Best PSU-s with passive cooling
921 (0.15/day)
Hungary / Budapest
System Name Kincsem
Processor AMD Ryzen 9 9950X
Motherboard ASUS ProArt X870E-CREATOR WIFI
Cooling Be Quiet Dark Rock Pro 5
Memory Kingston Fury KF560C32RSK2-96 (2×48GB 6GHz)
Video Card(s) Sapphire AMD RX 7900 XT Pulse
Storage Samsung 970PRO 500GB + Samsung 980PRO 2TB + FURY Renegade 2TB+ Adata 2TB + WD Ultrastar HC550 16TB
Display(s) Acer QHD 27"@144Hz 1ms + UHD 27"@60Hz
Case Cooler Master CM 690 III
Power Supply Seasonic 1300W 80+ Gold Prime
Keyboard HyperX Alloy Elite RGB
Software Windows 10-64
Benchmark Scores https://valid.x86.fr/ilvewh https://valid.x86.fr/4d8n02 X570 https://www.techpowerup.com/gpuz/g46uc
Hello Forum,
I am considering to get a passive cooled PSU and I know about the SEASONIC Prime Fanless PX/TX series,
Both of those would be fantastic for my low power home server. But maybe a bit pricy...
But is there any other brand producing a passive PSU with might good for 24/7/365 duty paired with 150~200W draw.
Thank You!
127 (0.05/day)
Dubai, UAE
System Name The Nomad
Processor Ryzen 5 5600
Motherboard Asrock B550M Phantom Gaming ITX
Cooling Arctic Liquid Freezer II 240
Memory 2x8GB Patriot 4400MHz DDR4
Video Card(s) MSI RX 5700 Evoke OC w/ Arctic Accelero Xtreme IV
Storage 1TB A-Data SX8200Pro, 4TB WD Blue HDD
Display(s) Gigabyte M27Q 27"
Case Coolermaster NR200P
Audio Device(s) Epos H6 Pro
Power Supply Corsair SF600
Keyboard Logitech G815
iirc Silverstone offered some good passive PSUs in the past.
Also, may I ask why do you need a passively cooled one? most power supplies are whisper quiet (especially at low load levels). Some have a Fan-Off mode when load doesn't meet a certain threshold -generally 15-20%- so If you get a high wattage active one it would effectively work as passively cooled for your use case.
13,088 (1.96/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
I agree with Muaadib. There are many PSUs with noise levels well below ambient. And many that operate with the fan off the vast majority of the time. EVGA, for example, has several PSUs that includes their ECO mode feature. The fans will remain off until the PSU's temperature crosses over the 55°C threshold. Note 55°C is fairly warm. Also, when the fan does start to turn, it runs at a low (thus extremely quiet) RPM and only ramps up in speed if the temperature keeps rising.
I know with my EVGA, when the fans starts to spin, I cannot hear it. I have to put my hand back there and "feel" the warm air exhausting out the back.
Totally passive PSUs are great where total silence is a requirement - such as with HTPCs (home theater PCs). But for a server? It really does not make sense.
Also, of utmost importance when dealing with passive cooling is the computer case itself. HTPC cases are designed for passive cooling. Normal computer cases are not.
921 (0.15/day)
Hungary / Budapest
System Name Kincsem
@Bill_Bright I agree too, if you check my config you can see that I have a PSU with that feature!
I am just curious if there is a PSU with passive cooling in a somewhat cheaper range that stuff you talked about.
Most likely not, but someone might give me a great option!
286 (0.16/day)
Silverstone still have a passive series, both SFX and ATX, I think.
Are you sure it's really 150-200 watt? That's actually pretty darn high for your average low power home server! (there's a big thread on tweakers.net, it's up to part 4)
921 (0.15/day)
Hungary / Budapest
System Name Kincsem
@Tetras I never really measured, it might be as low as 100W
But I want it to be a future proof solution so I calculate with a massive overhead.
It is a ASUS E35M1-M Pro with two SATA HDD-s as of now.
Some day I will change it up for a newer mainboard with something faster, features like 10Gbps ethernet and fast CPU for RAID5, which also means more HDDs.
Will see what the future hold, but I did not see a board to switch from the E35M1-M Pro yet. Would be happy to see some similar mini ATX sized with two m.2 slots and an integrated CPU similarly fast as the AMD Ryzen 5 3400G (but with only 4 threads) and of course with a massive passive heatsink.
286 (0.16/day)
Ahh, Anandtech measured it pretty low, though SATA HDDs can take a fair bit, especially older ones. If it's really that low, I think it would strongly support going semi-passive as suggested above. It would give you so many more options and it wouldn't have to be too expensive. If you're interested, this is one of the best threads I've seen, even taking into account servethehome and NAS forums I've browsed: https://gathering.tweakers.net/forum/list_messages/2096876 (links to earlier parts in the 1st post)
21,432 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
If you are only drawing <200W, you might look at DC-DC options with a 12V power brick. I know such options exist for your wattage range and they are always passive with no fan. They are also much less complex than AC-DC PSUs and as such quality/brand matters a bit less (there isn't much outright garbage, as far as wattage ratings are concerned, the brick would matter more).
Note efficiency with this option may not be as high. It still should be within 80plus white or bronze I'd picture though with a decent brick
An example: Would need an appropriately sized/ wattage rated 12V power brick, of course:
5,070 (3.80/day)
Colorado, U.S.A.
Software Windows 11 Home
I would argue that fan-less power supplies actually reply on the computer's fan and could not operate at full load in still air.
921 (0.15/day)
Hungary / Budapest
System Name Kincsem
@R-T-B Interesting option, like the idea, but I will take only "standard" PC parts
@Andy Shiekh good point!
Looks like it shall be something like the SEASONIC Prime GX, PX or TX line, or similar!
21,432 (3.40/day)
System Name Pioneer
That's fair and valid. Just making sure you were aware of that option.
1,687 (0.88/day)
Processor 7800X3D 2x16GB CO
Motherboard Asrock B650m HDV
Cooling Peerless Assassin SE
Memory 2x16GB DR A-die@6000c30 tuned
Video Card(s) Asus 4070 dual OC 2610@915mv
Storage WD blue 1TB nvme
Case Corsair D4000 Airflow
Power Supply EVGA GQ 650W
Software Windows 10 home 64
Benchmark Scores Superposition 8k 5267 Aida64 58.5ns
My evga GQ 650W has fan off up to 200-250W if eco mode is enabled.
921 (0.15/day)
Hungary / Budapest
System Name Kincsem
@Taraquin This one might be really good, half the price of the Seasonic!
Did not know about his product line!
1,687 (0.88/day)
It's related to temp though, if ambient is higher fan will kick at lower consumption. Eco mode only enables fan if temp is above 50C, my ambient is around 20C and while mining consumption from wall is 220-230W and fan don't kick in then.
12,337 (5.79/day)
Midlands, UK
System Name Nebulon B
Cooling be quiet! Dark Rock 4
Mouse Logitech MX Master 2S
Keyboard Logitech G413 SE
Fanless PC components usually require good case airflow, which (unless you have some very high quality case fans) defeats their purpose. I agree with the comments above saying that a whisper quiet, but actively cooled PSU would be a better choice - especially for a server that you probably run 24/7.
