Binned Intel CPUs are Selling for Less Than Untested Chips from Amazon & Newegg
1,519 (0.94/day)
The Intel Core i5-10600K is currently retailing for $289.99 and $299.99 respectively on Amazon and Newegg which is well above Intel's suggested MSRP of just $262. This has created a bizarre situation where it is currently better value to purchase the CPU from Silicon Lottery where it has been verified to overclock to a set amount. Silicon Lottery sells multiple binned variants of the chip ranging from 4.7 GHz - 5.1 GHz max all-core overclock with prices starting at $289.99 going all the way up to $419.99. The $299.99 option which is guaranteed to overclock to 4.9 GHz on all 6 cores, and 5.0 GHz on up to 2 cores is arguably the best value option for the chip currently.
This guaranteed all-core overclock of 4.9 GHz provides a significant performance boost over the stock base frequency of 4.1 GHz, which equates to roughly 1% - 3% gaming performance boost which while not massive still equates to a few extra FPS. If considering one of these CPUs keep in mind the need for reasonable aftermarket cooling to ensure these chips stay cool such as the Noctua NH-U12S we used in our review.
2,324 (0.46/day)
Right where I want to be
System Name Miami
Processor Ryzen 3800X
Motherboard Asus Crosshair VII Formula
Cooling Ek Velocity/ 2x 280mm Radiators/ Alphacool fullcover
Memory F4-3600C16Q-32GTZNC
Video Card(s) XFX 6900 XT Speedster 0
Storage 1TB WD M.2 SSD/ 2TB WD SN750/ 4TB WD Black HDD
Display(s) DELL AW3420DW / HP ZR24w
Case Lian Li O11 Dynamic XL
Audio Device(s) EVGA Nu Audio
Power Supply Seasonic Prime Gold 1000W+750W
Mouse Corsair Scimitar/Glorious Model O-
Keyboard Corsair K95 Platinum
Fail to see how +-0 and a +$10 price difference is cheaper.
1,519 (0.94/day)
I choose that one for the value it offered but a 4.7 GHz chip was previously available for $289.99 or 4.8 GHz for $284.99.
I have also updated the original post
3,326 (1.17/day)
System Name The de-ploughminator Mk-II
Processor i7 13700KF
Motherboard MSI Z790 Carbon
Cooling ID-Cooling SE-226-XT + Phanteks T30
Memory 2x16GB G.Skill DDR5 7200Cas34
Storage Kingston KC3000 2TB NVME
Display(s) 48" LG OLED C4
Case Corsair 5000D Air
Power Supply Corsair HX850
Mouse Razor Death Adder v3
Software win11
Well 4.9ghz for the 10600K is probably the worst bin, therefore it should be cheaper than standard price where people have a chance to get 5.0-5.1ghz chip.
1,384 (0.36/day)
Alabama, USA
Processor 5900x
Motherboard MSI MEG UNIFY
Cooling Arctic Liquid Freezer 2 360mm
Memory 4x8GB 3600c16 Ballistix
Video Card(s) EVGA 3080 FTW3 Ultra
Storage 1TB SX8200 Pro, 2TB SanDisk Ultra 3D, 6TB WD Red Pro
Display(s) Acer XV272U
Case Fractal Design Meshify 2
Keyboard Ducky One 2
Stock boost being 4.8 means I'd assume with multi-core enhancement they would all hit 4.8 all-core, That 4.7 is a downgrade from a chance of hitting even 5.0 all-core.
Never had an intel CPU that wouldn't max out all-core enhancement like that.
low
50 (0.03/day)
Pretested is a way to sell less quality CPUs for a higher Price. Buy the cheapest pretested and you get a potato chip. So no one wants to buy them.
5,944 (1.50/day)
Over here, right where you can't see me !
System Name The Little One
Processor i5-11320H @4.4GHZ
Motherboard AZW SEI
Video Card(s) Iris XE
Power Supply 65w brick
Mouse Logitech MX Master 2
Benchmark Scores PDQ
PSA
When overclocking ANY CPU/GPU etc, there is N.O. such a thing as a guarentee, regardless of who does it.... this is just a fact of life when dealing with the many assorted variables in the silicon wafers, lithography, mfg processes, QA/QC etc etc...
