Best fan orientation
419ohio0000
4 (0.13/day)
What is the best fan orientation to lower my GPU and not have to much excessive CPU heat. My GPU runs at 84 Celsius while gaming. I have a rtx 3060 GPU and a Corsair CPU water cooler top mounted in a cyber power pre built case
42,215 (6.64/day)
Typical layout in an ATX case is front is intake, back is exhaust, top is exhaust, and bottom is intake. 3060, get some thermalpads
6,770 (4.72/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
The top fans are installed incorrectly. Hot air goes up, flip the top fans for exhaust. Back should be exhaust, the two beside the motherboard are installed correctly.
292 (2.89/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
Looks to me like those front two fans are exhausting. I'd flip them around. back fan looks to be in-taking, I'd flip it around. top fans for Rad are exhausting, so they are fine.
I could be wrong, and certainly fans with reverse blade angle and spin exist, but these look to be standard fans. In other words, looks like you have your arrows backwards. Typically the fan motor housing is the back of the fan, and is also the direction that the fan blows. Very often fans are marked as to air flow direction.
79 (0.02/day)
System Name Vergil (I NEED MORE POWER)
Motherboard ASUS ROG STRIX B550-A
Cooling EVGA CLC 280mm
Memory 16GB G.SKILL Trident Royal Z Silver
Video Card(s) Radeon 6800XT Red Devil
Storage Plenty
Display(s) Acer RG241Y
Case Thermaltake VG200
Audio Device(s) ASUS Xonar STX -> JVC SP-402 / Sennheiser HD58X
Power Supply XPG 750W Core Reactor
Mouse Razer DeathAdder
Keyboard HyperX Alloy Origins Red
The airflow in this case doesn't seem to be very good to start with.
If the aim is to lower temperature of the GPU alone, i would make the side fans as INTAKE, the 2 top and the rear as EXHAUST
Since your GPU is not a blower model, it will spit hot air all inside the case, if there's nothing taking it outside, everything will cook, hence the setup i suggested.
For better results i would really just trash this case and get one with decent airflow, preferably one that has bottom fan support to blow cold air directly on the GPU's face
6,881 (1.47/day)
Florida
System Name natr0n-PC
Video Card(s) EVGA 3070ti FTW
Storage Various
Display(s) Pixio PX279 Prime
Software XP/7/8.1/10
remember no matter the orientation air doesn't flow through glass
6,922 (3.05/day)
California
System Name His & Hers
Storage lots of SSD.
Just do testing with fans in different orientation and see what works best for you. I've done quite a few different setups in my 011 XL and they all work pretty well but some are slightly better than others depending on if the cpu or gpu is the priority.
6,770 (4.72/day)
São Paulo, Brazil
Aw you beat me to my lovingly crafted mspaint tutorial, but i'll share it anyway :)
I'm planning on writing a thread explaining how this works, I have a few guide threads drafted but didn't manage to finish them yet :oops:
3,032 (4.72/day)
Russian Wild West
System Name DLSS / YOLO-PC
Processor i5-12400F / 10600KF
Motherboard Gigabyte B760M DS3H / Z490 Vision D
Cooling Laminar RM1 / Gammaxx 400
Memory 32 GB DDR4-3200 / 16 GB DDR4-3333
Video Card(s) RX 6700 XT / R9 380 2 GB
Storage A couple SSDs, m.2 NVMe included / 240 GB CX1 + 1 TB WD HDD
Display(s) Compit HA2704 / MSi G2712
Case Matrexx 55 / Junkyard special
Power Supply Thermaltake 1000 W / Corsair CX650M / DQ550ST [backup]
Software Windows 10 and 11
It already exists.
Get cool air from below, strike it away to above. It's that simple.
1,976 (0.62/day)
Processor Intel i5 8400
Storage 1TB 980 Pro
Software W11 Pro
I [pedantic] would like to point out hot air doesn't necessarily go up. :p I'm quite sure you know the following that is laid out for OP.
You provided the correct orientation so allow me to add that tuning fan curves in a tough situation is all about building or releasing air pressure. Air will seek the most opportune path to fill or evacuate which is rarely going to be upwards. The issue right now is likely parts recirculation and effectively leaving the gpu fans in dead air by creating a wall it can't escape through. In that situation 10x air flow won't solve a thing.
6,770 (4.72/day)
São Paulo, Brazil
Yeah, it is an oversimplification, but one that generally works with PC building in mind. I've written down a more technical explanation in my notes, going around the principles of buoyancy, air pressure, heat density etc but if I write that all down, i'm gonna come across as pedantic and a bit of a snob ;)
419ohio0000
4 (0.13/day)
Thanks for the replies. I ended up taking the fans out to see the orientation. All the fans were installed as exhaust except the back fan that was a intake. So I left the top fans as exhaust, flipped the back fan to a exhaust and made the 2 side fans intake for cool air.
1,976 (0.62/day)
Storage 1TB 980 Pro
Software W11 Pro
Maybe a visual simulation of the problem with modern cases would avoid undesirable associations. natr0n got a good laugh out of me.
