Best lubrication for fan
4ektonik
19 (0.01/day)
Hi.I have a question about lubricate for pc fan.i'm going to grease the fun and i think that grease to choose.IMHO i think to buy grease silicone in air spray/or oil silicone what will be better?
I read many articles and i vote for that option.
Help me what choose silicone oil or grease air spray/in plastic box
Or maybe you have any other suggestion.I need you help.But pls advise me safe and best option in professional approach.
41,504 (6.58/day)
Electric motor oil. Or sewing machine oil. Or any light machine oil. Or whatever...doesn't really matter that much...as long as it's oil...and NOT grease.
+1
26,898 (6.54/day)
I use dielectric grease whenever I service and re-lube fans.
https://www.amazon.com/Permatex-22058-Dielectric-Tune-Up-Grease/dp/B000AL8VD2
AsRock
TPU addict
19,011 (3.01/day)
UK\USA
As Mr Genius said sewing machine oil. silicone ( Super Lube ) types can work to, i put some on some very old Rosewill fans about 7 years ago and still running like new.
If you use sewing machine oil or alike make sure you do not over do it and run the fan out of system before putting to use.
silentbogo
5,533 (1.39/day)
Kyiv, Ukraine
System Name WS#1337
Processor Ryzen 7 3800X
Memory 4x8GB Samsung DDR4 ECC UDIMM
Video Card(s) Inno3D RTX 3070 Ti iChill
Storage ADATA Legend 2TB + ADATA SX8200 Pro 1TB
Case ghetto CM Cosmos RC-1000
Audio Device(s) ALC1220
Mouse Logitech G603
Software Windows 11, Ubuntu 20.04 LTS
At home I'm using a small tube of odorless lube that came with my hair trimmer )))
Always forget to bring some "good stuff" from my office.
FreedomEclipse
~Technological Technocrat~
23,913 (3.75/day)
London,UK
System Name DarnGosh Edition
Processor AMD 7800X3D
Memory G.Skill Trident Z5 NEO DDR5 6000 CL32-38-38-96
Storage WD SN770 1TB (Boot)| 2x 2TB WD SN770 (Gaming)| 2x 2TB Crucial BX500| 2x 3TB Toshiba DT01ACA300
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
Avoid products like WD40 and '2in1' oil. WD40 wont 'lube' anything but its great at getting water out of stuff like bike chains or unjamming some mechanical parts that have become rusted and stuck together..
2in1 will just turn into a sticky mess that will jam up your fans. silicone, lithium grease or sowing machine oil is always good.
9,781 (2.24/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
27 (0.01/day)
Hologram Earth
System Name Solaris | Haze
Processor Ryzen 1600AF @ 4.0 | Xeon E3-1235
Motherboard ASRock B450M Pro4 R2.0 | MSI H61M-P31/W8
Cooling Vetroo U6 Pro ARGB | Hyper 212 Evo
Memory F4-3200C16D-32GVK | HX318C10FBK2/16
Video Card(s) Red Devil RX 5700 XT | Nitro RX 480 OC
Storage SN550, Constellation & Ultrastar 2TB, My Book 4TB | TEAM GX2, Toshiba 1TB & Ultrastar 3TB
Display(s) Samsung S27C570 | UN40H5003
Case Cougar MX330 w/ Vetroo SG-120's | DIYPC VII-BK-15LED
Audio Device(s) Logitech Z313 & Astro A10's
Power Supply EVGA SuperNOVA 650 GT | Corsair VS450
Mouse Redragon Cobra M711 | Pictek PC280A
Keyboard Redragon Shiva K512 | Logitech EX 110
been using 3-in-1 multi purpose as well as the blue bottle for years to extend a fans life, with no bad results other than an oily mess here and there. blue is better for high rpm fans like delta, like 5k rpm etc.
583 (0.27/day)
Tried and tested multiple times. I have fans over 10 years old still running fine and completely silent, lubricated with sewing machine oil which is very cheap. WAY cheaper than buying new fans.
Whoever said "Buy new fans", shame on you.
