Best thermal pastes in 2021 ?
Kaliphtan
6 (0.00/day)
Hello guys,
I'm pretty noob in cpu cooling paste, there are a lot of thermal pastes, like a lot ! I'm using NT-H1 for my i5 9600k and it's getting "old", trying to cool it further down, so I'm looking for a new one.
All the benchmarks on the internet aren't good, most of them are not the same benchmark condition so the temperatures from a video to another are different.
I also saw that Kryonaut paste scratchs the aluminium chipset/ maybe copper on cooler, it's still true today ? And the main question is what's the best thermal pastes in 2021 ?
Thanks in advance
18,350 (2.71/day)
Memory 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 / 8GB DDR4 HyperX CL13
There was a bad batch in the past.
There is a new version:
Thermal Grizzly Kryonaut Extreme
Kaliphtan
6 (0.00/day)
Thanks for your answer, are there any syringe version ? I'm looking on Amazon, only the normal version is here.
18,350 (2.71/day)
It isn't cheap though...
freeagent
7,940 (3.73/day)
Winnipeg, Canada
Processor AMD R9 5900X
Display(s) LG 50UP7100
VR HMD Oculus 3
Software Yes
Benchmark Scores Yes
Thermalright TFX is rated slightly higher, and is cheaper, but not cheap.
9,340 (5.81/day)
Louisiana
Keyboard G710+x3
Thermal grizzly is always overpriced and overrated hydronaut is the only one never said to scratch anything.
NT-H1 I use or newer NT-H2 although I don't like it little too wet and dries too fast
MX-4 2019 and they do have a new version too
4,152 (0.87/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
NT-H1 is a very good thermal paste. Even if you use thermal grizzly the difference would likely be minimal during gaming.
8,312 (3.20/day)
System Name Best AMD Computer
Processor AMD 7900X3D
Cooling In Win SR36
Display(s) GIGABYTE FV43U
Case Corsair 7000D Airflow
Power Supply Deepcool 1000M
Keyboard Logitech G510
752 (0.50/day)
System Name Main PC
Processor AMD Ryzen 9 5950X
Motherboard ASUS X570 Crosshair VIII Hero (Wi-Fi)
Cooling EKWB X570 VIII Hero Monoblock, 2x XD5, Heatkiller IV SB block for chipset,Alphacool 3090 Strix block
Memory 4x16GB 3200-14-14-14-34 G.Skill Trident RGB (OC: 3600-14-14-14-28)
Video Card(s) ASUS RTX 3090 Strix OC
Storage 500GB+500GB SSD RAID0, Fusion IoDrive2 1.2TB, Huawei HSSD 2TB, 11TB on server used for steam
Display(s) Dell LG CX48 (custom res: 3840x1620@120Hz) + Acer XB271HU 2560x1440@144Hz
Case Corsair 1000D
Audio Device(s) Sennheiser HD599, Blue Yeti
Power Supply Corsair RM1000i
Keyboard Corsair Strafe RGB MK2
Software Windows 10 Pro 20H2
+1 for Noctua's NT-H1. Been using it for years.
FreedomEclipse
~Technological Technocrat~
23,576 (3.74/day)
London,UK
Display(s) LG GP850-B
Case Corsair 760T (White)
Power Supply Corsair AX760
Mouse Logitech G900
Benchmark Scores (ノಠ益ಠ)ノ彡┻━┻
Wasn't there an issue with kryonaut where they had pretty big particles that were causing pitting on coolers and CPUs?
18,350 (2.71/day)
3,250 (1.16/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
kingpin KPx should be the best paste for now.
bug
13,454 (4.02/day)
Processor Intel i5-12600k
Motherboard Asus H670 TUF
Cooling Arctic Freezer 34
Case Raijintek Thetis
Keyboard G.Skill KM780R
Software Arch Linux + Win10
Hello guys,
Thanks in advance
Changing paste will not lower the temps significantly.
Imho, applying the paste right is more important than picking the best paste.
8,312 (3.20/day)
Cooling In Win SR36
I changed from NTH1 to NTH2 and it dropped my temps by about 4 degrees C. As far as i am concerned Noctua's NTH2 is the best easily acccessible paste.
freeagent
7,940 (3.73/day)
Winnipeg, Canada
VR HMD Oculus 3
Software Yes
Thermalright TF8 is very easy to use. It was previously my favorite. I only bought TFX because I couldn't get TF8 for some reason.. couldn't be shipped to me from the U.S. So I bought my TFX.. from the US and I'm pretty sure it was the same seller lol.. TFX is a lot thicker, but the difference between the two is noticeable. I'm having a hard time deciding between a 12g tube of TF8 or a 6g tube of TFX for the same price..
