Atiflash gives Division by Zero and SIGFPE
Sandell
9 (0.00/day)
I got my hands on a faulty flashed XFX 5770 that gave no picture. So I tried to reflash it with the original firmware, but I got this strange error message that I can't find any info about. Has anyone seen this before? (see screenshot)
Now when I run atiflash -i there is no firmware displayed on the card, and any new retries to flash gives me the same error.
I have tried to change PCIe ports and different secondary graphics card also, but the 5770 wont get flashed.
Any suggestions what to try next?
43,627 (6.39/day)
Memory 64GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Case Fractal Design North
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
Have you tried the "force" command?
atiflash -f -p 0 biosname.rom
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Processor Intel(R) Xeon e5-2690 v2 Stock 3.300 GHz stock
Motherboard MSI X79A-G43 Plus (MS-7760) v3
Cooling CPU EK & Phobya G-Changer 360 V2.0 RAD H2o VGA "AlphaCool M18" Hybrid [pump replaced 18/8/21]
Memory G.Skill TridentX 16Gb 11-12-12-32 2T @ 1866Mhz [locked]
Video Card(s) Zotac GTX 1080ti AMP EXTREME
Storage HyperX Fury 120GB & Savage 480GB SSD, Seagate 250GB,250GB 7200rpm Kingston 64GB SSD
Display(s) Asus TUF Gaming VG32VQR 2560*1440 165Hz VA Panel
Case Corsair O-800D
Power Supply Be Quiet! [Dark Power Pro 11] 1200W CM replaced [7-4-2017]
Mouse Zelotes T-90
Keyboard K66 Mechanical US Layout
Software Win 10 Pro 64Bit v 20H2 / OS [build 19043.1237] WFEP 120.2212.3530.0
Hi
Looks as if atifash is at a C: prompt; are able to confirm
Try using a bootable USB Flash Drive
-download atiflash; use this version: here
-go here
-download - HP USB Disk Storage Format Tool - v2.1.8 & Windows 98 System Files
click Primary Download unzip the files to a folder on your HDD; make sure your USB Flash Drive is attached to your PC; open HP USB Disk
Storage Format Tool v2.1.8 ; select create a DOS start-up disk/ select: using DOS system files located at: (these are the files you have just downloaded): browse to the files in win98boot; then start the process.
copy atiflash and #BiosName#.rom to the bootable USB flash drive
Set the motherboard bios to boot from USB *press F8 during boot; select from boot menu *if option is available; this should boot to a win98 dos prompt
Unplug any USB and other devices [*other than the USB Flash Drive] that may be attached to the PC, disable anything that may disturb the flash process
Type the following command at DOS prompt:
Look for Adapter info
atiflash -ai 0
To force flash the card
atiflash -p -f 0 #BiosName#.rom
0=Zero if card is in top PCIe slot
Note: Model Number and link for the exact vga card / hashes from back of the card would help
Edit: If the above dose not work follow this link
atb (all the best)
Law-II
Sandell
9 (0.00/day)
Thank you for your input.
I am using a bootable USB-stick, but I created it with some freeware tool. Tried another tool to create it as well, but no difference. I'm also using ATIFlash 4.07. I will try to create a boot-stick with the HP tool, but I don't think it will help. Anyhow, it's worth a try.
When flashing I tried with another card connected to a PCIex1 port via a 1x-16x riser, and also vice versa with the 5770 connected to that x1 port. Same problem both ways tried. Today I will try to use a standard PCI card as a secondary display, as well as the internal graphics card on my motherboard.
Another interesting thing is this; another computer I have doesn't detect the card at all, it's an older computer with a motherboard based on nVidia nForce4. My current computer runs a motherboard based on Intel G41.
Does this matter?
Finally, the card is found when I run atiflash -ai, I will post the results of that later today.
Even though it is found, is it possible that shorting the vBIOS chip will help me?
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
In my hurry to assist I forgot; Welcome to TPU
Does this matter?
As long as both motherboards have PCIe x16 2.0 or compatible it should not make any difference.
Should be good to flash the adapter; let us know
No need for this if the adapter has been found: [the procedure is for adapter not found]
atb
Law-II
Sandell
9 (0.00/day)
Thank you!
I have now tried with the onboard graphics card as secondary display as well as disabling and disconnecting everything unnecessary. Still the same problem.
