Best codec pack for windows 8 on ms surface pro?
654 (0.10/day)
India
System Name HP envy 17 3090nr
Processor Intel core i7-2670QM 2.2ghz
Memory 8gb
Storage 1TB
Software Genuine Windows 7 Home Premium
Benchmark Scores Windows experience index 6.9
I've just got microsoft surface pro tablet - using windows 8 first time..
1. which is best codec pack for windows 8?
shark, windows8codecs.org , windows8codecs.com , klite codec pack - which in klite - mega/full?
2. which is best media player for microsoft surface pro?
gom player isnt working properly..it's not fitting properly to screen..on keeping full screen stretched, even we cant see video bar..
5,226 (0.84/day)
System Name Addison Clark
Processor Ryzen 9 7950x3D delid
Motherboard Asus X670E Hero
Cooling Custom Bykski loop CPU, GPU, 2x 360 rads, and 1x 280 rad with Arctic P12 and P14 ARGB fans
Memory G.Skill DDR5-6000 64GB CL30
Video Card(s) Gigabyte 4090 Aorus Master
Storage Kingston Fury 2TB and 4TB NVME
Display(s) Samsung 57"
Case Lian Li O11 mini
Power Supply Thermaltake 1000w SFX-L
Keyboard Corsair K95 Platnium
Software Win 11 Pro
I've always recommended CCCP for a codec package and have you tried vlan player?
654 (0.10/day)
India
Memory 8gb
Storage 1TB
5,731 (1.07/day)
West Midlands. UK.
System Name Ryzen Reynolds
Cooling Raijintek Leto Pro
Power Supply Corsair VS 550w
Mouse Zalman ZM-M401R
Keyboard Razor Lycosa
+1 for VLC plays most content without the need for codecs, be careful with some so-called codec packs as they can mess your system up, the ones listed are fine if VLC doesn't suit your needs. Not too sure how klite is these days, is it even still updated? as it's years old.
Frick
Fishfaced Nincompoop
19,707 (2.86/day)
w
System Name Black MC in Tokyo
Processor Ryzen 5 7600
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Keyboard Dell SK3205
VLC is great, but not if you have a large music collection or want a sort of playlist. I love the program, but the interface is horrible.
I too would recommend CCCP and the media player of your choice. WMP works good imo.
1,645 (0.27/day)
Raleigh, North Carolina
System Name Current
Processor i5 2500k @ 4.5
Motherboard ASRock Z77 Extreme4
Cooling Xigmatek Gaia
Memory 2x4G G-skill Sniper
Video Card(s) GTX 680
Storage 128 Crucial M4, 1 TB Seagate Baracuda
Display(s) Shimian Achieva 27"
Case Corsair 400R
Power Supply Corsais HX-620
Software Windows 7
I actually skipped codec packs on my latest windows installation and installed XBMC it plays everything I've thrown at it sans codec packs of any kind. Something to look into if you want an all in one. Seems they've added swipe controls for Windows based tablets into the nightlies. Worth giving a shot if you're having issues
Aquinus
Resident Wat-man
13,173 (2.79/day)
Concord, NH, USA
System Name Apollo
Processor Intel Core i9 9880H
Memory 64GB DDR4-2667
Case MacBook Pro (16", 2019)
Mouse Logitech MX Master 3
Software MacOS 12.1
43,613 (6.47/day)
Memory 32GB G.Skill 6000Mhz
Video Card(s) Asus RTX 4090
Storage WD/Samsung m.2's
Display(s) LG C2 Evo OLED 42"
Mouse Razer Basilisk V3 Pro
Keyboard Epomaker 84 key
With VLC, there is no need for codec packs.
6,089 (1.14/day)
System Name RemixedBeast-NX
Cooling Dell Standard
Memory 24GB ECC
Mouse Logitech G700s/G502
Keyboard Logitech K740
Software Linux Mint 20
Benchmark Scores Network: APs: Cisco Meraki MR32, Ubiquiti Unifi AP-AC-LR and Lite Router/Sw:Meraki MX64 MS220-8P
Klite messes up bad. I would avoid it. I've had nothing but issues with it.
Videos looked terrible, I had syncing issues, and lots of other stuff.
I would just use VLC and have no codecs. That's how I do it.
I just have VLC for videos and J-River Media Jukebox for music.
Frick
19,707 (2.86/day)
w
I have found that if you are very VERY low on resources (like if you're using a netbook or something) VLC sans codecs usually does better than codecs + something else.
I still don't like it though, the interface is terrible.
Aquinus
Resident Wat-man
13,173 (2.79/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
I like Media Player Classic because is supports H.264 offload to your GPU using DXVA with compatible video files. It also works without any extra codec packs most of the time.