I am a massive Thermalright fanboy though, so take it for what you will.. :laugh:
:D
dgianstefani
TPU Proofreader
4,677 (1.96/day)
Swansea, Wales
System Name Silent
Processor Ryzen 7800X3D @ 5.15ghz BCLK OC, TG AM5 High Performance Heatspreader
Motherboard ASUS ROG Strix X670E-I, chipset fans removed
Cooling Optimus Block, HWLABS Copper 240/40 + 240/30, D5/Res, 4x Noctua A12x25, 2x A4x10, Mayhems Ultra Pure
Memory 32 GB Dominator Platinum 6150 MT 26-36-36-48, 56.6ns AIDA, 2050 FCLK, 160 ns tRFC, active cooled
Display(s) 32" 240 Hz 1440p Samsung G7, 31.5" 165 Hz 1440p LG NanoIPS Ultragear
Case Sliger SM570 CNC Aluminium 13-Litre, 3D printed feet, custom front panel pump/res combo
Audio Device(s) Audeze Maxwell Ultraviolet, Razer Nommo Pro
Power Supply SF750 Plat, full transparent custom cables, Sentinel Pro 1500 Online Double Conversion UPS w/Noctua
Mouse Razer Viper Pro V2 8 KHz Mercury White w/Tiger Ice Skates & Pulsar Supergrip tape
Keyboard Wooting 60HE+ module, TOFU Redux Burgundy w/brass weight, Prismcaps White, Jellykey, lubed/modded
Software Windows 10 IoT Enterprise LTSC 19044.4046
Benchmark Scores Legendary
There's basically 3 that are worth paying for if you don't want to use the preapplied paste or stock stuff supplied with cooler.
NT-H2. Cryonaut/Cryonaut Extreme. Conductonaut.
These are ranked in order of performance.
Conductonaut has some preconditions. No aluminium. If used on bare copper you need to reapply since it will alloy. Nickel plated is fine.
NT-H2 Set and forget. Cryonaut/Extreme - best non conductive paste but needs reapplying every 3-5 years ideally. Conductonaut - Best performance by huge factor but you need to be careful and precise during application.
2,960 (0.87/day)
Long Island
The formulations over the years haven't changed significantly for the most part but every now and then a new player shakes things up ..... Benchmarkreviews.com had always done the most exhaustive testing and their test results were always "the benchmark), pun intended, of TIM testing and their "How to Apply" articles were great, showing that there was no "best" method .... that the method used should depend on the type of cooler used. Unfortunately, when the site was updated, these articles were lost. Each was oft referenced here on TPU as a "go to" source over the years. Some brands are just OEM's from other suppliers and others are knockoffs of lesser value.
The two top performers were AS5 and Shin Etsu G751. AS5 is capacative (scary if ya get on contacts) and has significant curing time (about 7 weeks @ 3 hours a week) both of which are detailed on AS5's web site leaving Shin Etsu as the best choice for CPUs, and it was also half the price everywhere (typically $3.99) of AS5 ... until recently. Can still be had for $4-5 if ya look around.. Later the liquid metal type became available but those come with significant risks and should not be used by a novice. Thermal Grizzly's The 12.5 W/mK Kryonaut arrived on the scene and 'took the title" by a significant margin. But it was expensive at about $15.... It has since dropped down to the typical $7-8 range of most everyone else. Later Noctua released NT-H2 which matched Thermal Grizzlies 12.5 W/mK rating ..... Kryonaut Extreme came later and upped the ante at 14.2 W/mK
But the thermal performance rating is not the be all and end all of what you need to be concerned about ... workability also comes into play ... on a GFX card for example where you may have up to 25 or so application points wurg GPU, memory and VRMs, potentially warranting application on both the block and back plate. Where longer viability is needed, Gelid Extreme is a great go to source.
