Attempting to enable Resizable BAR with RTX 3070
SpiritMolecule
1 (0.20/day)
Hello, any help would be appreciated as I've been attempting to get this done for awhile now with no luck.
I am simply trying to enable resizable BAR on my system.
It is enabled in BIOS along with the other necessary settings, but still seems to be disabled when checking in the Nvidia app and GPUZ.
Some digging around on the internet leads me to believe it is an issue with my VBIOS
However, I am unable to update the VBIOS using the ASUS utility as it simply gives the message "Your VBIOS does not need to be updated."
I am posting some screenshots of relevant information along with this post. Thank you in advance as I am very clueless/ inexperienced with this!
1,934 (0.61/day)
System Name BOX
Display(s) LG 27GP950-B
Mouse Logitech RX-250
Keyboard HP KB-9970
What is your motherboard (+BIOS version or date) and CPU ?
IIRC, there were some MBs that had a bug that needed 4G decoding to be enabled and ReBAR set to "Disabled" for it to actually work (or was it opposite, ie. "rebar on", "decode off" ?).
I'm not sure if this was later fixed.
Solaris17
Super Dainty Moderator
27,153 (3.84/day)
Alabama
System Name RogueOne
Processor Xeon W9-3495x
VR HMD Quest 3
This, it sounds like a definite bios issue. The vBIOS should not matter in the slightest, by the time 3xxx series came out they were compatible. Only 2xxx series cards (and then even only some) needed vbios updates. Some released late enough to have the needed modules.
You should probably start with what EXACTLY you have checked or otherwise enabled in the BIOS.
199 (0.12/day)
WorldWideWeb
System Name ROG
Processor i5-11400F
Motherboard ROG Strix Z490-H Gaming
Cooling Be Quiet Pure Rock (BK009)
Memory Kingston Fury RENEGADE KF3600C16D4/16GX (KIT 2x16)
Video Card(s) GTX1060 6Gb AERO ITX OC
Storage NVMe WD Black SN750 ; Samsung EVO 840 SSD and Mechanical TBs...
Display(s) iiyama Black Hawk G-Master GB2745HSU
Case CM HAF-X
Audio Device(s) Yamaha AV Creative DTT2200
Power Supply Corsair RM-1000
Mouse SteelSeries Rival
Keyboard MS Sidewinder X6
Software Windows 10/11
MB seems to be a new model (not specified...) as it supports PCIe 4.0, so get to bios and enable it (RBAR), that should be enabled by default bios in current standards..., unless bios is too old and needs update. that's the culprit.
302 (0.61/day)
Sounds like VBIOS needs updating but ASUS updater is being naughty. Can extract updated VBIOS from package and use table list to see which ones (dual BIOS?) IIRC and nvflash.
Maybe some human memory problems @Solaris17
Some early 30 series came with resizable BAR capped to 256MB. All the VBIOS updates did AFAICT is change that cap (1 nibble) to suit the VRAM Size. 20 series was a hack, not a VBIOS change.
505 (3.24/day)
it (RBAR)
I'm not sure MSI or ASUS mainboards call it differently.
Some ASUS mainboards has still a bug where some settings are visually enabled but broken. Only fix - firmware flash - try again with everything entered fresh - not from the saved usb profile.
Note firmware flash = cmos reset -> new uefi from the mainboard homepage flash = different version = preferred - newer version -> enter all settings by hand
It's not that easy to enable stuff on some mainboards. For some reason.
Note: We are waiting for a reply from the original topic poster.
42,847 (6.70/day)
Update your motherboard bios first, then see if that feature is even in it.
You never told us what mobo you have or cpu
Ruru
S.T.A.R.S.
13,115 (2.98/day)
Jyväskylä, Finland
Processor AMD Ryzen 7 5800X / Intel Core i7-6700K
Motherboard Asus ROG Crosshair VII Hero / Asus Z170-K
VR HMD Oculus Rift CV1
Hard to say before OP tells what platform he/she is using.
I'm 99.99% sure that it's not a VBIOS issue since doesn't RTX 30 cards support ReBAR straight outta the box?
42,847 (6.70/day)
Its a hit and miss certain conditions must be met.
A 4GB+ GPU is required, CSM must be disabled. And rebar is not some miracle performance boost that everyone thinks it is.
Ruru
S.T.A.R.S.
