Best thermal compound/paste for cooling CPU
Sayyid
2 (0.00/day)
Hello there guys. I need your help finding the best thermal compound for an Intel i7 processor with a copper heatsink.
After making some search on google I found this article that suggests Gelid Solutions GC-Extreme to be the best thermal paste although Coollaboratory Liquid Ultra seems to perform better if properly applied.
My question is: which one do you advise me to go with? is the 4C Degree difference between those two compounds make any remarkable difference if I want to use my PC especially for video editing and 3D graphics design?
Any help is appreciated.
Kursah
Super Moderator
14,734 (2.20/day)
Missoula, MT, USA
System Name Kursah's Gaming Rig 2018 (2022 Upgrade) - Ryzen+ Edition | Gaming Laptop (Lenovo Legion 5i Pro 2022)
Processor R7 5800X @ Stock | i7 12700H @ Stock
Motherboard Asus ROG Strix X370-F Gaming BIOS 6203| Legion 5i Pro NM-E231
Cooling Noctua NH-U14S Push-Pull + NT-H1 | Stock Cooling
Memory TEAMGROUP T-Force Vulcan Z 32GB (2x16) DDR4 4000 @ 3600 18-20-20-42 1.35v | 32GB DDR5 4800 (2x16)
Video Card(s) Palit GeForce RTX 4070 JetStream 12GB | CPU-based Intel Iris XE + RTX 3070 8GB 150W
Storage 4TB SP UD90 NVME, 960GB SATA SSD, 2TB HDD | 1TB Samsung OEM NVME SSD + 4TB Crucial P3 Plus NVME SSD
Display(s) Acer 28" 4K VG280K x2 | 16" 2560x1600 built-in
Case Corsair 600C - Stock Fans on Low | Stock Metal/Plastic
Audio Device(s) Aune T1 mk1 > AKG K553 Pro + JVC HA-RX 700 (Equalizer APO + PeaceUI) | Bluetooth Earbuds (BX29)
Power Supply EVGA 750G2 Modular + APC Back-UPS Pro 1500 | 300W OEM (heavy use) or Lenovo Legion C135W GAN (light)
Mouse Logitech G502 | Logitech M330
Keyboard HyperX Alloy Core RGB | Built in Keyboard (Lenovo laptop KB FTW)
Software Windows 11 Pro x64 | Windows 11 Home x64
I would be more concerned about the rest of your system rather than the thermal paste between the CPU and Cooler. I use the Noctua stuff that comes with the cooler and AC MX4, and both work great and are easy to work with and clean.
That said, if the rest of your system is good and well tuned for cooling performance within your needs, I would go with GC-Extreme if I had to choose between those two because it should be an easier application.
Do you really need to eek out those extra few degrees of cooling or is it something you want to do?
3,516 (0.49/day)
System Name Red Matter 2
Processor Ryzen 5600X
Motherboard X470 Gaming Pro Carbon
Cooling Water is Masterliquid 240 Pro
Memory GeiL EVO X 3600mhz 32g also G.Skill Ripjaw series 5 4x8 3600mhz as backup lol
Video Card(s) Gigabyte Gaming Radeon RX 6800
Storage EVO 860. Rocket Q M.2 SSD WD Blue M.2 SSD Seagate Firecuda 2tb storage.
Display(s) ASUS ROG Swift PG32VQ
Case Phantek P400 Glass
Audio Device(s) EVGA NU Audio
Power Supply EVGA G3 850
Mouse Roccat Military/ Razer Deathadder V2
Keyboard Razer Chroma
Software W10
Gelid Solutions GC-Extreme will allow you to edit more VPM (video per minute) than just about any other solution.
21,723 (3.40/day)
Olympia, WA
System Name Pioneer
Processor Ryzen 9 9950X
Case Thermaltake Core X31
I have a bulk tube of the AC MX2 I've been using for a bit now, good temps, easy to apply, and a great price. Then again, if you plan to only apply once and forget, it might be worth splurging on something a bit more expensive. I went with it for cost effectiveness and longevity on my client builds...
