BFG Announces Four New Graphics Cards Featuring ThermoIntelligence Cooling
malware
5,422 (0.75/day)
Bulgaria
Processor Intel Core 2 Quad Q6600 G0 VID: 1.2125
Motherboard GIGABYTE GA-P35-DS3P rev.2.0
Cooling Thermalright Ultra-120 eXtreme + Noctua NF-S12 Fan
Memory 4x1 GB PQI DDR2 PC2-6400
Video Card(s) Colorful iGame Radeon HD 4890 1 GB GDDR5
Storage 2x 500 GB Seagate Barracuda 7200.11 32 MB RAID0
Display(s) BenQ G2400W 24-inch WideScreen LCD
Case Cooler Master COSMOS RC-1000 (sold), Cooler Master HAF-932 (delivered)
Audio Device(s) Creative X-Fi XtremeMusic + Logitech Z-5500 Digital THX
Power Supply Chieftec CFT-1000G-DF 1kW
Software Laptop: Lenovo 3000 N200 C2DT2310/3GB/120GB/GF7300/15.4"/Razer
BFG Technologies announced today the release of the BFG NVIDIA GeForce 8600 GT OC and OC2 graphics cards with ThermoIntelligence cooling. Both cards are available now in 256MB & 512MB versions at leading retailers and etailers throughout North America and Europe.
We've added our custom ThermoIntelligence custom cooling solutions to our 8600 GT lineup, lowering GPU temperatures up to 18°C over the reference cooler
said Dean Brady, Sr. Director of Marketing for BFG Technologies.
Bigger isn't always better
Better cooling solutions often come at the expense of space inside your computer, many of them taking up two add-in card slots when installed. The BFG 8600 GT series with ThermoIntelligence fansinks only use a single PCI Express slot, leaving you with room for other add-in cards.
Quiet by design
Many custom cooling solutions today increase the fan speed to reduce temperatures, but this results in excess noise. The 8600 GT ThermoIntelligence fansink was specifically designed not to increase acoustic noise while providing, on average, an 11°C lower GPU load temperature. For users running two graphic cards in an NVIDIA SLI configuration, the thermal performance improves with the primary graphics card operating at up to 18°C cooler
BFG NVIDIA GeForce 8600 GT OC2 with ThermoIntelligence
(256MB & 512MB versions)
  • Core Clock: 620MHz
  • Shader Clock: 1350MHz
  • Memory Clock: 1600MHz (256MB), 1500MHz (512MB)
BFG NVIDIA GeForce 8600 GT OC with ThermoIntelligence
  • Core Clock: 565MHz
  • Shader Clock: 1242MHz
  • Memory Clock:1400MHz
Please visit http://www.thermointelligence.com for further information.
994 (0.15/day)
SoCal
Processor Intel C2D E6420 (3.2 gHz @ 1.365v)
Motherboard Gigabyte 965P-DS3
Cooling Zalman CNPS9500 LED
Memory 4 x 512mb Corsair XMS2 DDR2 667
Video Card(s) Visiontek HD 4870 512mb
Storage 200gb Maxtor SATA, 400gb WD SATA
Audio Device(s) Audigy 2 ZS
Software Windows XP Pro SP2
It also has the HD 2x00-esque flames too! Hopefully they won't charge a fortune for these ...
jydie
209 (0.03/day)
Processor Athlon 64 X2 4200+ (socket 939)
Motherboard ASUS A8R-MVP Express200
Cooling Standard AMD CPU Heatsink/Fan
Memory 1GB Geil PC3200
Video Card(s) Sapphire Radeon X1900GT
Storage 2 Maxtor 7200 HDD (80GB)
Display(s) Samsung 19" LCD
Case Yellow Chieftech Dragon
Audio Device(s) integrated
Power Supply Thermaltake TT-420AD
Software Windows XP Home
I have a question. There are a lot of video cards that exhaust the air toward the capacitors on the video card... as this one does I am not very knowledgeable on electronics, so I do not know if this is a good or bad thing. Do capacitors typically run hot? If so, then I would guess that blowing air across them would be a good thing... even if the air was warm. If the capacitors run warm, then running warm air across them might make them hotter. The only reason I ask is becuase I have seen a lot of motherboards go bad because of blown capacitors. Keeping them cool is very important to extending their life.