13,115 (2.98/day)
Jyväskylä, Finland
Well, at least on the desktop side, there aren't any RTX cards which have less than 6GB VRAM.
42,847 (6.70/day)
Giving the minimums is why
Ruru
S.T.A.R.S.
13,115 (2.98/day)
Jyväskylä, Finland
Saw your ninja edit above, isn't ReBAR anyway just a marginal speed boost even in the best scenarios (except for Intel GPUs)?
42,847 (6.70/day)
I found a page from here that gives a general description.
Zen 2 and core i10 is minimum Requirement, that leaves the mobo having the setting.
I only know the b550 steel legend has it in bios, so other mobos idk.
INSTG8R
Vanguard Beta Tester
8,087 (1.10/day)
Canuck in Norway
Case TT Kandalf L.C.S.
Mouse G502 Hero
Keyboard G19s
VR HMD Oculus Quest 3
Software Win 11 Pro x64
As someone mentioned earlier I know in my BIOS by default ReBar was enabled but 4G was disabled and greyed out. You have to disable RreBar that allows you to enable 4G then re-enable ReBAR :wtf:
Solaris17
27,153 (3.84/day)
Alabama
VR HMD Quest 3
one of my AM4 boards (wish I remembered which it was) did this. If I clicked the "Rebar Enable" like toggle on the main bios page literally would not function. I had to shut it off, then go into the pcie settings and enable above 4g encoding.
INSTG8R
8,087 (1.10/day)
Canuck in Norway
Mouse G502 Hero
Keyboard G19s
Yeah basically one setting is blocking the other, and why only one of the two being enabled when it does nothhing without the other one,..
42,847 (6.70/day)
Yeah i saw those functions in the SL board, the user of that board is not a gamer and is running W11 using a R7 250X Ghost. Anyways we wont know until the op gives mobo and cpu details
302 (0.61/day)
@SpiritMolecule You can check your VBIOS is capped at 256MiB by maybe checking GPU-Z "message" or dumping VBIOS and attaching.
If it's AS10 then it's capped to 256MiB.
42,847 (6.70/day)
Op gave us vague info, we don't even know if the system is capable of it to begin with .
302 (0.61/day)
Right
Sorry I didn't get back to you earlier, some info on Asus site from 2021.
All of our GeForce RTX 3060 graphics cards support Resizable BAR out of the box. However, a video BIOS (VBIOS) update is required before Resizable BAR can be enabled with our GeForce RTX 3060 Ti, GeForce RTX 3070, GeForce RTX 3080, and GeForce RTX 3090 graphics cards. We provide self-contained VBIOS updater packages through our product support pages.
Not sure what the OP has, if it's AS10 then it doesn't seem to appear in the Asus update tool. Of course it could be already good and a mainboard BIOS problem but thought it might be an easy check.
7,128 (4.85/day)
São Paulo, Brazil
Display(s) 55-inch LG G3 OLED
Audio Device(s) Apple USB-C + Sony MDR-V7 headphones
Software Windows 10 Pro 22H2
Initial batches of OG non-LHR RTX 3060 through 3090 (with BIOS dates of 2020) have no ReBAR support. BIOS must have the following settings:
- ReBAR: Auto
- Above 4G Decoding: Enabled
- CSM: Disabled
- OS installed in UEFI mode
1. Backup original BIOS using GPU-Z
2. Download latest VBIOS and nvflash from TPU
3. Rename the downloaded VBIOS as GA104.rom for convenience
4. Run CMD as administrator, point out to nvflash folder and then issue the following command:
nvflash64 GA104.rom
If more than one NVIDIA GPU is present on the system use the nvflash64 --list command before and -i(number) to choose the correct card
5. Reboot with shutdown -r -t 0 after the process is complete
6. If BIOS settings are correct, no further configuration will be required and the driver will enable Resizable BAR without further user input. System Information in NVIDIA Control Panel will say Resizable BAR "Yes" and GPU-Z will show a BAR1 size of the full GPU memory capacity
Let us know if you need any further help.
Ruru
S.T.A.R.S.
13,115 (2.98/day)
Jyväskylä, Finland
Interesting, my 3080 TUF has a receipt from 17.9.2020, though I'm maybe the third owner so could be updated before I bought this.
7,128 (4.85/day)
São Paulo, Brazil
Yup, it most definitely was. My 3090 that I ordered at launch did not have ReBAR enabled either, that came on an update a few months down the road.