2,258 (0.39/day)
System Name Budget AMD System
Processor Threadripper 1900X @ 4.1Ghz (100x41 @ 1.3250V)
Motherboard Gigabyte X399 Aorus Gaming 7
Cooling EKWB X399 Monoblock
Memory 4x8GB GSkill TridentZ RGB 14-14-14-32 CR1 @ 3266
Video Card(s) XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1025Mhz HBM2
Storage 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA
Display(s) Vizio 22" 1080p 60hz TV (Samsung Panel)
Case Corsair 570X
Power Supply Seasonic X Series 850W KM3
I've been using Lucas Oil Gun Oil. Works great for ball-bearing fans. Does dry out after about a year though of 100% on usage.
newtekie1
Semi-Retired Folder
28,473 (4.13/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
I use standard motor oil, 5w-30 because that is what my car takes. I just keep it in one of those little oiler type cans.
1,327 (0.37/day)
Nowy Warsaw
System Name SYBARIS
Processor AMD Ryzen 5 3600
Motherboard MSI Arsenal Gaming B450 Tomahawk
Cooling Cryorig H7 Quad Lumi
Memory Team T-Force Delta RGB 2x8GB 3200CL16
Video Card(s) Colorful GeForce RTX 2060 6GV2
Storage Crucial MX500 500GB | WD Black WD1003FZEX 1TB | Seagate ST1000LM024 1TB | WD My Passport Slim 1TB
Display(s) AOC 24G2 24" 144hz IPS
Case Montech Air ARGB
Audio Device(s) Massdrop + Sennheiser PC37X | QKZ x HBB
Power Supply Corsair CX650-F
Mouse Razer Viper Mini | Cooler Master MM711 | Logitech G102 | Logitech G402
Keyboard Drop + The Lord of the Rings Dwarvish
Software Windows 10 Education 22H2 x64
Picked up a little vial of "bearing lubricant" from my local cycle store a few weeks ago for $1 or so converted. I think the guy put wd-40.
Previously used sewing machine oil too.
16,793 (4.61/day)
I learned something today, cheers mate
AsRock
TPU addict
19,011 (3.01/day)
UK\USA
You can use WD40 but it needs to be 100% removal after and a real replacement.
166 (0.05/day)
Copenhagen, Denmark
System Name Royal Fortune (Main)/Adventure Galley (NAS)/Little Ranger (HTPC)
Processor Intel i5 4460/AMD C-70/Intel Pentium G3258 Anniversary Ed.
Motherboard Gigabyte ga-z97x-gaming 5/Asrock C-70M1/Asrock Z97 Anniversary
Cooling Phanteks PH-TC12DX/Stock/Raijintek Triton Core
Memory 8GB Team Group Dark 1600 CL9/8GB Team Group Elite 1600 CL9/8GB Avexir Core 1600
Video Card(s) VTX3D R9 280X 3GB/APU/Palit GTX 750 TI StormX Duo
Storage 120GB Team Group Ultra L5 SSD + 1TB WD Black/4 X 2TB WD Blue/120 GB Kingston V300
Display(s) Dell 2310/AOC e2070Swn 19.5"/TV
Case In Win 707/Bitfenix Prodigy M/Dimastech Easy V3
Audio Device(s) N/A
Power Supply EVGA Supernova GS 650W/be quiet! System Power 7 350W/Xigmatek Maverick 400W
Mouse Logitech G303 Daedalus Apex/Razer Abyssus/-
Keyboard Corsair K70 Red/Steelseries Apex Raw/Logitech K400
Software Win10/FreeNAS 9.3/KodiBuntu
Sewing machine oil is formulated for high RPM bearings in a hot, dusty, dirty environment...that sounds like the average fan to me
4,994 (0.71/day)
South of England
System Name Box of Distraction
Processor Ryzen 7 1800X
Motherboard Crosshair VI Hero
Cooling Custom watercooling
Memory G.Skill TridentZ 2x8GB @ 3466MHz CL14 1T
Video Card(s) EVGA 1080Ti FE. WC'd & TDP limit increased to 360W.
Storage Samsung 960 Evo 500GB & WD Black 2TB storage drive.