We both know pedantic angry comments never approaching a key point or accepting the long line is why those threads stay in the editor.
Pop Art Love GIF by Xinanimodelacra
12,341 (5.75/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Yep. And glass with a 1-2 cm gap is still glass. Don't learn this the hard way like I did with the Corsair 280X.
292 (2.89/day)
Texas, USA
235 (1.85/day)
System Name AM4_TimeKiller
Case Corsair 7000D Airflow
Mouse Logitech wireless mouse
Are those fans reversed?
If not, two at the top and in the fron are positioned as exhaust fans, only one in the back is intake fan. Of course the GPU overheats, there is not enough cold air in it's vicinity. Basically your case is about to implode. :D
Was this prebuilt?
2,186 (1.13/day)
LV-426
System Name Custom
Processor i9 9900k
Cooling corsair h150i
Memory 4x8 3200mhz corsair
Display(s) MSi MAG341CQ
Case Lian Li Pc-011 Dynamic
Mouse Logitech G403
Keyboard Logitech G110
top intake back switch it to intake and then the side ones make it exhaust... i think that is the best... for your situation
2,092 (0.53/day)
System Name Ryzen 2023
Processor AMD Ryzen 7 7700
Motherboard Asrock B650E Steel Legend Wifi
Memory G Skill Flare X5 2x16gb cl32@6000 MHz
Video Card(s) Sapphire Radeon RX 6950 XT Nitro + gaming Oc
Storage WESTERN DIGITAL 1TB 64MB 7k SATA600 Blue WD10EZEX, WD Black SN850X 1Tb nvme
Display(s) LG 27GP850P-B
Case Corsair 5000D airflow tempered glass
Power Supply Seasonic Prime GX-850W
Mouse A4Tech V7M bloody
Keyboard Genius KB-G255
Software Windows 10 64bit
It should be 2 intakes a and 3 exhausts.
419ohio0000
4 (0.13/day)
Was this prebuil
It was a pre-built, And my buddy installed the CPU cooler for me and everything worked fine until recently. I took everything apart to clean it because it was getting hot again on the GPU. So how it was set up after I looked at the fan arrows was there was only one intake and that was the back upper fan. Now I have the back upper fan as an exhaust and the top mounted radiator as an exhaust. Then the two side fans are intake and it seems to run a lot cooler. I'm around 72 Celsius playing call of duty versus 84 Celsius the previous day on my GPU.
This is how it was after I looked at all the arrows on the fans.
This is the direction I flipped the fans and it is running around 72 Celsius Now playing call of duty vs 84 on the GPU originally
12,341 (5.75/day)
Midlands, UK
I was gonna say that I don't see any change, then I realised that you used the original picture with different arrows. Tricky. :D
4,612 (0.94/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
hot air will go in any direction you push and/or pull it with a fan, with no air flow hot air will rise but do so slowly
The one mistake I constantly see people with air coolers for the CPU is they use the roof front mount as intake or outake when it should be left open so the CPU fan can pull in cooler air. The back roof mount should be outake
This video does a pretty good job in set ups although he mistakenly say "heat" rises as opposed to hot air
419ohio0000
4 (0.13/day)
Yeah lol sorry. I was just updating the post since I wasn't home to take a picture. I appreciate everyones input and advice, I think I have a way better airflow set up now considering all the variables
5,084 (3.77/day)
Colorado, U.S.A.
Software Windows 11 Home
I'm still wondering about fans in series vs parallel.
  • Fans in parallel will have a certain flow, but the same two fans in series will have less flow.
I reason as follows: as one adds more fans in a line, so the later fans don't get to do much as the flow has already reach maximum. I am not suggesting a line of fans, just using this idea to argue that fans in series are not as effective as fans in parallel.
I'm also one who feels that a CPU fan that blows air onto the mother board is important to cool the VRMs
10,767 (1.73/day)
Austin Texas
System Name stress-less
Processor 9800X3D @ 5.42GHZ
Memory 64GB DDR5 6000 CL30-36-36-76
Video Card(s) RTX 4090 FE
Case Jonsbo Z20
Audio Device(s) Yes
Power Supply Corsair SF750
Keyboard 65% HE Keyboard
It depends, the whole "hot air rises" only applies to a system with no airflow, and it happens relatively slowly -- as soon as you introduce any active circulation into the mix that whole concept no longer applies.
Also cooling your radiator water with warm air drops the efficiency of the watercooler massively, so I actually prefer if theres an AIO that it's used as an intake rather than exhaust - the airflow that @OP posted is actually perfect for low fan speed (quiet) systems - just ramp the back fan with systemp and you're good to go.
The back fan has far less restriction and positive pressure so it's actually probably close to moving the same amount of air as the pull rad fans.
6,770 (4.72/day)
São Paulo, Brazil
The problem is that Gaming PCs are constantly generating heat with high wattage parts, axial GPUs are almost always making the upper area of the chassis warm :)
