Bios for RX 580 2048sp soyo
kaio96
6 (0.19/day)
I have a soyo rx 580 2048sp. I'd like to find its correct BIOS. I think it's an rx 570.
The BIOS that came with this board uses Hynix H5GC8H24AJR memory, but as you can see in the photos, the memory chips are Samsung K4G80325FC-HC25. I've attached them to this post.
GPU: 215-0876406
Memory: Samsung K4G80325FC-HC25
  • BIOS RX 580.rom
41,051 (6.56/day)
GPU: 215-0876406
Ok so it says FC, fyi 570 and 580 (2048) are same chip
1,624 (0.27/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
I'm testing a few BIOS, but so far I've had no success. I need to find the right BIOS for it.
Why are you reflashing the card? Did it work properly before?
kaio96
6 (0.19/day)
That's right, it doesn't work properly. The BIOS that came with this card has Hynix H5GC8H24AJR memory, but the memory chips on the video card are Samsung K4G80325FC-HC25.
1,624 (0.27/day)
kaio96
6 (0.19/day)
41,051 (6.56/day)
The PCB seems to be a Dataland design:
https://videocardz.net/dataland-radeon-rx-570-4gb-dual-cool -> https://cdn.videocardz.net/cache/b744f533518dc39a1d69710908b83527-1200x900.jpg
Following bios might work:
Thank you very much. I've just rewritten the bios and I'm testing the video card. So far it's working perfectly.
Don't use these unless we say so...
I was going to provide 3 others:
This 1 below has a higher TDP, use at own risk:
How were you able to find that pcb design, was it on tpu as well?
kaio96
6 (0.19/day)
Thank you very much. I'm carrying out some tests with the one that gave the video. It seems to be working perfectly.
kaio96
6 (0.19/day)
This first BIOS is working better. Probably because of the lower frequencies and tdp. So far this is the best.
