B550 chipset no 1st or 2nd gen ryzen cpu?
123 (0.08/day)
I just was wondering why this chipset doesn't support older generation ryzen cpu's. Is there a technical reason that I don't know of. I was troubleshooting a board with a 3900x in it and I had a spare r5 1400 cpu and I was going to use it to test the board but I realized that the cpu isn't supported on b550 chipsets. I was just wondering. It seems odd to have the same socket and not be able to use older processors. Do any of you very smart people know why?
newtekie1
Semi-Retired Folder
28,473 (4.16/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
AFAIK, there isn't a technical reason B550 doesn't support older CPUs. The issue is a BIOS size limitation. A lot of board OEMs were using small sized BIOS chips. This meant that their motherboard could only support so many CPUs. So AMD decided to just cut support for the lower processors from B550, so the motherboard manufacturers could keep using the smaller BIOS chips.
Low quality post by Blue4130
1,002 (0.18/day)
Unsure if its possible with this or not, but AGESA codes in general say what CPU it can support, so if you somehow find some suitable ones, or mod them, you can probably make B550 run older Ryzen too.
Im not experienced in modding new BIOSes tho, I did opposite which was adding full 6 core support to old 1366 motherboard, including fixes for Meltdown, Specter and so on, at least what Intel released.
But unless things changed drastically, it shouldnt be that hard to simply swap support of many new CPUs for many old CPUs, as long as mobo can work with it.
441 (0.35/day)
Germany
System Name Homebase
Processor Ryzen 5 5600
Cooling Scythe Mugen 5 RGB
Mouse Sharkoon Sharkforce Pro
Keyboard Fujitsu KB955
These two ASUS B550 do support Zen and Zen+ CPUs.
bug
13,507 (4.00/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
If the mobo is not very new, it was probably launched with support for older CPUs. You can just flash the older BIOS and you will get support.
But yes, a lot of people took AMD's promise at face value and disregarded the numerous technical hurdles you have to overcome to reuse the same mobo for many generations of CPUs. Those same people seem a little confused, now that reality caught up ;)
1,002 (0.18/day)
Hm so its just matter of BIOS editing most likely.
1,978 (1.65/day)
Lithuania
System Name Shizuka
Processor Intel Core i5 10400F
Motherboard Gigabyte B460M Aorus Pro
Cooling Scythe Choten
Memory 2x8GB G.Skill Aegis 2666 MHz
Video Card(s) PowerColor Red Dragon V2 RX 580 8GB ~100 watts in Wattman
Storage 512GB WD Blue + 256GB WD Green + 4TH Toshiba X300
Display(s) BenQ BL2420PT
Case Cooler Master Silencio S400
Audio Device(s) Topping D10 + AIWA NSX-V70
Power Supply Chieftec A90 550W (GDP-550C)
Mouse Steel Series Rival 100
Keyboard Hama SL 570
Nah, AMD straight up lied that's it. ADM didn't particularly have problems with AM2, AM2+, AM3, AM3+ and FM2+ platforms and they supported several generations of CPUs just fine. AM4 platforms just wasn't well thought out and thus it has a case of split support.
441 (0.35/day)
Germany
Deleted member 202104
It only depends on the SMU inside the AGESA. It is a kinda artificial limitation, and you can check the bios-files before flashing with SMU Checker provided by this german website:
If the CPUs are listed when examining the BIOS file, does that mean they're supported? For example, here's the output from the latest BIOS file for my board (MSI B550 Unify):
441 (0.35/day)
Germany
As far as I can see the microcode is there yes, unfortunately this does not mean it will work. The vendor still have ways to block the boot :( that's why I recommend those two Asus Boards.
Ah, ok, thanks. That makes sense as the board doesn't show support for most of that list. Unfortunately, I don't have any older CPUs/APUs to test. Appreciate the information.
