BIOS Issues Continue to Haunt PowerColor HD 4870 PCS+
47,057 (7.59/day)
It was earlier reported that the non-reference high performance Radeon HD 4870 graphics card, the PowerColor Radeon HD 4870 PCS+, faced a BIOS glitch (covered here) that affected its stability. Barely days after Chinese website Expreview reported this, PowerColor posted a revised BIOS on their website. Expreview notes that the BIOS didn't quite fix the fan speed (as in up the maximum speed limit), but makes the fan operate at erratic speeds or "zipzip" as Expreview notes. The fan-speed sensor graph should give you a better idea:
Expreview notes that the first screen shot was captured when system was idle…even core temperature(DISPIO) kept 64.5° C, the fan kept "crazy changing its speed from 100% to 13% to 0%". The card continues to fail at Furmark beyond 1440×900 8xAA, leading to a driver crash during the benchmark run. The card was tested using the latest Catalyst 8.8, when it was noted that Furmark could be cleared but that the card suffers frame-rate loss compared to older drivers, in essence temperatures are lowered at the expense of performance. Expreview sought another sample from PowerColor and hopes for the best with the product.
41,430 (6.58/day)
i remember when there was no need for temperature sensor for fan speeds on video cards, fan would run at full speed and keep stuff properly cooled, why not have a manual way of doing it, i mean CPU Fans suffer from the same thing when they are plugged into the motherboard (thats why i dont have mine on it but a molex)
And i Recall Arctic-Cooling having a 2-way toggle switch for fan speed for the AC VGA Silencer Rev 3.
To add another note, Board Makers are thinking about putting Turbo Mode back on the motherboards, same with case makers, why not have the said above (Manual Fan switching)
1,664 (0.28/day)
System Name Ryzen5900X
Processor AMD Ryzen 5900X
Motherboard Gigabyte B550 AORUS PRO AC
Cooling NZXT Kraken X62
Memory 4x G.Skill F4-3600C17D-8GTZ
Video Card(s) AMD Radeon RX 6800XT Midnight Black
Lolz I had this bug also with my normal HD4870. This issue is caused by software and bios.
I had this issue only when GPU-Z (under xp) was active with the stock bios (113-B50701-100). They fixed it with the 113-B50701-105 bios which also have powerplay. I couldn't recreate this problem with my second operation system (vista) so it could be also a part of the drivers/operating system
RBE has an option which can fixed this (when the correct bytes and section are avaible).
1,425 (0.22/day)
Processor E5-1680 V2
Motherboard Rampage IV black
Video Card(s) Asrock 7900 xtx
Storage 500 gb sd
Software windows 10 64 bit
Benchmark Scores 29,433 3dmark06 score
i agree ^_^ it's another never ending story of bulls**t attempt to automate everything
I have 2 8800gts 512's and last radeon card (I still have but unused) is an x1900xtx so I'm unaware as to how you can deal with fan speeds on newer catalyst versions, but can't you override fan speed manually with software via catalyst or even 3rd party software or even that neat looking bios editor for ati I think wizzard came up with here? If that is the case...who the hell cares unless the bios has other issues that causes instability, if it's just a screwed up fan control/sensor issue you just pick a manual setting that cools well enough for all applications and still doesn't set your ears on fire.
406 (0.07/day)
System Name -
Processor Ryzen 9 5900X
Motherboard MSI MEG X570
Cooling Arctic Liquid Freezer II 280 (4x140 push-pull)
Memory 32GB Patriot Steel DDR4 3733 (8GBx4)
Video Card(s) MSI RTX 4080 X-trio.
Storage Sabrent Rocket-Plus-G 2TB, Crucial P1 1TB, WD 1TB sata.
Display(s) LG Ultragear 34G750 nano-IPS 34" utrawide
Case Define R6
Audio Device(s) Xfi PCIe
Power Supply Fractal Design ION Gold 750W
Mouse Razer DeathAdder V2 Mini.
Keyboard Logitech K120
VR HMD Er no, pointless.
Software Windows 10 22H2
Benchmark Scores Timespy - 24522 | Crystalmark - 7100/6900 Seq. & 84/266 QD1 |
Fixed...
Afternoon chaps..
Basically to fix the fan/temp issue you need to do is the following..
my idle/load temps are 43/60c.
biker
47,057 (7.59/day)
The point is, PowerColor should do that before selling you the card and making you go thru that. BIOS flash could make them reject your RMA. Besides, didn't they name this "Professional Cooling System"?
chron
569 (0.08/day)
why can't you just flash the regular bios to this thing? Why does it have to be some kind of special power color bios? The clocks might be different, but you can fix that...
