AUO Has 8K Gaming TV Panel with 120 Hz Refresh Rate and 4608 Zone FALD
18,120 (2.45/day)
TPU doesn't normally cover TVs, but at Touch Taiwan had a new gaming focused TV panel that might very well end up in some very high-end gaming "monitors" as well. The panel is a 65-inch model that supports 7680 x 4320 resolution at up to 120 Hz. However, the high-end specs don't stop there, as the panel has a 4,608 zone full array local dimming backlight, which gives it a typical brightness of 400 cd/m², but it can go up to 1,800 cd/m² at 10 percent areas in HDR mode.
As with the 4K display panel we wrote about earlier, this TB panel also features AUO's A.R.T. "reflectionless" feature, which should prevent it from being overly reflective in brightly lit areas. The demo panel was powered by MediaTek's Pentonic 2000 SoC, which is currently one of the highest-end 8K TV processors and potentially the only one with support for H.266 video decoding. Sadly we don't have any indication on which TV manufacturers will use the new display, but regardless of the brand, we expect the retail products to be very expensive.
537 (0.16/day)
System Name My Addiction
Processor AMD Ryzen 7950X3D
Motherboard ASRock B650E PG-ITX WiFi
Cooling Alphacool Core Ocean T38 AIO 240mm
Memory G.Skill 32GB 6000MHz
Video Card(s) Sapphire Pulse 7900XTX
Storage Some SSDs
Display(s) 42" Samsung TV + 22" Dell monitor vertically
Case Lian Li A4-H2O
Audio Device(s) Denon + Bose
Power Supply Corsair SF750
Mouse Logitech
Keyboard Glorious
VR HMD None
Software Win 10
Benchmark Scores None taken
Are there any existing connection out there to feed this beast?
17,650 (4.67/day)
Motherboard B650 Steel Legend
Cooling Frost Commander 140
Display(s) 27" QD-OLED Glossy 240hz 1440p
Case NZXT H710 (Red/Black)
this is dumb as shit
163 (0.09/day)
I hope h.266 gets buried, we don't need additional proprietary codecs for useless resolutions like 8k.
AV1 did the job.
18,120 (2.45/day)
AV1 did the job.
AV1 isn't nearly as efficient for 8K content though. I'm not keen on proprietary codecs either, but hopefully there will be an AV2 or something.
8,788 (4.01/day)
System Name Bragging Rights
Processor Atom Z3735F 1.33GHz
Memory 2GB DDR3L-1333
Case Veddha T2
Mouse MX Anywhere 2
Software W10 21H1, barely
No thanks,
8K truly is a solution to a problem that nobody has. Even 4K feels extravagant and beyond the point of diminishing returns. If there's leftover processing power at 4K, it's better spent on attaining a high-refresh experience, not needlessly driving up the resolution. it's not as if game assets are even made with 8K in mind yet.
3,965 (0.60/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
No thanks,
Hmmm. I suppose Be good for sharp billboards or something.
definitely a niche product though. Basically 4 - 32” 4k screens glued together with fald backlight and 120 refresh. Cut it into quarters and sell them as monitors. :). I wouldn’t mind a 4k monitor with 120 refresh and fald. :)
1,596 (0.64/day)
London, UK
65 inch? if they change this to a maximum 42 inch 16:9 then it might be a killer.
7,714 (1.78/day)
AV1 did the job.
Considering who's backing that I doubt it'd go away anytime soon but as long as Google continues with the development or AV1 or a future AV2 codec the paid alternative will not gain any real traction! YT probably has more streams (minutes) viewed than all other sites combined.
576 (0.28/day)
System Name Fractal
Processor Intel Core i5 13600K
Motherboard Asus ProArt Z790 Creator WiFi
Cooling Arctic Cooling Liquid Freezer II 360
Memory 16GBx2 G.SKILL Ripjaws S5 DDR5 6000 CL30-40-40-96 (F5-6000J3040F16GX2-RS5K)
Video Card(s) PNY RTX A2000 6GB
Storage SK Hynix Platinum P41 2TB
Display(s) LG 34GK950F-B (34"/IPS/1440p/21:9/144Hz/FreeSync)
Case Fractal Design R6 Gunmetal Blackout w/ USB-C
Audio Device(s) Steelseries Arctis 7 Wireless/Klipsch Pro-Media 2.1BT
Power Supply Seasonic Prime 850w 80+ Titanium
Mouse Logitech G700S
Keyboard Corsair K68
You can see the difference in PPI? I'd go the other way, maybe if it was a 120" panel. It would be a killer. If it wasn't going to cost $100k.
1,596 (0.64/day)
London, UK
100k? where did you get that price?
576 (0.28/day)
System Name Fractal
Just made it up in jest. Just saying it's going to be unaffordable for 99.9% of the people out there.
1,596 (0.64/day)
London, UK
If it was microled then I would agree on that price being around 50k but since is mini led, my take on the price is around 5k maximum. The issue for a subpixel layout that is not rgb to be clear and readable must have a high ppi reason a 42 inch or lower would be best. Anyway, 50% of these prototypes are never released. They just want to show off hoping to get investors money.
