Best motherboard for running 192GB on Ryzen 9 9950x
c7aesa7r
2 (0.67/day)
I already have purchased this memory pack: CORSAIR VENGEANCE DDR5 RAM 192GB (4x48GB) 5200MHz CL38 Intel XMP iCUE Compatible Computer Memory - Black (CMK192GX5M4B5200C38)
And just now after reading the "validated memory support list" of the GIGABYTE AORUS PRO ICE memory i figured this:
The non-rgb pack is from Spectek B i have no idea what brand is this, i read someone saying its a "cheap Micron brand (?)"
Is this something i should worry, how bad is this compared to the Hynix version?
I also read multiple comments of people saying this memory would not run at these speed.
They labeled on the document "Speed 5200" will it indeed run at 5200, or is it too much expect it will reach this speed by just enabling XMP?
This machine is for emulation of virtual machines, ill be using Windows 11, my software rely heavily on WINAPI as do the applications im running on graphics acceleration, i'm not using Linux, or running any kind of games.
It will perform "considerable" disk I/O, constantly (re)starting applications, creating/cloning machines, rebooting, etc, not something absurd but far from what a "casual" user perform.
I have no budget for a Threadripper or HEDT yet, old xeon server also would not fit on my use case.
My current build is a 14700k, RX 7600XT 16gb, 64GB ram.
Which this same mentioned use case, i have been able to run 62 VM’s, its using 100% ram, ~90% vram, ~50% gpu, ~80% cpu.
My new build:
CPU: 9950X
MB: ???
RAM: 192GB 5200Mhz
GPU: 2X Arc 16GB or 2X RX 7600 XT 16GB
SSD: 2X Corsair MP700 PRO 1TB
Cooler: Artic Liquid III 360
I need a lot of VRAM, gpu use is medium, 2TB is enough for me my machines they use like 4~7GB.
I'm also thinking on getting two gen 5 of 1TB instead of one of 2TB and try raid 0 on it, would it be worth? (losing data is not a concern and i could format/disable it at anytime).
I'm looking for recommendations about the motherboard, i have found these:
GIGABYTE X870E AORUS PRO ICE $390
ASUS ROG Strix X870-A $357
ASUS ROG STRIX X870E-E $508
(these prices are after tax)
The last one is so expensive i would like to avoid it unless really necessary.
What best motherboard for this use case?
42,750 (6.69/day)
My build:
Have you read your motherboard manual about ram configurations?
dgianstefani
TPU Proofreader
5,123 (2.00/day)
Swansea, Wales
System Name Silent/X1 Yoga
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader/1185 G7
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front, LINKUP Ultra PCIe 4.0 x16 white
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper V3 Pro 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape, Razer Atlas
Benchmark Scores Legendary
Any of the ASUS boards with Nitropath.
Though I'd still be skeptical of being able to run even at 5200 MT with so much memory, you'll likely be forced to run at something like 4800 MT or 3600 MT.
To be honest I'd be strongly considering CUDIMMs, which at the moment are only supported by Arrow Lake.
Official support for 4 slots is 3600 MT.
2,944 (2.07/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
this will be more of a IMC problem rather than motherboard.
if you actually NEED 192GB, performance should not be relevant and the only priority is stability (fully verifying 192GB with TM5, VT3 and Karhu takes at least ~5-6 Days)
start with DDR5 4400 without EXPO or look for JEDEC Timings for 4400 Kits to dial in.
ir_cow
4,588 (0.77/day)
USA
For what I gathered Nitropath is just to help 2 DIMMs in a 4 slot MB.
CUDIMM won't help unless it's a signal integrity issue. 4x2R is 100% limited by the CPU IMC.
Either case the op is going to get lucky and 5200 works or is stuck at 3600 to 4800 speeds most likely.
Best motherboard? Eh I don't think it matters at that speed.
3,365 (1.09/day)
Cooling Noctua NH-D15 Chromax
Memory 32GB DDR5 6000 CL30
Case Thermaltake Core X9
Mouse PMM P-305
Keyboard Wooting HE60
VR HMD Valve Index
Software Win 10
Yes and typically the benefit is only seen with higher frequencies. Unoccupied DIMM slots can interfere with neighboring slots at higher frequencies.
ir_cow
4,588 (0.77/day)
USA
As for the memory manufacturer. Also does not matter at these lower speeds. You won't be overclocking past the XMP/EXPO profile or adjusting the timings. At least I hope you wouldn't because that would just add more complications and more room to have system crashes. You are clearly using the PC for work, but still trying to be in a budget.
79 (0.01/day)
System Name Blah
Processor Ryzen 7950x
Motherboard Asrock X670E Taichi
Cooling BLACK ICE SR2 480,EKWB Quantum Magnitude AM4,D5 Pump,17 CORSAIR SP120 RGB ELITE
Memory 32Gig Gskill 6000 DDR5
Video Card(s) MSI RTX 4090 LIQUID X 24G
Storage Optane 900P 480GB,2x SX8200 2TB ,SAM 980 PRO 2TB,2xSAM 860 EVO 1TB,SAM 870 EVO 4TB,SAM 860 EVO 2TB
Display(s) Samsung Odyssey Neo G9 57
Case CORSAIR 7000X
Audio Device(s) Realtek ALC4082
Power Supply CORSAIR HX1500I
Mouse Corsair Harpoon
Keyboard Corsair Strafe MkII
VR HMD Oculus
I can vouch for the Asus x870e hero....
However the cost is rather high, however the memory you specify is on the Qualified Ram list:
CORSAIR CMK192GX5M4B5200C38(Ver 3.53.02) 4x 48GBXMP52005200DSMicron 38-38-38-841.251,2,4
