Keyboard | Corsair K70 Max |
Software | Windows 10 Pro |
System Name | AlderLake |
Processor | Intel i7 12700K P-Cores @ 5Ghz |
Motherboard | Gigabyte Z690 Aorus Master |
Cooling | Noctua NH-U12A 2 fans + Thermal Grizzly Kryonaut Extreme + 5 case fans |
Memory | 32GB DDR5 Corsair Dominator Platinum RGB 6000MT/s CL36 |
Video Card(s) | MSI RTX 2070 Super Gaming X Trio |
Storage | Samsung 980 Pro 1TB + 970 Evo 500GB + 850 Pro 512GB + 860 Evo 1TB x2 |
Display(s) | 23.8" Dell S2417DG 165Hz G-Sync 1440p |
Case | Be quiet! Silent Base 600 - Window |
Audio Device(s) | Panasonic SA-PMX94 / Realtek onboard + B&O speaker system / Harman Kardon Go + Play / Logitech G533 |
Power Supply | Seasonic Focus Plus Gold 750W |
Mouse | Logitech MX Anywhere 2 Laser wireless |
Keyboard | RAPOO E9270P Black 5GHz wireless |
Software | Windows 11 |
Benchmark Scores | Cinebench R23 (Single Core) 1936 @ stock Cinebench R23 (Multi Core) 23006 @ stock |
Hi,...thanks for the tip, great idea, but unfortunately i don't have a DSLR and I can only assume that's going to be A LOT more expensive than a webcamDoes it have to be a webcam?
Many DSLR type cameras can record video and even stream over USB to a PC.
That way you can get something like a macro lens, that should help.
Thanks for the recommendationElgato Facecam
Hi, I'm looking for a recommendation on webcams that are great for close-up work. I run jewelry making workshops online and need a webcam that can take very close up video without blurring.
Any recommendations?
Yes, sure, it'll cost more, but the quality will be 100x better. I thought this was for a business.Hi,...thanks for the tip, great idea, but unfortunately i don't have a DSLR and I can only assume that's going to be A LOT more expensive than a webcam
System Name | Dumbass |
Processor | AMD Ryzen 7800X3D |
Motherboard | ASUS TUF gaming B650 |
Cooling | Artic Liquid Freezer 2 - 420mm |
Memory | G.Skill Sniper 32gb DDR5 6000 |
Video Card(s) | GreenTeam 4070 ti super 16gb |
Storage | Samsung EVO 500gb & 1Tb, 2tb HDD, 500gb WD Black |
Display(s) | 1x Nixeus NX_EDG27, 2x Dell S2440L (16:9) |
Case | Phanteks Enthoo Primo w/8 140mm SP Fans |
Audio Device(s) | onboard (realtek?) - SPKRS:Logitech Z623 200w 2.1 |
Power Supply | Corsair HX1000i |
Mouse | Steeseries Esports Wireless |
Keyboard | Corsair K100 |
Software | windows 10 H |
Benchmark Scores | https://i.imgur.com/aoz3vWY.jpg?2 |
there is/was a watch repair streamer on twitch , forgot his name that does that same thing, no idea what cam he is using.Hi, I'm looking for a recommendation on webcams that are great for close-up work. I run jewelry making workshops online and need a webcam that can take very close up video without blurring.
Thanks,
M
System Name | Dusty |
Processor | 5900x |
Motherboard | MSI B550 Tomahawk |
Cooling | Noctua NH-D15 |
Memory | Corsair Vengence LPX 32GB |
Video Card(s) | MSI RTX 3070 Gaming X |
Storage | yes |
Case | Fractal Design Define R6 |
Power Supply | EVGA SuperNOVA 750w |
VR HMD | Oculus CV1 |
Logitech Brio, might be 4 years old by now but it does in fact have both clearer video and more features than the dell camera, also, its cheaper! So its a triple win.Yes, sure, it'll cost more, but the quality will be 100x better. I thought this was for a business.
Maybe take a look at Dell's new webcam, it's 4K and has some pretty advanced zoom features.
Dell UltraSharp Webcam - WB7022 - 4K UHD | Dell USA
View the Dell UltraSharp 4K Webcam (WB7022) featuring 4k imaging, advanced image signal processing & smart technology or shop all 4K webcams for PC at Dell.com.www.dell.com
The suggested Elgato camera won't be good for close ups, it has fixed focus and it's designed specially for streaming/face type applications.
If you mean people like Louis, he uses a microscope with a camera attachment, but i mean, thats in the couple thousand dollar range. He did use a tagarno earlier on however, a cheap little chineseium USB camera microscope. Same as EEVblog used for his soldering. Currently on a Eakins I think? But thats still a 500 dollar camera microscope from aliexpress.there is/was a watch repair streamer on twitch , forgot his name that does that same thing, no idea what cam he is using.
Processor | 7800X3D -25 all core |
Motherboard | B650 Steel Legend |
Cooling | Frost Commander 140 |
Video Card(s) | Merc 310 7900 XT @3100 core -.75v |
Display(s) | Agon 27" QD-OLED Glossy 240hz 1440p |
Case | NZXT H710 (Red/Black) |
Audio Device(s) | Asgard 2, Modi 3, HD58X |
Power Supply | Corsair RM850x Gold |
Generic USB Microscope
System Name | Juliette // My HTPC |
Processor | Intel i7 9700K // AMD Ryzen 5 5600G |
Motherboard | ASUS Prime Z390X-A // ASRock B550 ITX-AC |
Cooling | Noctua NH-U12 Black // Stock |
Memory | Corsair DDR4 3600 32gb //G.SKILL Trident Z Royal Series 16GB (2 x 8GB) 3600 |
Video Card(s) | ASUS RTX4070 OC// ASUS RTX 4060 OC |
Storage | Samsung 970 EVO NVMe 1Tb, Intel 665p Series M.2 2280 1TB // Samsung 1Tb SSD |
Display(s) | ASUS VP348QGL 34" Quad HD 3440 x 1440 // 55" LG 4K SK8000 Series |
Case | Seasonic SYNCRO Q7// Silverstone Granada GD05 |
Audio Device(s) | Focusrite Scarlett 4i4 // HDMI to Samsung HW-R650 sound bar |
Power Supply | Seasonic SYNCRO 750 W // CORSAIR Vengeance 650M |
Mouse | G903 and a Master Mouse MM710/No mouse, MS game copntroller |
Keyboard | EVGA / Logitech K400 |
Software | Windows 11 Pro // Windows 10 Pro |
