Best AIO for 14900k
7 (0.00/day)
Looking for some recommendations for a AIO for use on a 14900k. Looked at a million reviews of AIO's , but none of them show the performance when paired with an 14900k. Either 420/360mm
Currently have an Asus ROG RYUO III 360 and it cannot tame this CPU.
1,490 (3.68/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
To handle 14900K density thermal output, would consider a custom loop with an all copper block. I tried HeatKiller plated model and is no good for 14700K even at defaults. Tight mount and lid-less could also be a consideration using just paste would help temps quite, bit more with LM.
Assuming the ambient temp is normal 75f/24c of course.
I have no AIO suggestions at this time. Sry.
437 (0.91/day)
USA
System Name Dark Palimpsest
Processor Intel i9 13900k with Optimus Foundation Block
Motherboard EVGA z690 Classified
Cooling MO-RA3 420mm Custom Loop
Memory G.Skill 6000CL30, 64GB
Video Card(s) Nvidia 4090 FE with Heatkiller Block
Storage 3 NVMe SSDs, 2TB-each, plus a SATA SSD
Display(s) Gigabyte FO32U2P (32" QD-OLED) , Asus ProArt PA248QV (24")
Case Be quiet! Dark Base Pro 900
Audio Device(s) Logitech G Pro X
Power Supply Be quiet! Straight Power 12 1200W
Mouse Logitech G502 X
Keyboard GMMK Pro + Numpad
Liquid freezer iii 420. Get some p14 Max fans on there and use the best paste you can get (kpx, kryonaut extreme (pink), etc.) otherwise custom loop is in order.
Also, have you done any undervolting or V/F point negative offsets? It really helps with all-core workloads and keeps things much more manageable.
sneekypeet
not-so supermod
29,631 (4.34/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Are you vastly overclocked or running BIOS overvoltage?
7 (0.00/day)
No overclock at all. Just using an Intel default profile on the motherboard (Performance) 253/253/307a . But the fan noise levels from the current AIO im using are really bad as it struggles to cope with the thermals. Looking for something that's way more quiet than i have just now , that can tame the beast :D
437 (0.91/day)
USA
A 420 aio with really good paste is your best option without going to a MO-RA4 type of thing (like my setup lol).
Whats your case setup like? Even with the best aio, you have to make sure your case is giving it fresh cool air or it'll be hot anyway. Then it's about finding fans that sound pleasant to you. My personal favorite are be quiet! 140mm fans, but the non-ppc-industrial noctua fans also sound good. P14 Max I have not listened to in person, but on paper they're unbeatable and the reviews have been really good. I've used the p12 fans and they're good for the cheap price, but they're not moving a ton of air and I've heard (from someone here who uses them a lot) that they're not the most reliable long-term. I like the sound of 140mm fans more than 120mm fans, personally.
7 (0.00/day)
I have a Be-Quiet Dark Base Pro , so the thermals internally are pretty good. Im kinda leaning towards your idea of a freezer iii 420 and seeing how it sounds with the fans it comes with as standard. Maybe opt to swap those out if need be :)
ir_cow
4,577 (0.77/day)
USA
If you are just using Intel's default power plan, there is no need for a custom loop. Grab a nice 360 AIO and accept temps will be in the 90s.
2,697 (0.45/day)
System Name Dire Wolf IV
Processor Intel Core i9 14900K
Motherboard Asus ROG STRIX Z790-I GAMING WIFI
Cooling Arctic Liquid Freezer II 280 w/Thermalright Contact Frame
Memory 2x24GB Corsair DDR5 6667
Video Card(s) NVIDIA RTX4080 FE
Storage AORUS Gen4 7300 1TB + Western Digital SN750 500GB
Display(s) Alienware AW3423DWF (QD-OLED, 3440x1440, 165hz)
Case Corsair Airflow 2000D
Power Supply Corsair SF1000L
Keyboard Chuangquan CQ84
Not really a recommendation, just a data point:
At Intel stock "extreme" settings, my Freezer II 280 keeps my 14900K at 85-90c (depending on what the ambient is at the time) when maxed out at 253W. I have a pretty crappy chip, so stock volts are relatively high and I have way too little spare time to sit an optimize voltage curves nowdays. I am on the latest microcode and I get ~37k R23 at those temps which seems to be more or less in line with what people are getting out of these things (at baseline settings and with low-ish end cooling). I run the two stock fans the cooler comes with. I have zero case fans. The only fans in here are the GPU (which sorta works like an intake), the AIO which exhausts and the PSU which effectively has its own air channel so it doesn't really affect other air movement.
What is your workload? If you plan to run this at 253W 24/7 then then the above likely won't make your system happy, but if you're not running it at full tilt extensively, this is just fine.
At the default power plan a good 280/360 should have no issues keeping the chip from throttling. A 420 would allow for quieter fans to be used, which if you have room and budget for is probably better for noise levels.
