ATI to use NanoFoil on R600
D_o_S
954 (0.13/day)
Processor AMD Opteron 144
Motherboard DFI Lanparty nF4 SLI-DR Expert
Cooling Watercooled - Alphacool Nexxxos XP, BIX2, Eheim HPPS
Memory 2x 512MB OCZ PC 3200EL Platinum Rev.2 (TCCD)
Video Card(s) 2x Gainward GeForce 6800 Ultra (430/1200)
Storage 4x WD Raptor 740GD in RAID 0
Display(s) Eizo FlexScan L768
Case CM Stacker
Audio Device(s) Audigy 2
Power Supply Silverstone Zeus ST65ZF
Probably all of us are eagerly awaiting the R600 from ATI. The news floating on the internet is mixed - some report that the chip runs cool and doesn't draw a lot of power, while others tell us the contrary.
Hexus.net managed to find out some information about how ATI plans to cool the chip. Apparently, NanoFoil technology will be used. The technology works by having ultra-thin nanolayers of aluminium and nickel that can be controlled by heat, electricity or mechanical or optical stimulation, causing a reaction that gives off heat in a controlled fashion. The technology has been around since 2003, but hasn't yet been used to cool computer components.
overcast
733 (0.11/day)
Processor AMD Opteron 165 @ 2.7ghz Stock Voltage
Motherboard ASUS A8N-SLI Premium
Cooling Stock Opteron
Memory OCZ PC4000 EB Platinum 2GB
Video Card(s) ATI X1900XTX
Storage 2 x Western Digital 74gb Raptors
Display(s) NEC 990B 19"
Case Antec P150
Power Supply Seasonic S12-500
Software XP 32bit
Track
312 (0.05/day)
Israel
Processor Intel Pentium 4 (prescott) 3.0Ghz 1M L2 cache 800Mhz FSB w/HT
Motherboard Asus P4GD1
Cooling Zalman VF900, Zalman 7700, 1x AC 80nm
Memory 1024 MB DDR400 PC3200
Video Card(s) X1900XT (512Mb) @ 745/1660
Storage 1x WD 80GB 8M cache 7200 RPM, 1x WD 250GB 8M cache 7200RPM
Display(s) Viewsonic VA712 LCD 17"
Power Supply 500W
Software Windows XP SP2 Gold Edition
No matter what new technology they come up with, a stock cooler will always remain a stock cooler because ATI/nVidia arent going to bundle a 30$+ cooler with their cards..
I hope Zalman gets news of this and starts to manufactur some DX10 card coolers..
517 (0.08/day)
Stamford, UK
System Name The Money Sink
Processor Intel i7-5960X at 4.60Ghz
Motherboard MSI X99A Godlike
Cooling Custom watercooling loop, single D5 -> CPU, dual D5 -> GPU's
Memory 64GB DDR4-3000
Video Card(s) 2 x 1080Ti @ Stock for the moment (40oC LOAD)
Storage 960GB Mushkin Scorpion Deluxe and 2 x 512GB M.2 SSD RAID0
Display(s) Dual Curved LG 34" Display
Power Supply EVGA 1600W G2
Benchmark Scores ALOT
I can't honestly see this happening :S
498 (0.07/day)
Nanofoil is a bonding/soldering material. http://www.llnl.gov/str/October05/Barbee.html
The only way it will help with cooling is to form a better bond with the heat sink. Most likely they will use it on the heatspreader or this article is a little of and there using it to solder. I really hope ATI isn't dumb enough to fuse there stock heatsink to the chip:eek:
D_o_S
954 (0.13/day)
Case CM Stacker
Yep, NanoFoil is used instead of the TIM.
WarEagleAU
Bird of Prey
10,812 (1.59/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Agreed, though it does move and accomodate the different heat temps we are used to seeing with Video Cards.
-The Eagle
2,318 (0.33/day)
System Name MONEY PIT
Processor i7-3770K @ 4800 1.20v batch #3231B415 Delided
Motherboard ASrock Z77 OC Formula w onboard waterblocks
Cooling Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res
Memory G,skill Trident X F3-2400C10D-16GTX
Video Card(s) EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed
Storage 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0
Display(s) 3/ Samsung2343bwx + 65in LG 4K
Case NZXT Phantom White w/red
Audio Device(s) ReCon3d fatal1ty pro, Logitech z906 THX
Power Supply corsair AX860i
Mouse Rat7
Software 64bit ++++ win 10
reading the white papers on this stuff ..it would appear that IF they use it.. it will fuse the the sink to the chip... we have seen this before but can usually remove it .... this stuff might just be a littli bit more of a challange... :ohwell:
ATIonion
1,015 (0.15/day)
why would they do this?? ...unless they plan on releasing lines of product without heatsinks as well....
would make it tough for aftermarket cooling.......especially for us H2O guys...that would suck...unless of course they release cards without cooling on them for cheaper prices...that could be nice...
looking forward to the first reviews and "REAL" specs on that...:rockout:
overcast
733 (0.11/day)
Case Antec P150
Software XP 32bit
Oh c'mon guys, don't be so negative. That's my job.
498 (0.07/day)
I can't see them fusing the heatsink, it was more of a joke. There would be some real pissed folks if they did. I think the core2 is fused I'm not sure if they use nanofoil or not.
How great is this stuff? Even the best TIM would give like a few deg drop and if it's that great I want some. Nano stuffs f#$# cool:rockout:
2,318 (0.33/day)
Mouse Rat7
498 (0.07/day)
WoW, 8c diff! I hope that proves true in real world products.
It would be great if someone released waterblocks or TECs perfused to chips as it appears not to be DIY yet.
WarEagleAU
Bird of Prey
10,812 (1.59/day)
Gurley, AL
I dont think it will fuse onto the card. ATI has nothing to lose by allowing other companies to make aftermarket coolers. Just doesnt seem logical.
-The Eagle
ktr
7,404 (1.08/day)
so basicly they gonna melt and sandwich some aluminum foil (renolds perharps) between the gpu and the heatsink...
me-->:slap:<--ati cooling dev dept...
S
Slater
Well it may be another P4 prescott-type deal (remember there was "epoxy" holding the IHS to the chip? Well it's probably the same thing.)