The video card is typically the hottest component in a system these days. I personally like the video card coolers that exhaust the hot air out the back of the case... even if it takes up one of the slots below the video card. I do not know of any system that has an intake fan mounted in the rear of the case, so this is ideal.
OnBoard
3,033 (0.46/day)
Finland
Processor Core i5-750 @ 3.6GHz 1.136V 24/7
Motherboard Gigabyte P55A-UD3, SATA 6Gbit/s & USB3.0 baby!
Cooling Alpenföhn Brocken HeatpipeDirectTouch
Memory Geil Ultra Series 4GB 2133MHz DDR3 @ 1440MHz 7-7-7-24
Video Card(s) Gigabyte GTX 460 1GB OC (mostly stock speeds)
Storage OS: Samsung F3 500GB Games: Samsung F1 640GB
Display(s) new! Samsung P2350 23" FullHD 2ms / Mirai DTL-632E500 32" LCD
Case new! Xigmatek Midgard/Utgard side window with red cathodes, 1x140mm & 3x120mm fans
Audio Device(s) new! ASUS Xonar DG & JVC HA-RX700 headphones
Power Supply Cougar CM 700W Modular
Benchmark Scores Logitech UltraX Premium & G5 laser v2 + Ulti-mat Breathe X2 for fragging
Cooler they run, longer they last. Those solid state ones (text on top) are tougher though and can handle bigger temp, but there are 3 cheaper regular ones too.
"Many custom cooling solutions today increase the fan speed to reduce temperatures, but this results in excess noise. The 8600 GT ThermoIntelligence fansink was specifically designed not to increase acoustic noise while providing, on average, an 11°C lower GPU load temperature."
This is such an marketing gimmick it's not even funny. Basicly it's lying and only think that is true is there's a bigger heatsink = lower temps. Doesn't matter how "smart" heatsink is, to run it cooler you need more fan rpm = more noise.
edit: from their page:
"In an acoustically controlled environment with a background acoustic noise level of 19.2<20 dB(A), the NVIDIA reference fansink measured 39.9 dB(A) and the BFG ThermoIntelligence fansink measured 39.2 dB(A)"
0.7db whii xD So it's even the same fan, just running a bit slower, because the heatsink is bigger.. Silly BFG :)
edit2:
"ThermoIntelligence fansink maintains a 5C lower GPU temperature on average vs. the NVIDIA reference fansink with a single card setup. For power users running dual cards in an NVIDIA SLI configuration, the thermal performance gets even better with the primary card operating at up to 11C cooler."
"ThermoIntelligence fansink was specifically designed not to increase acoustic noise while providing, on average, an 11°C lower GPU load temperature. For users running two graphic cards in an NVIDIA SLI configuration, the thermal performance improves with the primary graphics card operating at up to 18°C cooler"
funny how their info on 2 pages doesn't add up, 6-7C difference.
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
Stupid name.
WarEagleAU
Bird of Prey
10,812 (1.62/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Thanks for the clear up onboard. I didnt look at their page and to me, Im not all about silence. Hell my fans are all turned up to the highest and I barely hear anything.
rick22
628 (0.10/day)
System Name bubba
Processor e something
Motherboard old but good mobo
Cooling my farts
Memory can't find it
Video Card(s) EVGA 250 took a shit..back to my 4850..fk off ati fanboys
Storage i think i have one
Display(s) not sure but it sucks
Case lol my mouth
Audio Device(s) me
Power Supply ass farts
Software that sucks to
Benchmark Scores i'm so fat i sat on the bench and smashed assssit
great looking card...i problem with BFG the cards are over priced...
