- Oct 9, 2007
- 47,438 (7.50/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
Be Quiet!, the market leader in PC power supplies in Germany for eleven consecutive years*, adds a new top flow CPU cooler to its current portfolio of cooling products. Shadow Rock TF 2, the follow-up to be quiet!'s successful Shadow Rock TopFlow, adds several optimizations that significantly improve upon its predecessor's cooling potential. With its low-profile design and supported TDP of 160W, Shadow Rock TF 2 is ideal for powerful compact PC systems requiring extensive cooling.
Five 6 mm high-performance copper heat pipes are designed with aluminum caps at the ends, enhancing Shadow Rock TF 2's clean modern look. Overall cooling performance is improved significantly by a complete redesign of the cooling fins - direct connections between fins and base plate support faster heat dissipation. As a result, Shadow Rock TF 2 cools down the CPU significantly better than its predecessor at a similar TDP rating of 160W. Additional cooling support comes from a 135mm silence-optimized be quiet! fan using a durable rifle bearing, airflow-optimized fan blades and a design producing sound pressure levels up to 24.4dB(A) at the maximum of 1,400 revolutions per minute.
Intelligent, compact top flow design allows maximum compatibility
At a height of just 112mm (including fan), the Shadow Rock TF 2 is ideal for cooling powerful PCs that have limited space. Small, diagonally arranged fins spread airflow to all components surrounding the CPU socket, adding significant cooling support for PCs case fans, an often overlooked, but important aspect for many smaller systems. Shadow Rock TF 2 includes mounting kits for all Intel- and AMD-based sockets, including AM4.
Unmatched craftsmanship and affordable price
Shadow Rock TF 2's concept was designed and is quality controlled in Germany, offering the best mix of performance and price in the premium compact CPU cooler segment. be quiet! signs for the CPU cooler's workmanship with its 3-year manufacturer's warranty.
Available now, the Shadow Rock TF 2 top flow CPU cooler is priced at €60 / $60 / £54.99 MSRP.
