Atom/Nvidia-Ion Choppy Video...Need Help
blackcat54
43 (0.01/day)
Computer: Zotac MAG HD-ND01
Op System: Win 7 64bit
Bios: 1/7/11, v08.00.15
Video Drivers: Nvidia 301.42
Dedicated Video Memory: 256 MB
Problem: Choppy Video. Every second there is a subtle jerk.
Updated Bios and Video Drivers (see above).
Couldn't find a way to increase dedicated video memory above 256 MB.
Any solutions out there?
OneMoar
There is Always Moar
8,793 (1.66/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
define #video
flash video downloaded video HD/SD WHAT
blackcat54
43 (0.01/day)
Video = Downloaded HD Video, .mp4, .mkv, .avi, .wmv.
YouTube (Flash?) stutters too.
temp02
493 (0.09/day)
My guess would be some program running in the background performing some timed task, for instance I once noted that on a machine running XP a simple task manager running in the background would create a "subtle jerk" about every second on a very demanding 3D application just because the task manager kept refreshing its taskbar icon.
Try to decrease the amount of programs running to the bare essential and see if the situation improves.
de.das.dude
Pro Indian Modder
8,922 (1.70/day)
Internet is borked, please help.
System Name Monke | Work Thinkpad| Old Monke
Case Ant Esports Tempered case | Thinkpad | Antec
Audio Device(s) Logitech Z333 | Jabra corpo stuff
Mouse Logitech G400 | nipple
VR HMD ;_;
atom sucks at HD video. but i think you can configure that nvidia to help render videos. mussels is good at this
blackcat54
43 (0.01/day)
This is a fresh windows install only a few days old.
Not many programs running.
This is a known issue which I think has something to do with the Nvidia Ion video processor not having enough memory at its disposal.
blackcat54
43 (0.01/day)
I have another Atom system with Radeon HD4300 video that renders HD video smoothy.
So I know the Atom is capable. In this case I think it is the Ion portion that is the bottleneck.
7,223 (1.03/day)
Processor AMD Ryzen 7 7700 Raphael \ i5-1135G7 Tiger Lake-U
Motherboard ASRock B650M PG Riptide Bios v. 2.02 AMD AGESA 1.1.0.0 \ Lenowo BDPLANAR Bios 1.68
Video Card(s) Asus GeForce RTX™ 4070 Dual OC GPU: 2325-2355 MEM: 1462| Intel® Iris® Xe Graphics
Display(s) LG UltraGear 27GP850-B 1440p@165Hz | LG 48CX OLED 4K HDR | Innolux 14" 1080p
Software Win11 Pro 23H2 UK | Win11 LTSC UK / Arch (Fan)
u should be able to through Cuda/PhysX to decode 720/1080p even on youtube synes Adobe Flash Player supports Cuda, and u got an Intel Ion chipset that has like 16 cuda cores or something.
with a problem like CoreAVC if u use Mediaplayer Classic u can play 1080p in mp4 or mkv when the codec is h264/x264/ccv1 and original bluray with a program like PowerDVD or Arcsoft TotalMedia Theatre 5.
OneMoar
8,793 (1.66/day)
Rochester area
I recommend MPC-HC weekly builds I use it on all my machines for everything
http://xhmikosr.1f0.de/mpc-hc/
install and then go in the options and configure for evr-custom preset
OneMoar
8,793 (1.66/day)
Rochester area
core avc is good but it has issues with some videos if you run DXVA
blackcat54
43 (0.01/day)
I installed CCCP and CoreAVC.
Not sure how to configure it all.
Anyway......Video still Stutters!
7,223 (1.03/day)
i use these setttings, but before doing anything go to Nvidia Controlpanel-->Configure Surround,PhysX and set PhysX to ur GPU.
CoreAVC Settings:
CCCP Settings:
and in FFDShow Audio Decoder Configuration i set FLAC to disabled.
i have run 1080p mkv on a old Intel P4 with 4gb memory and a GT 520 1gb flawless with these settings.
blackcat54
43 (0.01/day)
Tried those settings....
Still stutters!
I prefer Splash Pro EX video player over Media Player Classic.
OneMoar
8,793 (1.66/day)
Rochester area
don't bother with cccp it just causes conflicts MPC-HC + coreavc should be enough
cdawall
where the hell are my stars
27,680 (4.16/day)
Houston
System Name All the cores
Processor 2990WX
Motherboard Asrock X399M
Cooling CPU-XSPC RayStorm Neo, 2x240mm+360mm, D5PWM+140mL, GPU-2x360mm, 2xbyski, D4+D5+100mL
Memory 4x16GB G.Skill 3600
Video Card(s) (2) EVGA SC BLACK 1080Ti's
Storage 2x Samsung SM951 512GB, Samsung PM961 512GB
Display(s) Dell UP2414Q 3840X2160@60hz
Case Caselabs Mercury S5+pedestal
Power Supply Seasonic Prime 1200w
Mouse Thermaltake Theron, Steam controller
Keyboard Keychron K8
Software W10P
Lack of system ram?
blackcat54
43 (0.01/day)
Well.......
It has 2GB Ram.
With only 256MB dedicated to video.
With no way (that I know of) to allocate more dedicated video memory.
Completely Bonkers
2,576 (0.40/day)
Processor Mysterious Engineering Prototype
Motherboard Intel 865
Cooling Custom block made in workshop
Memory Corsair XMS 2GB
Video Card(s) FireGL X3-256
Display(s) 1600x1200 SyncMaster x 2 = 3200x1200
Software Windows 2003
Completely Bonkers
2,576 (0.40/day)
Well.......
It has 2GB Ram.
Pagefile/disk cache issue? Set up a small ramdisk (say 256MB) and point your temps there. See if that improves things. Did you turn off antivirus? And NTFS filestamping?
blackcat54
43 (0.01/day)
I'll have to look into the ramdisk... never worked with that.
No anti virus.
Filestamping, that's new to me.
cdawall
27,680 (4.16/day)
Houston
Processor 2990WX
Software W10P
OneMoar
8,793 (1.66/day)
Rochester area
its has nothing todo with the am mount of ram or ram disks he has For fucks sake people quit talking out your ass hes cpu limited atoms are SLOW and I am sure the codecs arent configured properly
start over
1. remove all media players codecs and crap from the system
2. clean install coreAVC and MPC-HC
3.open MPC-hcs options and set the output to http://cl.ly/JDSl
4. then goto the filters tab and uncheck everything on the right handside http://cl.ly/JCE0
this setup will decode 720p h264 HIGH on a 2.2Ghz AMD 2700+ running windows xp with 64MB of on-board video (note the atom is a little weaker because its clocked slower so make sure you are using threaded decode (doesnt apply to coreavc >ffmpeg)
sorry I sound like a ass but dam people get your heads on strait or don't post
cdawall
27,680 (4.16/day)
Houston
Processor 2990WX
Software W10P
2->4GB is all it took to get an L310 and HD3200 to play video smooth.
OneMoar
8,793 (1.66/day)
Rochester area
hes not running a HD3200 what probly happens is that you changed the ram out for faster ram AMD's igpus are memory bandwidth limited and its not a question of GPU power that machine I listed has SIS 9xx Video chip circa 2002
something is bogging the proc down if hes not using both threads for the decode then thats the issue a 1.6Ghz ATOM is not gonna decode HD video or flash video
he needs to get hardware decode working or it wont ever play