Yes you can test, delid, test, repaste, push, test, and make all the promises you want, etc etc...but in the end, virtually each individual chip can be just slightly different in this regard... not to mention the differences in mobo's, ram, psu's etc etc....
You're welcome ..:peace:..:D..:clap:
tabascosauz
7,987 (2.38/day)
Western Canada
System Name ab┃ob
Processor 7800X3D┃5800X3D
Storage 8TB of SSDs┃1TB SN550
Case Caselabs S3┃Lazer3D HT5
PSA
That's true if you're buying from a retailer. The whole point of buying a CPU from SL is that you're paying extra for a CPU that meets a specific level of guaranteed performance, ie. 4.9 all core @ 1.35V. Yes, there are very specific conditions for stability including the choice of board and the LLC settings required, but that comes naturally with meeting specific performance requirements, since the whole point is that it's tested by them to meet that standard, and you're paying for it.
Now, even then, the next step up is 1.425V for 5.0, so there could conceivably be a 10600K that comfortably meets 4.9 with less than required voltage, but can't meet 5.0 (or else it would be sold at that tier instead for more $).
3,685 (0.57/day)
Northern Ontario Canada
Processor Ryzen 5700x
Mouse Mionix Naos Pro
Software W10 22H2 Pro x64
"The Intel Core i5-10600K is currently retailing for $289.99 and $299.99 respectively on Amazon and Newegg which is well above Intel's suggested MSRP of just $262. "
All I got out of the article is Newegg and Amazon are gouging when the economy is in the pits.
636 (0.15/day)
Technical Tittery....
System Name "IBT 10x Maximum Stable"
Processor Intel i5 4690K @ 4.6GHz -> 100xx46 - 1.296v
Motherboard MSI MPower Z97
Cooling Corsair H100i + 2x Corsair "HP Edition" SP120's
Memory 4x4GB Corsair Vengence Pro 2400mhz @ 2400MHz 10-11-12-31-1T - 1.66v
Video Card(s) MSI Gaming GTX970 4GB @ 1314 Core/1973 Mem/1515 Boost
Storage Kingston 3K 120GB SSD + Western Digital 'Green' 2TB + Samsung Spinpoint F3 1TB
Display(s) Iiyama Prolite X2377HDS 23" IPS
Case Corsair Carbide 300R
Audio Device(s) Rotel RA-04/Cambridge Audio Azur 540R + B&W DM302/Cerwin Vega AT12 / Sony MDR-XB700 & FiiO E5
Power Supply EVGA NEX650G + Silverstone Extensions
Mouse Always failing me....
Keyboard Endlessly broken.....
Software Windoze 7 Pro 64-bit/Windoze 10 Pro
Benchmark Scores I had some of these once upon a time? Old age has seen me misplace them....
This; along with most other replies in this thread so far...
@W1zzard is this a promotional piece? or just a bad news piece from a new hire?? :confused:
Edit to say theres no bias against SL - previously used to purchase 7700k @ 5.2ghz - very pleasant experience.
9,340 (5.66/day)
Louisiana
Keyboard G710+x3
1,349 (0.22/day)
Milwaukee, Wisconsin, USA
Processor i7-3770K
Motherboard Biostar Hi-Fi Z77
Cooling Swiftech H20 (w/Custom External Rad Enclosure)
Memory 16GB DDR3-2400Mhz
Video Card(s) Alienware GTX 1070
Storage 1TB Samsung 850 EVO
Display(s) 32" LG 1440p
Case Cooler Master 690 (w/Mods)
Audio Device(s) Creative X-Fi Titanium
Power Supply Corsair 750-TX
Mouse Logitech G5
Keyboard G. Skill Mechanical
Software Windows 10 (X64)
Sure looks like it is otherwise why mention SL at all.
Just because a company's name is mentioned doesn't mean that someone is promoting them.
21,136 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
