Best single slot Graphics card for general use?
SBBusboy
7 (0.01/day)
California, USA
I have an older Dell XPS 8300 with an NVIDIA GT 530 OEM graphics card. Due to space considerations, I need to replace it with a a single-slot graphics card. Can anyone recommend the best single-slot replacement? I don't play games but I do watch movies and videos, so I don't need outrageous power, but I do need a solid general purpose card. I have a monitor with an HDMI connection and a 400W power supply. Any help appreciated.
Deleted member 202104
It's probably the absolute worst time in history (not exaggerating) to buy a video card.
A GT 1030 is going to be about 3x the performance of your 530, but look to be paying 2-3x what it's worth. A quick check shows if you can find one in stock it's $150-$225.
When it came out in 2017 it was $79.
9,781 (2.24/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
i got my nephew an optiplex SFF from work years back as his first real PC. it was a blessing & a curse, since it performed well, but had little to no upgrade options.
i had to get clever with upgrades, so i grabbed a GTX 750ti for his first GPU upgrade, & a GTX 1050ti for his second GPU upgrade.
both were Low profile, & require no power other than what is provided by the PCI lane. im sure there are newer options since this was a few years back, but the same idea will work now.
i hope this helps
820 (0.46/day)
Taiwan
Processor i5-9600K
Cooling Scythe Mugen 5S
Display(s) Gigabyte M32Q
Case Antec DF700 Flux
Audio Device(s) Edifier C3X
Mouse Razer Basilisk V2
Keyboard Ducky ONE 2 Horizon
A 1030 should be more than enough for your purpose
6 (0.00/day)
Sol 3 (Earth) or Upstate NY
Agreed a 10xx series nvidia 1030 2g ram will run great.
SBBusboy
7 (0.01/day)
California, USA
Thanks for the response. I found a ZOTAC low profile that will fit, but it's too expensive. I will wait for the prices to come down.
i hope this helps
Thanks for the reply...
SBBusboy
7 (0.01/day)
California, USA
I went to the ZOTAC store and found an open box GT 1030 low profile model for $119 w/free shipping. I grabbed it since the fan on my old card is making a little noise and I don't trust it. Price at Amazon was $199.99 for a refurb. Yesterday morning I was looking at passive cooling models which were readily available and by the afternoon they had all disappeared and only the models with a fan were available (probably just as well - I'm not sure if there is enough air circulation in my case for a passive cooler). The 1030 gets 301% performance over the 530.
Thanks for the reply. See my response to weekendgeek...
Good find at the Zotac site! I forgot all about searching direct from the manufacturer.
I would agree that the fan version was the better choice. Without some directed airflow over the card they can run really warm.
Happy computing! :)
4,980 (3.86/day)
Colorado, U.S.A.
Software Windows 11 Home
I am also delighted with the GT 1030, but the fanless version; one less thing to worry about and runs games like Far Cry 4.
I just realized you said single slot... the heatsink can take up the second slot.
4,980 (3.86/day)
Colorado, U.S.A.
It is VERY important to get the GDDR5 version of the GT 1030 and NOT the DDR4 version.
tabascosauz
8,025 (2.37/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
May I ask why you need a single slot card specifically? I had a XPS 8500, same chassis as the 8300, it takes any dual slot full length high end cards just fine. Don't see why any 2-slot low profile 1030 wouldn't work.
You Sir don't know what you are talking about
Don't engage with a troll, user's only been here for 15 min and every single post he's made is for blatant trolling
SBBusboy
7 (0.01/day)
California, USA
All my PCIe slots are full, no room for a dual-slot card unless I want to remove something else, like the USB3 card or my sound card.
4,980 (3.86/day)
Colorado, U.S.A.
Pity as I find the small fans on video cards don't always last so long, but the one you ordered seems to be GDDR5 so I think you will be impressed by its performance.
SBBusboy
7 (0.01/day)
California, USA
It's rated at 300% performance above my current card, and my current card suits my limited needs, so all is good...
qubit
Overclocked quantum bit
17,865 (2.91/day)
Quantum Well UK
System Name Quantumville™
Cooling Noctua NH-D14
Case Cooler Master HAF 922
Power Supply Corsair AX1600i
Keyboard Yes
Yup, as the others have said, the GT 1030 will work great if you can find one at a reasonable price.
Check out the gaming benchmarks for my one from my showdown review linked to in my siggy. It's surprisingly good for such a tiny card. :) It plays videos just fine of course and has the all important HDMI socket.
Ruru
S.T.A.R.S.
12,323 (2.86/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3466
Storage 256+240+128+480+2x1TB SSDs + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p144
Audio Device(s) Corsair HS35
VR HMD Oculus Rift CV1
Here's a vote for GT 1030 as well. I had one with i7-2600K on my previous 2nd rig, it ran even Crysis more than fine at 1080p high.
SBBusboy
7 (0.01/day)
California, USA
Received the ZOTAC GT 1030 low profile, installed it and loaded the gaming drivers from NVIDIA web site. It's working well. The fan is turning very slowly so I think the heatsink is actually doing most of the work. Nice and quiet. I hope it and the new drivers will solve the "DPC WATCHDOG VIOLATION" BSODs I was getting in ZOOM meetings...
i7-2600 is exactly what I have in my rig. The 1030 is working well; as I told weekendgeek, I hope it will solve the problems I was having during ZOOM meetings.
Ruru
S.T.A.R.S.
12,323 (2.86/day)
Jyväskylä, Finland
I had 2600K @ 4.5 and the 1030 overclocked that it boosted to about 2000MHz (and of course the memory overclocked to its limits), but I don't think that it makes that huge of a difference compared to your system.
