BIOS damaged after installing RealTemp
dictum
5 (0.00/day)
I ran the application and immediately the machine shut down and would not boot up anymore.
The machine is Sun Ultra 40 M2 and has this error message.
I checked the obvious and all the fans are working, the main fan module with 3 fans in it and as well as the RAM fans. They are all spinning.
Any idea how to troubleshoot this? The machine displays this message then shuts down. Hitting Escape does not prevent shutdown. I have not made any configuration changes except for the temperature app. How could it damage my BIOS?
9,781 (2.24/day)
Massachusetts
Processor i7-11700K
Cooling Noctua NH-U12A
Case Fractal Design Meshify-C
Audio Device(s) on board
Mouse Logitech G502 spectrum
It couldnt. It runs in your os , & has no effect on bios. Im not saying i know what happened, i just know realtemp didnt "damage" your bios, no more than your eyes could damage a book from reading it , try uninstalling RT, also try clear cmos?
Good luck
Looks like sensor issues to me
OneMoar
There is Always Moar
8,789 (1.66/day)
Rochester area
System Name RPC MK2.5
Processor Ryzen 5800x
Mouse Kone burst Pro
Keyboard SteelSeries Apex 7
Good luck
thats not entirely correct
it is possible by setting the incorrect registers or issuing the wrong commands over ic2 to `brick` it especially on old or odd systems such as this sun machine i killed a pll chip on a old dell that way
clear the cmos and hope it has the sense to clear the registers you will need to get into the setup and re-set any fan related options
worst case update the bios that should reset the fmc table
remember and @Solaris17 can back me on this sun systems especially the old ones are a odd duck they do things completely differnt
dictum
5 (0.00/day)
How do I clear the CMOS? I scanned the entire BIOS, no such option.
Meaning this thing is permanently bricked.
From Sun Oracle:
As of April 5th customers now need either hardware warranty or a 'system' level contract to download firmware, drivers, etc from either SunSolve or the Download Center.
Sincerely,
Sun Web Team
Sun Microsystems, Inc.
I found an entry to reset bios to original settings, I think that's what it was, to no avail.
OneMoar
8,789 (1.66/day)
Rochester area
there is a jumper on the board or just remove the battery and power for 15m
dictum
5 (0.00/day)
I removed the battery and power, will see if that has any effect.
It's complaining about the DIMM fan *and* the CPU fan, so which one is it? And if it's a hardware related failure, does it make to try to replace the CPU fan? I cannot really tell if it's moving because it's under the heat sink, or somewhere inside I assume. It's not visible.
The DIMM fan and the main system fan (3 of them on that board) are moving.
8,180 (2.19/day)
SE Michigan
System Name Dumbass
Processor AMD Ryzen 7800X3D
Power Supply Corsair HX1000i
Software windows 10 H
I was never lucky enough to play with one of these bad bois, the fans look a wee bit old style and its possible they actually could have failed. Consider replacing them with molex fans, so you dont need to plug them into the motherboard.
If the BIOS is like most others, there should be a way disable the extra fan headers. I also suggest taking small steps changing any BIOS settings and take careful notes what settings you do change incase you need to change them back.
dictum
5 (0.00/day)
Removing and reinstalling the 2032 lithium battery did the trick... it booted right up. I have no idea which app messed it up.
I installed CoreTemp, RealTemp and instspeedfan452, one of them, or several really messed up my BIOS.
It's working now. I am up and fully booted into Windows 7.
I won't be installing any temperature monitoring programs anytime soon.
OneMoar
8,789 (1.66/day)
Rochester area
just don't install 3 at once .... speedfan was the likely culript
8,180 (2.19/day)
SE Michigan
System Name Dumbass
Is that a x64 or x32? Consider, if you do want to extract system specs try HWinfo64 or Speccy or Aida64. And if anything happens installing these programs that there is a real issue here.
Weed it out if you can.
Highly doubtful. Unless the OP tried playing with the clocks tab, a big no-no.
Frick
Fishfaced Nincompoop
19,278 (2.84/day)
Piteå
System Name White DJ in Detroit
Processor Ryzen 5 5600
Motherboard Asrock B450M-HDV
Cooling Be Quiet! Pure Rock 2
Case Fractal Design Define R4
Realtemp/Coretemp is specifically for Intel CPUs. If anything it's them, and IMO it would really be nice to know which one.
OneMoar
8,789 (1.66/day)
Rochester area
speedfan is the only one that provides ic2 access if he was fiddling around with the advanced settings thats what did it
8,180 (2.19/day)
SE Michigan
System Name Dumbass
Correct, and, using speed fan only for a temp reader is funny.
newtekie1
Semi-Retired Folder
28,473 (4.13/day)
Indiana, USA
Memory 32GB DDR4-3600
Video Card(s) RTX 2070 Super
Case Fractal Design Define S
Rraltemp is for Intel only, but Coretemp is for both Intel and AMD.
8,180 (2.19/day)
SE Michigan
System Name Dumbass
I never had good luck with Coretemp.