9,916 (1.83/day)
Jakarta, Indonesia
System Name micropage7
Processor Intel Xeon X3470
Cooling Enermax ETS-T40F
Case Icute Super 18
Software Win 7 64-bit
Benchmark Scores Classified
mx2
but you need better contact pressure and maybe some lapping it to get better result
21,723 (3.40/day)
Olympia, WA
System Name Pioneer
mx2
I'm using a socket LGA-2011 cooler on a socket LGA-2011v3 build,. so my contact pressure is already pretty tight. Don't know if that'll be the same case for this build however.
9,916 (1.83/day)
Jakarta, Indonesia
Case Icute Super 18
some people just think that all that they need just a good paste but sometimes forgot about how good their contact area, contact pressure, their airflow or they dont clean their old paste properly
Ebo
778 (0.18/day)
Nykoebing Mors, Denmark
System Name the little fart
Processor AMD Ryzen 2600X
Motherboard MSI x470 gaming plus
Cooling Noctua NH-C14S
Memory 16 GB G.Skill Ripjaw 2400Mhz DDR 4
Video Card(s) Sapphire RX Vega 56 Pulse
Storage 1 Crucial MX100 512GB SSD,1 Crucial MX500 2TB SSD, 1 1,5TB WD Black Caviar, 1 4TB WD RED HD
Display(s) IIyama XUB2792QSU IPS 2560x1440
Case White Lian-Li PC-011 Dynamic
Audio Device(s) Asus Xonar SE pci-e card
Power Supply Thermaltake DPS G 1050 watt Digital PSU
Mouse Steelseries Sensei
Keyboard Corsair K70
Software windows 10 64 pro bit
Ive used the IC7 Diamond for years and been happy about it.
When i built my new system, I switched to Polimatech PK-3 and it gains 1 degree cencius over the IC7 in use, so it works for me.
The Gelid should be the top of the pop, for now.
9,916 (1.83/day)
Jakarta, Indonesia
Case Icute Super 18
ic diamond? i may skip that since from some user ic7 gets kinda abrasive to the cooler
gelid especially for now get easier to find here
Toothless
Tech, Games, and TPU!
9,738 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x24 Klevv Cras V RGB
Power Supply Corsair HX850
Mouse Corsair Harpoon
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
How does thermal paste make video edits go faster? Unless the last paste is letting the chip hit the throttle points, I question your post.
3,685 (0.85/day)
GMT +2
System Name Red Radiance l under construction
Processor 5800x
Motherboard x470 taichi
Cooling stock wrath
Memory TridentZ Neo rgb 3600mhz (2x8 kit)
Video Card(s) Sapphire Vega 64 nitro+
Storage 970 evo nvme
Display(s) lc27g75tq
Case tt core x5 tge
Audio Device(s) sennheiser's pc323d usb soundcard
Power Supply corsair AX860i
Mouse roccat burst pro
Keyboard roccat ryos mk fx
Software windows 10
irony?
i question your sense of humor :p
Toothless
9,738 (2.45/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
rtwjunkie
PC Gaming Enthusiast
14,025 (2.32/day)
Louisiana
Processor Core i9-9900k
Welcome to TPU!
There are multiple threads here on this topic. Buy whichever you think is the best at the price you are willing to afford. I use MX-4 for what I feel is the best blend of efficiency and cost. Others have their favorites. Some undoubtedly will give a degree or two improvement.
But really, if you aren't overheating or close to it, it does not matter. The only purpose is to provided an even surface of contact between cpu and the heatsink so that heat transfers to the heatsink.
FreedomEclipse
~Technological Technocrat~
24,423 (3.76/day)
Hong Kong
System Name WorkInProgress
Processor AMD 7800X3D
Display(s) LG GP850-B
Mouse Logitech G502 X
Software Windows 11 Home
Benchmark Scores ლ(ಠ益ಠ)ლ
cant go wrong with MX-4 or PK-3 which is slightly more expensive but better than MX-4. weather or not its worth the premium for an extra 2-3'c here and there is down to your own decision
4,666 (0.70/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
I wouldn't trust that website in the slightest. They've done a total of five "reviews" and did zero of the testing themselves, instead just copying the work of others. Four of the five are just a copy of the manufacturer's description, not testing.
I haven't been following thermal goop too closely, but I'm pretty sure those are more for replacing the TIM between the bare die and heatshield on a delidded proc. I don't think they're particularly inexpensive.
Real pros use mayonnaise. It's on par with the Gelid GC-Extreme, costs a lot less, and is a lot easier to find.
(^ Seriously, click the link. It's a roundup of thermal pastes. Don't use mayonnaise though.)