Display(s) Asus ROG Swift PG278QR 27" 1440P 165hz Gsync
Case Phanteks Enthoo Pro M
Audio Device(s) Phillips Fidelio X2 headphones / basic Bose speakers
Power Supply EVGA Supernova 750W G3
Keyboard Cherry MX Board 6.0 (mx red switches)
Software Win 10 & Linux Mint
Benchmark Scores https://hwbot.org/user/infrared
I used to use a drop of 10W40 synthetic, just because i had some on hand lol. I haven't had any fans go bad lately but the Antec 120mm fans I re-lubed lasted for years, ended up getting thrown away with the case but they were still kinda okay, just not worth keeping.
1,025 (0.34/day)
Croatistan
System Name 1.21 gigawatts!
Processor Intel Core i7 6700K
Motherboard MSI Z170A Krait Gaming 3X
Cooling Be Quiet! Shadow Rock Slim with Arctic MX-4
Memory 16GB G.Skill Ripjaws V DDR4 3000 MHz
Video Card(s) Palit GTX 1080 Game Rock
Storage Mushkin Triactor 240GB + Toshiba X300 4TB + Team L3 EVO 480GB
Display(s) Philips 237E7QDSB/00 23" FHD AH-IPS
Case Aerocool Aero-1000 white + 4 Arctic F12 PWM Rev.2 fans
Audio Device(s) Onboard Audio Boost 3 with Nahimic Audio Enhancer
Power Supply FSP Hydro G 650W
Mouse Cougar 700M eSports white
Keyboard E-Blue Cobra II
Software Windows 8.1 Pro x64
Benchmark Scores Cinebench R15: 948 (stock) / 1044 (4,7 GHz) FarCry 5 1080p Ultra: min 100, avg 116, max 133 FPS
I use bike chain oil with PTFE (teflon). It's thicker than sewing machine oil.
Most oils will be OK, be that car engine oil, chainsaw chain oil, oil for fine mechanical parts, sewing machine oil... WD-40 will be good only as a short term solution and I wouldn't recommend it.
dorsetknob
9,106 (1.27/day)
I Have used :) extra Virgin Olive Oil :D in the past applied via Hypodermic Syringe (its Electrically non Conductive) injected thru the covering Brand sticker/seal
7,022 (1.01/day)
USA
Cooling Noctua NH-D15S, 2xThermalRight TY-143, 4xNoctua NF-A12x25,3xNF-A12x15, 2xAquacomputer Splitty9Active
Storage 1x Samsung 970 Pro 512GB NVMe (OS), 2x Samsung 970 Evo Plus 2TB (data), ASUS BW-16D1HT (BluRay)
Case Lian Li O11 Air Mini
Mouse Zowie EC3-C
Software Win 10 LTSC 21H2
Thin automotive oils will work. 0W20 synthetic.
583 (0.27/day)
That is risky because even very good olive oil rots.
All organic oils rot eventually.
Only mineral/synthetic oil should be used (preferably designed specifically for small machinery, like the readily available sewing machine oil)
Motor oil is designed to be the most fluid at temperatures around 90-95 degrees Celsius, meaning for room-temp equipment it's not very good. I also recommend against it.
350 (0.15/day)
U.S.A.
System Name Dell T3500
Processor Xeon X5687
Motherboard Dell - 9KPNV
Cooling Dell U016F
Memory 12gb ECC 1333
Video Card(s) MSI rx480 gaming X
Storage 1tb WD blue
Case Dell T3500
If you are using sprays heavy in solvents remain mindful they could be detrimental to certain plastics. WD40 is a good example. Mostly kerosene. And not made to be a lubricant in the first place. It's a water displacement product.
My preference is a tiny drop or two of heavy duty silicone from the spray can. Have checked the MSDS and confirmed it has no ingredients harmful to plastics. But only on fans that can benefit. Which brings up the next subject. Many ball bearings used in these fans are sealed units and cannot be easily lubed without disassembly.
Indeed. Multi-viscosity motor oils (probably 90% of the market these days) are designed to be thickest at higher temps. Thanks to those wonderful thermally sensitive expanding coil shaped polymer molecules. Number before the 'W' represents thickness at 32-f. After the 'W' represents thickness at 212-f.
4ektonik
19 (0.01/day)
but oil silicone will be as fine as silicone air-spray?
350 (0.15/day)
U.S.A.
Cooling Dell U016F
Storage 1tb WD blue
Case Dell T3500
Very glad you asked. One should always read the labels and instructions to be sure their particular product is plastic safe. Some are. Some are not.
