Be Quiet - 12VHPWR PCI-E Adapter Cable and RTX 5070 Ti
Morganas
1 (1.00/day)
Hello,
I have a power supply: Be Quiet Straight power 11 (850W).
I bought a video card: TUF-RTX5070TI-O16G-GAMING
Questions:
1. Will the power be enough, because it recommends 850W?
2. Can I connect via the Be Quiet 12VHPWR PCIE-E Adapter cable (which I also bought original), or is it better to connect via the manufacturer's (Asus was included with the board) adapter 3x8?
3. The VGA (Asus) manufacturer's adapter has more small pins than the power supply. I read that this has no effect, but is it really so?
https://help.moddiy.com/en/article/...al-pins-are-used-in-the-12vhpwr-cable-yg3cv4/
My Be Quiet 12VHPWR PCIE-E Adapter cable (2 Small pins in Red Square) Nvidia Adapter (4 Small pins in Red Square)
PC Build:
MB: Z690 AORUS PRO (rev. 1.x)
CPU : i5-14600K
RAM: 32 GB
PSU : 850W (be quiet)
GPU: TUF-RTX5070TI-O16G-GAMING
PS: I don't want the VGA to "burn out" due to too little power or something like that. The internet is full of stories about bad adapters or bad connections...
https://www.tomshardware.com/pc-com...ion-points-at-prior-rtx-4090-fe-cabling-usage
Thanks for answers !
1,195 (0.79/day)
Processor E5-4627 v4
Motherboard VEINEDA X99
Memory 32 GB
Video Card(s) 2080 Ti
Storage NE-512
Display(s) G27Q
Case MATREXX 50
Power Supply SF850L
Of course you can use the new adapter. A 300 W GPU with 600W cable is perfectly reasonable. As far as I'm aware the small pins are just grounded or open and don't have a sefeguard function with the Nvidia adapter.
Sol_Badguy
14 (0.54/day)
@Morganas
Hello.
The PSU is a good one, the wattage is ok for that build, the only issue could be the multi-rail design because it requires load balancing.
I don't see any problem with using the Be Quiet! 12VHPWR cable, regarding the sense pins please read the last paragraph from this page:
I looked at the PSU manual and to achieve load balancing using the Be Quiet! cable you insert one connector into PCIe3 and the other into PCIe1, but you probably knew that already.
And everything should be fine. The cable connection to the PSU would be quite solid compared to having a 12V-2x6 socket.