6,089 (1.14/day)
Memory 24GB ECC
MetroX VLC skin
http://maverick07x.deviantart.com/art/VLC-MetroX-345256054
My screenshot:
Other media player is J-River Media Jukebox Also with MetroX skin
http://maverick07x.deviantart.com/art/MetroX-327728200
654 (0.10/day)
India
Memory 8gb
Storage 1TB
but vlc will work properly on ms surface pro? interface?
1,645 (0.27/day)
System Name Current
Case Corsair 400R
Software Windows 7
Give it a try and tell us :) easy enough to uninstall an application if you don't like it.
654 (0.10/day)
India
Memory 8gb
Storage 1TB
k. tri d gom player but it didn't work well. well,i will try this too. :)
4,213 (0.71/day)
Vietnam
System Name Gaming System / HTPC-Server
Processor i7 8700K (@4.8 Ghz All-Core) / R7 5900X
Motherboard Z370 Aorus Ultra Gaming / MSI B450 Mortar Max
Cooling CM ML360 / CM ML240L
Memory 16Gb Hynix @3200 MHz / 16Gb Hynix @3000Mhz
Video Card(s) Zotac 3080 / Colorful 1060
Storage 750G MX300 + 2x500G NVMe / 40Tb Reds + 1Tb WD Blue NVMe
Display(s) LG 27GN800-B 27'' 2K 144Hz / Sony TV
Case Xigmatek Aquarius Plus / Corsair Air 240
Audio Device(s) On Board Realtek
Power Supply Super Flower Leadex III Gold 750W / Andyson TX-700 Platinum
Mouse Logitech G502 Hero / K400+
Keyboard Wooting Two / K400+
Benchmark Scores Cinebench R15 = 1542 3D Mark Timespy = 9758
another vote for cccp here.
7,311 (1.03/day)
Video Card(s) Asus GeForce RTX™ 4070 Dual OC (Waiting on RX 8800 XT) | Intel® Iris® Xe Graphics
i also use CCCP on Windows 7 and tried it out on Windows 8, but atm i got no Windows 8 running so i dunno how LAV and DXVA works but it works flawless on my Windows 7 and uses my GTX670 4gb for decoding my anime and most of the time even better then CoreAVC did :D
Aquinus
Resident Wat-man
13,173 (2.79/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
Are you sure it's actually getting decoded by the video card? Last time I installed CCCP it used DirectShow for H.264 video and offloaded it all to the CPU. Maybe it has changed but just MPC alone had all the codecs I needed before I grew up and out of anime and even now, all the video files I have can be played with MPC without a single extra codec.
You're also looking for the GPU bit stream decoder when you're looking to see if MPC-HT is using DXVA.
If it doesn't say anything on this screen after installing CCCP, it's not using your GPU. Also to my knowledge MPC-HT and Windows Media Player are the only two mature applications that will use DXVA for decoding. When I used CCCP I had to disable a number of extra codec that CCCP adds just to get GPU decoding back.
6,089 (1.14/day)
Memory 24GB ECC
Codecs are harder to get rid of and often require a reformat.
1,077 (0.19/day)
System Name Primary Rig
Processor e8500 Q822A549 4.5ghz AIR
Motherboard Foxconn Mars P35
Cooling TRUE
Memory 2 x2GB Patriot Viper 1066 5-5-5-12 @ 1.8v
Video Card(s) Sapphire 5870 Unlocked
Storage 300gb Velociraptor
Display(s) Dell 24" Ultrasharp
Case Coolermaster CM690
Power Supply PC Power & Cooling 750w Quad Silencer
Software Windows 7 Ultimate x86
Vlc works fine on my Acer Iconia w510 windows 8 tablet.
If u do klite, be very careful.
Do the basic pack only, And ONLY video components.
DO NOT select any audio - it will screw up the WMP audio.
Then It should work fine.
7,311 (1.03/day)
http://www.techpowerup.com/forums/attachment.php?attachmentid=51189&stc=1&d=1369560048
u got the newest version? i use Combined-Community-Codec-Pack-2013-04-20.exe myself atm and they have "LAV" in it now.
and yes ino Combined-Community-Codec-Pack-RC-2013-05-20.exe is out, i just haven't updated yet ^^;
here is LAV Video decoder filter:
Aquinus
Resident Wat-man
13,173 (2.79/day)
Concord, NH, USA
System Name Apollo
Software MacOS 12.1
http://www.techpowerup.com/forums/attachment.php?attachmentid=51194&stc=1&d=1369594206
Yes, and MPC doesn't require any extra codecs that could mess with Windows Media Player. I personally haven't used LAV but I rarely will install extra codecs. They only have caused me headache in the past and when you have things like MPC and Foobar2000 there is really no reason to need to install extra codecs imho.