1,174 (0.70/day)
Loose in space
System Name "The black one in the dining room" / "The Latest One"
Processor Intel Xeon E5 2683 V4 16c/32t / i7 14700K @5.8GHz
Motherboard Asus X99 Deluxe / ASRock Z790 Steel Legend WiFi
Cooling Arctic Liquid Freezer II 240 w/4 Silverstone FM121 fans / Arctic LF II 280 w Silverstone FHP141's
Memory 64GB G.Skill Ripjaws V DDR4 2400 (8x8) / 96GB G.Skill Trident Z5 DDR5 6400
Video Card(s) EVGA RTX 1080 Ti FTW3 / Asus Tuff OC 4090 24GB
Storage Samsung 970 Evo Plus, 1TB Samsung 860, 4 Western Digital 2TB / 1tb, SK hynix P41 Platinum 2tb
Display(s) 43" Samsung 8000 series 4K / 50" Vizio M-series 4K
Case Modded Corsair Carbide 500R / Modded Corsair Graphite 780 T
Audio Device(s) Asus Xonar Essence STX II/ Asus Xonar Essence STX
Mouse Logitech Performance MX, Microsoft Intellimouse Optical 3.0
Keyboard Logitech K750 Solar, Logitech K800
Software Win 10 Enterprise LTSC 2021 IoT / Win 11 Enterprise IoT LTSC
Benchmark Scores https://www.passmark.com/baselines/V11/display.php?id=202122048229
Gelid CG Extreme or MX-4 are what I use.
2,659 (0.69/day)
Alabama
Processor Ryzen 2700X
Cooling Scythe Big Shuriken 3
Memory C.R.S.
Video Card(s) Radeon VII
Software Win 7
Noctua NT-H2 or Arctic MX4
Thermal Grizzly is overpriced for what you get, really
This.
For the money spent, unless doing subzero stuff Grizzly is just too expensive and know it's formulated for subzero use anyway, hence the expense of it.
NT-H1 and MX4 Carbon are my go to's for what I do including subzero runs. Great stuff for everyday use as well, not difficult to apply and these just work with all I've ever used them for.
Gelid CG Extreme, although good itself is very expensive for what you get vs results in return for the money paid and you have to watch what you get, if it's goopy it's fine but there is also the issue of it being "Dry" sometimes and if so, it's no good.
I suggest NT-H1 or MX4 since there are no real issues with dried batches or it scratching stuff and lasts for a very long time too per application.
8,153 (2.23/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
3,045 (1.71/day)
Thessaloniki, Greece
Processor Ryzen 9 5900X (July 2022), 160W PPT limit, 75C temp limit, CO -9~14
Motherboard Gigabyte X570 Aorus Pro (Rev1.0), BIOS F37h, AGESA V2 1.2.0.B
Cooling Arctic Liquid Freezer II 420mm Rev7 (Jan 2024) with off center mount for Ryzen, TIM: Kryonaut
Memory 2x16GB G.Skill Trident Z Neo GTZN (July 2022) 3600MHz 1.42V CL16-16-16-16-32-48 1T, tRFC:280, B-die
Video Card(s) Sapphire Nitro+ RX 7900XTX (Dec 2023) 314~465W (390W current) PowerLimit, 1060mV, Adrenalin v24.5.1
Display(s) Dell Alienware AW3423DW 34" QD-OLED curved (1800R), 3440x1440 144Hz (max 175Hz) HDR1000, VRR on
Case None... naked on desk
Power Supply Corsair HX750i, 80+ Platinum, 93% (250~700W), modular, single/dual rail (switch)
Software Windows 11 Home 64bit (v23H2, OSB 22631.3737)
Hello guys,
Thanks in advance
Best in what?
1. Best performance no matter the cost?
2. Best "cheap"?
3. Best performance/$$$?
I cant answer all the questions but 1st one... and thats still Liquid Metal.
2,659 (0.69/day)
Alabama
Memory C.R.S.
Software Win 7
Best in what?
2. Best "cheap"?
Personally I will not use it because of the detrimental effects it has with the metals it come into contact with.
Well documented this stuff deteriorates the surfaces it comes in contact with and while it may take awhile for it to start affecting things. Once done the effects are there and non-reversible, meaning whatever coolers/blocks it's used with along with the CPU lid are permenantly affected.
Usually it takes a year or so for the effects to appear, many say the machine will last until you're ready to upgrade but that's not the point - Thing is we don't know for how long anyone is expecting their build to last or even need it to. Could be a few years, could be for longer than that based on the user's needs and budget/situation.
Really up to the OP but to know the pros and cons about Liquid Metal is the thing here.