When I run atiflash -ai 0 I get this:
Code:
Adapter 0       (BN=01, DN=00, PCIID=68B01002, SSID=00000000)
   Asic Family     :  Juniper
   Flash Type      :  SST25VF010  (128 KB)
   No VBIOS
Markings on the card says:
HD-577A-ZN HD-577A-ZNDA VC.1
HD 5770 875M 1GB DDR5 DP HDMI DUAL DVI
PCI-E XXX
I will update this thread with a picture of the output from atiflash -ai that I ran before the card was flashed the first time.
Sandell
9 (0.00/day)
This is what was shown before any flashing took part, adapter 1 is the one that wasn't working:
And with atiflash -ai:
What's up with that "Hybrid Images"? The previous owner had modified the BIOS to make the card work in a Mac and he said it did for some short time. But suddenly it stopped working for some reason.
PCIID was 68B8 before flashing and now it is 68B0. What's the importance of that?
Thank you for your input, it's much appreciated.
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
Hybrid Images
EFI [Extensible Firmware Interface] used in some motherboards to improve upon the old legacy bios.
(Possibly similar to the Graphic card version UEFI-hybrid VBIOS however once legacy bios has been updated to UEFI it is not possible to flash a legacy bios back with these) Not sure about the EFI whether it can be written to
PM Sent
atb
Law-II
Sandell
9 (0.00/day)
Ok, thank you.
Didn't know that existed in graphics cards.
I guess my next step will be to try and flash the card in another computer, to rule out that the computer possibly has something that disturbs the flash process.
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
General info
Mac mod; 5770_vervet_netkas.efi here This may assist other member of the TPU community to assist.
It mentions "keep the original copy of the XFX5770.rom somewhere just in case something goes wrong if you need to re-flash your card to the original rom." but dose not go into detail other than the .rom modded image should be over written when flashing back the original .rom image.
Note: Could you upload/attach a zipped copy of the original vbios image you are using
atb
Law-II
Sandell
9 (0.00/day)
This is the file i received from the guy that did the mac mod, I think it was saved from the card before it was modded. http://www.techpowerup.com/forums/attachment.php?attachmentid=52493&stc=1&d=1379498232
The card is a XXX version which has 875MHz core and 1300MHz memory clock. There are three firmwares in the database which has these clocks. One of them seems to be the one I received with the card, and it says "XXX Edition": http://www.techpowerup.com/vgabios/66216/xfx-hd5770-1024-091210.html
Another newer firmware matches the numbers on the card, namely this one: http://www.techpowerup.com/vgabios/75175/xfx-hd5770-1024-100326-2.html
Does it matter which one I choose? I have tried both and the same error occurs anyway.
  • 5770orig.zip
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
Assuming have tried the vga card in a system after each flash and it has blank screen on boot
As have Flashed two other vbios images and have the original vbios image [looks fine; btw] using force flash command [atiflash -p -f 0 #BiosName#.rom] (0=top PCIe slot)
and still get following error
atiflash -ai 0
No VBIOS
*Maybe worth a try
Flash once more with the original bios, follow this link from heading Re flash
see attached SST25VF010 pin-outs below
atb
Law-II
1,980 (0.39/day)
Mainland Britain
System Name H2o Box
Case Corsair O-800D
Mouse Zelotes T-90
Hi
It's alive! I tried to use Atiflash 3.99 instead of 4.07. Works like a charm! Thank you for all your input!
Well done: thanks for the feedback; who would have thought 3.99, nice job :toast:
atb
Law-II
Sandell
9 (0.00/day)
Yeah, that wasn't very obvious. Hopefully someone will find this thread if they encounter the same problem.
2,318 (0.33/day)
System Name MONEY PIT
Processor i7-3770K @ 4800 1.20v batch #3231B415 Delided
Motherboard ASrock Z77 OC Formula w onboard waterblocks
Cooling Apogee HD, MCP655,rad MCR320-XP,Micro Rev2 res
Memory G,skill Trident X F3-2400C10D-16GTX
Video Card(s) EVGA GTX 980 Ti Classified with EK nickel/acetal waterblock installed
Storage 2x120gig Wildfire raid0 2x120gig VERTEX3 raid0
Display(s) 3/ Samsung2343bwx + 65in LG 4K
Case NZXT Phantom White w/red
Audio Device(s) ReCon3d fatal1ty pro, Logitech z906 THX
Power Supply corsair AX860i
Mouse Rat7
Software 64bit ++++ win 10
@ Law-II Thks
Always Try the flasher from the card era if the most current won't work
