[Case Gallery] B & G Theme - RA23R
F
felix
Specs:
INTEL CORE 2 DUO E8600 E0 4.32 GHZ (480x9@1.375v):: XFX NFORCE 780I P08 :: OCZ REAPER HPC DDR2 PC2-9600 1200MHZ (960Mhz@5-5-5-15) :: ZOTAC GTX 260 AMP2 EDITION =SLI= ZOTAC GTX 260 AMP2 EDITION :: SEAGATE BARRACUDA 250GB & 500GB :: SAMSUNG WRITEMASTER 20X DVD-ROM :: COOLER MASTER REAL POWER PRO 850 WATTS :: COOLER MASTER CM690 BLACK/GREEN THEME WITH 7 120MM FANS (MODDED 3 TOP EXHAUST) :: RAZER KRAIT :: RAZER PRO SOLUTIONS PAD :: RAZER LYCOSA :: WATER COOLED BY = SWIFTECH APOGEE GTZ - HWLABS BLACK ICE PRO III - ASETEK WATERCHILL EXTREME
Mods:
THIS IS REPOSTED AFTER HAVING NEW HARDWARES AND A LITTLE MOD FOR WATERCOOLING
ANY COMMENTS ARE WELCOMED AND AN EARLY THANKS TO THOSE VOTED, IF U HAVE ANY IDEAS PLS SHARE WITH ME TOO. THANKS.
617 (0.10/day)
Pacific Coast
System Name Z77 Rev. 1
Processor Intel Core i7 3770K
Motherboard ASRock Z77 Extreme4
Cooling Water Cooling
Memory 2x G.Skill F3-2400C10D-16GTX
Video Card(s) EVGA GTX 1080
Storage Samsung 850 Pro
Display(s) Samsung 28" UE590 UHD
Case Silverstone TJ07
Power Supply Seasonic PRIME 600W Titanium
Mouse EVGA TORQ X10
Keyboard Leopold Tenkeyless
Benchmark Scores 3DMark Time Spy: 7695
Very clean.
Next step: get rid of that 780i "franken cooler" and go WC on the chipset.
7/10.
3,318 (0.56/day)
Dallas, Tx
Processor Intel i5-3570K @ 3.4Ghz
Motherboard Asrock LGA1155 Z77 Extreme 4
Cooling Cooler Master Evo 212
Memory 16GB (4X4) G.Skill Ripjaw 2 DDR3-1600
Video Card(s) Nvidia gForce GTX 660ti
Storage 1x Samsung 840 EVO 256GB 6Gb/s, 1x WD 500GB 6Gb/s, 1x WD 80GB 3Gb/s
Display(s) ASUS VH242H Black + 2 HP 2311x 23" LED
Case Fractal Design R4
Audio Device(s) Realtek OnBoard Both
Power Supply Cooler Master 850w
Software Windows 7 Ultimate 64-bit SP1
Odin Eidolon
920 (0.15/day)
Rockclimbing somewhere in Italy
Processor e6300 @ 3000, stock Volts
Motherboard msi p35 neo2-FIR
Cooling HDT-1283
Memory 2gb tracers 1066 micron d9GMH, cooled by a modded CoolIt Memory Cooler
Video Card(s) HIS 4850 ICEQ4
Storage WD Caviar 16 320gb WDAAKS + 640gb WDAAKS
Case CM RC-690 sligthly modded
Power Supply Bequiet darkpower PRO 850W (say overkill? :D)
Software kubuntu 8.10 + Windows XP, soon Windows 7 too
nice! how is that asetek pump?
F
felix
i wish so much i could go wc on the chipsets but where im from, the block would be too costly to ship . . . so guess ill just have to stick with air for now.
@Odin Eidolon
the pump is okay, saves space n performs fairly well, just that i couldnt install the software, some problem which i didnt really bother to resolve.
3,296 (0.54/day)
System Name Thakk
Processor i7 6700k @ 4.5Ghz
Motherboard Gigabyte G1 Z170N ITX
Cooling H55 AIO
Memory 32GB DDR4 3100 c16
Video Card(s) Zotac RTX3080 Trinity
Storage Corsair Force GT 120GB SSD / Intel 250GB SSD / Samsung Pro 512 SSD / 3TB Seagate SV32
Display(s) Acer Predator X34 100hz IPS Gsync / HTC Vive
Case QBX
Audio Device(s) Realtek ALC1150 > Creative Gigaworks T40 > AKG Q701
Power Supply Corsair SF600
Mouse Logitech G900
Keyboard Ducky Shine TKL MX Blue + Vortex PBT Doubleshots
Software Windows 10 64bit
Benchmark Scores http://www.3dmark.com/fs/12108888
WOw! How you fit a tri rad up there is superb! I saw one like it but only was dual.. this is nobel!
Nice paintjob too
btw, those blue clips on the 5" bays and on the expansion slot lock can be removed.. I advice you color them black as well. Then the power and reset switch you can color green so that ittl be pronounced from the black backdrop and go with the theme as well. You can also try to run the mems on cas 4 @ that bandwidth. That intake on the back might hurt also.. since it will suck up the hot air from the 260s and the PSU (warm air exhausted from those always come up)
2,228 (0.36/day)
Larisa, Greece
System Name StarCruiser Dark Knight v.2
Processor Intel® Core™ i5-3570K
Motherboard P8Z77-V LX
Cooling 1x custom W/C loop/ inflow:6x120 /outflow:4x120, 2x200
Memory Viper 3 Black Mamba (4x4GB)
Video Card(s) Powercolor LCS 5870
Storage 1X 128GB OCZ, 2 x 1.500 Gb Seagate
Display(s) Samsung 24" LC24F396
Case custom MDF case (I BUILT IT) check sig.....NOW
Power Supply Tagan 900 watt
Software Win 7 RC / Open office / Games
solid build, great specs, perfectly positioned rad, and I love the way the tubing is aligned with the case window, just love it! Only thing did not like is that the bottom HDD area is a bit crouded with cables that I believe should be easily hidden....9.5/10!
chk my rig...http://www.techpowerup.com/gallery/1832.html
F
felix
@Bjorn_Of_Iceland
I actually cut a 360 fan hole on the top, plus a little extra for the tubings to go through. So its pratically a huge hole on the top. Yeah, i think ill colour them clips . . . and bout the rear fan . . . ive seriously nvr thought bout it, haha, thx for the tip. Btw i tried running cas 4 but it always bsod, these rams arent that good anyways.
3,296 (0.54/day)
System Name Thakk
Cooling H55 AIO
Case QBX
Mouse Logitech G900
@Bjorn_Of_Iceland
Kudos to that. Will probably copy your layout once I have me LC someday. ^^
3,296 (0.54/day)
System Name Thakk
Cooling H55 AIO
Case QBX
Mouse Logitech G900
Can I ask one more thing, that is a slim type 120 x 3 rad right?