+1 to the Polimatech PK-3. Outperforms the Gelid, on par with the Coollab Liquid Ultra, and it's cheap as chips (relatively). HardwareSecrets' tests show that AS5 still beats most everything though.
The IC7 is abrasive, isn't it?
Also +1. There are a lot of options that perform pretty well. I'd just start at the top and work your way down until you find something moderately inexpensive.
1,192 (0.28/day)
Processor 11700
Motherboard TUF z590
Memory G.Skill 32gb 3600mhz
Video Card(s) ROG Vega 56
Case Deepcool
Power Supply RM 850
Welcome! Noctua has never let me down so :toast:
1 (0.00/day)
Singapore
System Name Floored
Processor Intel i7 4790K Devil's Canyon [Delidded]
Motherboard Gigabyte GA-Z97X Gaming 7 [rev 1.0]
Memory 2 x 8GB Kingston Valueram 1600MHz CL 11
Video Card(s) MSI R9 290 Gaming 4G
Storage Crucial M500 480GB, Western Digital 3TB Green
Display(s) Philips 240B1CB 1920 x 1200
Case Corsair Obsidian 750D
Power Supply Seasonic X750 KVM
Mouse Zowie FK1
Keyboard Filco Majestouch 2 Ninja Tenkeyless
As the others have stated, either one of the other pastes should work fine such as mx-4, nt-h1. I myself use gelid gc extreme in my setup and i would say it performs on par with the others,maybe even slightly better but temp differences are nothing to rave about. One caution about CLU. I used it recently between my die and IHS and even when i reapplied it a day later, i realised that it's stained the area on the IHS that came into contact with it. And i could see the stained area and feel the difference when cleaning it off.
peche
Thermaltake fanboy
6,709 (1.79/day)
San Jose, Costa Rica
System Name Athenna
Keyboard Tt eSports KNUCKER
Software windows 10x64Pro
mx2
agreed....
i may agreed this too...
a 1 or 2 C difference is never wothfull for paying some extra $'s....
:shadedshu:
just no ...never use mayo dude....
Welcome to TPU!
welcome to TPU!
rtwjunkie say almost what is tpu ...
here we love Arctic MX 4, Coolermaster Hyper 212EVO and also badgers... @CAPSLOCKSTUCK can explain the reuth about badgers...
i may told you something about arctic silver... real pain in the ass... curing time... several myths about aplication methods.... well i trully recomend ya arctic cooling mx 4 for the win ... also delidding your processor you can have a real drop on temps if you are runing 3rd or 4th intel i7's ...
@Knoxx29 im i right?
:laugh:
4,666 (0.70/day)
Washington, US
System Name Rainbow
:shadedshu:
Makes your CPU cold AND delicious! :D
Yes, yes. Of course I know you never want to use mayo as your TIM.
Everyone would try to eat it!
peche
Thermaltake fanboy
6,709 (1.79/day)
System Name Athenna
  • Like
Reactions: xvi
12,333 (2.24/day)
Oregon
Keyboard EVGA / Logitech K400
Any quality CPU thermal compound is fine. There isn't 4c deference from the best to the worst let alone Gelid Solutions and Coollaboratory Liquid Ultra. Your information is wrong about that.
Micropage7 has some good advice. There are other things that lead to temp problems other than paste. Check the mounting surfaces and cooler
Good article
http://www.tomshardware.com/reviews/thermal-paste-heat-sink-heat-spreader,3600.html
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616.html
I stand correct. The best to the worst thermal compounds is 4.2c .So thermal compound choice make very little difference. Focus on more important issues
http://www.tomshardware.com/reviews/thermal-paste-performance-benchmark,3616-17.html
82 (0.02/day)
United States
Video Card(s) RTX 4090
You can never go wrong with a small tube of Arctic Silver 5
FreedomEclipse
24,423 (3.76/day)
Hong Kong
that depends. Sometimes its worth trying out something new. you can never beat MX-4 on price|performance a 20g tube is just so cheap
19,375 (3.51/day)
TL;DR... unless you are after that last degree or two, nearly any solution will be fine. A degree or two isn't generally worth the huge (% wise) difference in cost. I mean it is only a couple of dollars, but you are paying 30% more for a degree or two... Not worth it (to me).
+1 to jetster and Micro!
