ASUSTOR Launches AS-T10G2 10 Gigabit Ethernet Card
AleksandarK
2,870 (1.04/day)
The all-new AS-T10G2 is here, bringing increased efficiency and speeds to the much beloved AS-T10G. The AS-T10G2 uses the AQC-107 controller, which offers increased performance, and lower power requirements. Using the Lockerstor 16R Pro, transfer rates were found to be up to 1127 MB/s when reading and 1124 MB/s when writing. The AS-T10G2 also supports IP, TCP, UDP checksum offload to reduce CPU usage for a more efficient experience.
The AS-T10G2 is equipped with a 10 Gbps 8p8c RJ-45 Ethernet port. The AS-T10G2 supports automatic switching between all major Ethernet speeds and is compatible with four lanes of PCI Express 3.0. Pop it into an ASUSTOR NAS running ADM 4.0 or a PC to upgrade network speeds to 10-Gigabit Ethernet. The AS-T10G2 is compatible with both full-height and half-height computers, making it compatible with almost any device featuring a PCI Express slot, ensuring affordable, yet high speed networking for both homes and businesses.
AS-T10G2 specifications
Supports:
  • Jumbo Frame 16K Bytes
  • IEEE 802.3x flow control
  • IP, TCP, UDP checksum calculations
  • 100/1000/2500/5000/10000
  • Provides 802.1Q Virtual LAN (VLAN) tagging
Supported standards:
  • IEEE 802.3an 10GBase-T
  • IEEE 802.3ab 1000Base-T
  • IEEE 802.3u 100Base-TX
  • IEEE 802.3bz NBASE-T
  • IEEE 802.3az
  • IEEE 802.1p
  • IEEE 802.3x Flow control
  • IEEE 802.1Q Tagged VLAN
  • IEEE 802.1Qav Audio Video Bridging
  • IEEE 1588 v2 Precision Time Protocol
Maximum data rate: 10 Gbps
Operation mode: Full duplex
Supports PCIe 3.0 x4
System requirements:
  • ADM 3.5.6 and up
  • Windows 7/8/8.1/10 32/64-bit
  • Linux Kernel 4.4, 4.8, 4.9
Dimensions: 86.95 (W) x 67.9 (D) mm
18,273 (2.46/day)
$119, which is about $30-40 too much.
6,500 (1.56/day)
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
VR HMD Whahdatiz ???
Benchmark Scores PDQ
Yee haw, an overpriced 10Gb card for all our slow-as-frozen molasses 1Gb connections.... yessirreeee, now that's something to get excited about :eek::p:D
yes this was meant as s.A.r.C.a.S.m....in case you haven't figured that out already !
21,962 (3.42/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
Software Gentoo Linux x64
30 (0.01/day)
Budapest, Hungary
System Name ASUS G15 Advantage
Processor Ryzen 9 5900HX
Memory ADATA 2x16GB 3200MHz CL22
Video Card(s) Radeon RX 6800M
Storage WDC SN850 512GB, ADATA SX8200 Pro 2TB
Display(s) BOE 15.6" QHD 165Hz, Philips Momentum 278M1R
Audio Device(s) Edifier R980T, HyperX Cloud II
Power Supply Delta ADP-280BB B
Mouse Logitech G305
Keyboard Hama Exodus 900 Red
Considering how the Intel X550-T1 is usually 125$ used and has a way too long PCB to not completely obstruct a graphics card above it, this card might actually be a very much worthy replacement to that lineup! Not to mention the way bigger heatsink...I think I'm OK with this product.
4,302 (0.96/day)
System Name Skunkworks 3.0
Processor 5800x3d
Motherboard x570 unify
Cooling Noctua NH-U12A
Memory 32GB 3600 mhz
Display(s) Asus 1440p144 27"
Mouse *squeak*
Software Manjaro
Hopefully that means we'll get their 10Gbps NICs in their cheaper NAS's. They either offer you an intel one with 2.5 gbps or a marvell one with 10 gbps. Ideally having 10gbps in the intel one without raising prices would be great. Shame we still dont see a 4.0x1 interface, which is sufficient for 10Gbps.
Compared to what? Serious question. I haven't seen many cheap 10gbps cards...
Currently available for $80 from syba
asus has this for $92:
Rosewill card for $75:
TPlink for $99
4,021 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
Indeed. I remember buying my intel 1000CT a few years ago for about $30, now they are closer to $50
18,273 (2.46/day)
In addition to the links above.
Trendnet $90.
TP-Link goes for the equivalent of $86 here.
As all these cards are based on Aquantia, there shouldn't really be such a huge spread in cost difference.
Unfortunately you can't get the Aquantia cards any more, but they were normally retailing for around $80-90 as well. I got two of them for about $70 each during their black Friday special some years ago and they've been rock solid once they released a firmware that worked with AMD Ryzen...
1,778 (0.30/day)
Little Rock, AR
System Name Gamer
Processor AMD Ryzen 3700x
Motherboard AsRock B550 Phantom Gaming ITX/AX
Memory 32GB
Video Card(s) ASRock Radeon RX 6800 XT Phantom Gaming D
Case Phanteks Eclipse P200A D-RGB
Power Supply 800w CM
Mouse Corsair M65 Pro
That's a gigabit nic. The OP is a 10 gigabit nic.
4,021 (0.60/day)
I know, exactly my point. If a 1 gig card is $50 then a 10gig card should be $500. So at that price it's a fair deal.
2,881 (1.15/day)
Where are the affordable NAS's with even 2.5GbE, let alone 10GbE? My new Asus X570 MB has the Intel 2.5GbE port, but I have no devices to take advantage and I upload a lot of photos and 2.5Gb/s would be a nice boost. Even my brand new Synology is still 1GbE.
newtekie1
Semi-Retired Folder
28,473 (4.04/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I have to agree, for a rebranded Aquantia, $120 is a bit on the high side.
Holy shit, please tell me they aren't serious with the heatsink on that thing! There is no way that card doesn't overheat.
Ironically my X470 motherboard comes with the Aquantia ACQ-107 built in. They really were great budget 10G cards, it is sad Marvell bought them up and killed off the cheap cards.
What do you consider "affordable"?
