
5,488 (1.04/day)
ill try to break it down for you.
DSC or display stream compression technically (what we use with older DP) does compress the signal data for us to be able to enjoy high data-rate video, but in reality its impact is so invisibly low, that nobody is in a real rush to provide DP2.1 capabilities to consumer grade graphics cards even in the 4K240 era. There's no rush and no push to get consumer GPUs out the door with DP 2.1 arrays because of it.
174 (0.11/day)
System Name The New, Improved, Vicious, Stable, Silent Gaming Space Heater
Motherboard MSI B450 Tomahawk Max
Cooling be quiet! DRP4 (w/ added SilentWings3 120mm), 4x Noctua A14x25G2 (3 @ front, 1 @ back)
Memory Teamgroup DDR4 3600 16GBx2 @18-22-22-22-42 -> 18-20-20-20-40
Video Card(s) PowerColor RX7900XTX HellHound
Storage ADATA SX8200Pro 1TB, Crucial P3+ 4TB (w/riser, @Gen2x4), Seagate 3+1TB HDD, Micron 5300 7.68TB SATA
Display(s) Gigabyte M27U @4K150Hz, AOC 24G2 @1080p144Hz vertical, ASUS VP228H@1080p60Hz vertical/ double4Kwhen?
Case Phanteks P600S
Audio Device(s) Creative Katana V2X gaming soundbar
Power Supply Seasonic Vertex GX-1200 (ATX3.0 compliant)
Mouse Razer Deathadder V3 wired
Keyboard Keychron Q6Max w/ Gateron G Pro 3.0 Black linear switches
Finally an actual announcement in the 27" 4K HRR OLED category but with no expected launch date. Stop messing with my upgrade itch damnit.
Proximity sensor for burn-in prevention is something I...think I have heard of but can't recall which 27" 1440p or 32" 4K models have it.
Not that it matters this time. I will just lump all desktop shortcuts at my other monitor so that there will be no desktop layout got messed up when I physically turn off whatever new monitor I get.
I guess this exact model will be a "well, I'm the best in this category" model to justify a USD900~1000 launch price. That MSI 32" model (I'm assuming MSI MAG 321UP at USD800 launch price) is very potato in terms of functions, and can do only 165Hz, so it should not be compared to this one too closely.
Oh crap there's already a review here. Haven't watched it completely, just to lump it here.
1,958 (0.47/day)
You do realize that every new card released in 2025 will likely support 2.1 UHBR20 right?
It is not some magical thing Nvidia came up with for their 5090...
How about running without DSC and it's related issues?
HDMI 2.1 is 48Gbps and while it's higher bandwidth than DP 1.4a it's less than DP 2.1 UHBR 13.5, much less UHBR20.
HDMI 2.2 is in the works but dont expect this until 2028 maybe.
384 (0.24/day)
Texass
I'll let you know when it gets setup and you can come fly the sim.
2,031 (0.45/day)
Netherlands
System Name TheDeeGee's PC
Processor Intel Core i7-11700
Cooling Noctua NH-D15S
Display(s) EIZO CX240
Mouse Logitech G500S
I'd rather get the Sony M10S, much sleeker design.
This kiddo toy look ASUS goes with totally doesn't do it for me.
155 (0.09/day)
HDMI 2.1 48Gbps and DP 2.1 40Gbps are basically on par since they use 2 different encoding schemes.
16b/18b on the HDMI 2.1, leads to 41.89Gbps of effective bandwidth.
128b/132b on the DP 2.1 (all three standards), leads to 38.69Gbps for the UHBR10 version.
4k240hz 10bit RGB requires 68.56Gbps. If you apply the minimal DSC compression (16bit/pixel), bandwidth decreases to 36.56Gbps.
So, DP 2.1 UHBR10 (+UHBR13.5) and HDMI 2.1 48Gbps give you the same visual result.
Botan626
6 (0.02/day)
How can it be Dolby Vision (see 3d pic) and only VESA DisplayHDR TB 400 at the same time?
No VESA DisplayHDR 600.
What about HDR10+?
155 (0.09/day)
There isn't any relationship between Vesa certifications and DV. Being an oled, Vesa only refers the minimum luminance level on a 10% windows.
It's 1000nits peak brightness.
That's an LCD standard. It doesn't meet the DisplayHDR True Black 600 requirements i guess for the full screen sustained brightness (350nits on the True Black 600 certification).
What about HDR10+?
Well.. Do you really want an answer?
MxPhenom 216
ASIC Engineer
13,020 (2.48/day)
Loveland, CO
System Name Ryzen Reflection
Processor AMD Ryzen 9 5900x
Display(s) Asus XG27AQM 240Hz G-Sync Fast-IPS | Gigabyte M27Q-P 165Hz 1440P IPS | LG 24" IPS 1440p
Mouse Razer Viper v2 Pro
Is anyone really buying these 27" 4k screens?
17,854 (2.43/day)
MxPhenom 216
ASIC Engineer
13,020 (2.48/day)
Loveland, CO
17,854 (2.43/day)
Are you running windows with any scaling? Seems like shit would be tiny
Sure, 125%, but that's perfect.
No scaling when gaming obviously.
My laptop with 2880x1800 resolution on a 14-inch display is much harder to work with, even with scaling.
MxPhenom 216
ASIC Engineer
13,020 (2.48/day)
Loveland, CO
Good to know
17,854 (2.43/day)
