Auto control of custom cooling on graphics card
Dux
511 (0.16/day)
Ok. so what i want to do is put 2 x 120mm fans on my graphics card. I did it in the past and it does wonders for cooling. But in the past i put fans that had only molex connectors so they were constantly running at full speed. Cooling was great, but so was noise. I would like to buy 2 x 120mm fans with PWM. So the fan speed can alternate.
Now what I'm wondering is, is there any kind of software that can read GPU temperatures and control the speed of these 2 fans based on that temperature? I know that there are warious programs and potenciometre that can control fan speed, but i want to control their speed specifically based on GPU temperature.
3,059 (0.43/day)
Baltimore MD
Processor Ryzen 5900X
Motherboard ASUS Prime X470 Pro
Cooling Arctic liquid freezer II 240
Memory 2 x 16 Gb Gskill Trident Z 3600 Mhz
Video Card(s) MSI Ventus 3060 Ti OC
Storage Samsung 960 EVO 500 Gb / 860 EVO 1 Tb
Display(s) Dell S2719DGF
Case Lian Li Lancool II Mesh
Mouse Logitech G703
Keyboard Logitech G513
Software Win 11
11,880 (2.15/day)
Manchester uk
Keyboard Roccat Aimo 120
VR HMD Oculus rift
Software crashes though, your GPU already controls fans why not wire them into that?.
1,065 (0.28/day)
System Name loon v4.0
Processor i7-11700K
Motherboard asus Z590TUF+wifi
Cooling Custom Loop
Memory ballistix 3600 cl16
Video Card(s) eVga 3060 xc
Storage WD sn570 1tb(nvme) SanDisk ultra 2tb(sata)
Display(s) cheap 1080&4K 60hz
Case Roswell Stryker
Power Supply eVGA supernova 750 G6
Mouse eats cheese
Keyboard warrior!
Benchmark Scores https://www.3dmark.com/spy/21765182 https://www.3dmark.com/pr/1114767
1,029 (0.29/day)
Nova Scotia, Canada
Cooling Cooler Master Hyper 212 Plus
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) PCWINMAX RTX 3060 6GB Laptop GPU (80W)
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 11 Pro 64-Bit
Was thinking about that. Simply plugging the new fans to fan conectors on graphics card PCB. But will the PCB be able to prowide enough power for bigger 120mm fans?
The stock 2080 fans are around 7w each from what I could see so I think it'll be fine.
Dux
511 (0.16/day)
Unfortunately when i was cleaning the fans on my graphics card i peeled off the stickers that said power info. But i think they are 6V fans. 120mm case fans are 12V
And off topic, can someone tell me what these stars beneath usernames mean?
1,029 (0.29/day)
Nova Scotia, Canada
Mouse Evga Torq X3
I've never seen a 6V rated fan on a gpu, they're all 12V.
Edit: actually you should check to see that your card has 4-pin fan headers in the first place. IIRC The ref 2080Ti uses a 14pin? header instead.
1,065 (0.28/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
there are plenty of high end 120mm fans that use 3 watts or less. i doubt that header will have an issue with 0.5 amps. if it gets any air flow, i wouldn't be freaked out with a peak, not continuous, closer to 1 amp.
Dux
511 (0.16/day)
OK. SO i did some googling and seems that connecting your case fans to graphics card PCB can quickly burn out that part of PCB. So i found and downloaded this program and testing it currently. Can read GPU sensor and control any case fan speed based on that. You can even set a custom fan curve just like in MSI afterburner.
And it seems to work great so far. Now just to find some good 120mm fans with high air flow that don't cost too much.
1,065 (0.28/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
sorry but my gut reaction is, did they use some 25 watt delta finger choppers? (FUD!)
you've seen the 12v on what you fans have, look for the amps - it will be there and match appropriately. :cool:
Dux
511 (0.16/day)
It's the same. 12V, 0,40A.
But no point on spending extra money now on these adapters if i can software control fans based on GPU tems and keep them connected to MBO.
1,065 (0.28/day)
Processor i7-11700K
Cooling Custom Loop
Mouse eats cheese
Keyboard warrior!
i did the same fan/MB set up w/speed fan but i just prefer "hardware based" solutions and hate auto starting software while booting. it just annoys me.
but hey if you're happy. :rockout:
Dux
511 (0.16/day)
So i did buy 2 x 120mm LC Power LC-CF-120 fans. I am surprised with how quiet and good these cheap fans are. GPU temps went from around 65 celsius stock to 55 celsius when overcloked. And you can barely hear these fans. Unlike stock cooler that would get very loud.
Thinking about putting 2 of these on my CPU cooler as well.