1,664 (0.28/day)
The problem is the HD4870 PCS+ has another part nummer in the bios. When they check the bios they could reject it because it isn't the orginal bios for the card or a newer HD4870 PCS+ bios
jydie
209 (0.03/day)
Processor Athlon 64 X2 4200+ (socket 939)
Motherboard ASUS A8R-MVP Express200
Cooling Standard AMD CPU Heatsink/Fan
Memory 1GB Geil PC3200
Video Card(s) Sapphire Radeon X1900GT
Storage 2 Maxtor 7200 HDD (80GB)
Display(s) Samsung 19" LCD
Case Yellow Chieftech Dragon
Audio Device(s) integrated
Power Supply Thermaltake TT-420AD
Software Windows XP Home
They are so worried about the noise level for the video card!!! They force the fan to barely run in idle, and ramp up way to slowly during gaming. I really wish it was the other way around, and they would focus on keeping the temperature at a decent level at ALL times... that way my video card would last longer. If my GPU in hitting 80+ degrees celcius, then I WANT the fan running 100%, because despite what they say I think that is to hot!!
These are high performance cards, I expect a little fan noise. ;)
406 (0.07/day)
System Name -
Case Define R6
Hence why I used and edited the bios that CAME with the card, the ONLY change I made was the fan speed..! The card has now been stable for the last 2 days.
biker
47,057 (7.59/day)
Nkd
364 (0.06/day)
this could very well be an issue with gpuz, gpu-z 0.2.7 tells me that my fan is running at 0% and nothing for rpm for my 9800gx2, just look at the temps on that screenshot, if it was at 0% those temps would not be in the 50s and 60s, I cant believe that we all jump to conclusions without proper observation
EastCoasthandle
6,885 (0.97/day)
System Name MY PC
Processor E8400 @ 3.80Ghz > Q9650 3.60Ghz
Motherboard Maximus Formula
Cooling D5, 7/16" ID Tubing, Maze4 with Fuzion CPU WB
Memory XMS 8500C5D @ 1066MHz
Video Card(s) HD 2900 XT 858/900 to 4870 to 5870 (Keep Vreg area clean)
Storage 2
Display(s) 24"
Case P180
Audio Device(s) X-fi Plantinum
Power Supply Silencer 750
Software XP Pro SP3 to Windows 7
Benchmark Scores This varies from one driver to another.
I find it odd that they use the term "zipzip" to explain the fan speed. The graph clearly shows that they increase the fan speed and, the erratic behavior is not synonymous with the graph. After looking at the graph the fan is suppose to run at a higher RPM. Therefore, what they explain doesn't make any sense to me. Also if this keeps the card within spec we are grasping at straws here. I honestly wouldn't use furmark on that 4870 as I don't see any active cooling on the vregs. As VuurVOS said other programs can affect the card and cause similar results.
WarEagleAU
Bird of Prey
10,812 (1.62/day)
Gurley, AL
System Name Pandemic 2020
Processor AMD Ryzen 5 "Gen 2" 2600X
Motherboard AsRock X470 Killer Promontory
Cooling CoolerMaster 240 RGB Master Cooler (Newegg Eggxpert)
Memory 32 GB Geil EVO Portenza DDR4 3200 MHz
Video Card(s) ASUS Radeon RX 580 DirectX 12 DUAL-RX580-O8G 8GB 256-Bit GDDR5 HDCP Ready CrossFireX Support Video C
Storage WD 250 M.2, Corsair P500 M.2, OCZ Trion 500, WD Black 1TB, Assorted others.
Display(s) ASUS MG24UQ Gaming Monitor - 23.6" 4K UHD (3840x2160) , IPS, Adaptive Sync, DisplayWidget
Case Fractal Define R6 C
Audio Device(s) Realtek 5.1 Onboard
Power Supply Corsair RMX 850 Platinum PSU (Newegg Eggxpert)
Mouse Razer Death Adder
Keyboard Corsair K95 Mechanical & Corsair K65 Wired, Wireless, Bluetooth)
Point is, shit should work when you buy it and these should have been caught.
282 (0.04/day)
Whole ignored by most, RV770 and the 780G IGP definitely have their issues. For ex, People seem to just happily accept RV770s ridiculous power use just because it's the first ATI chip in YEARS that hasn't sucked compared to the competition. Even though they advertised its "awesome" power saving features. Oh I guess it's "ok" to just let that BS slip buy. I guess it's also why I don't own RV770 in any incarnation.
My 780G mobo has a list of problems that I don't really feel like going into again. Stuff like CnQ failing after videos, 2D performance problems in XP, strange video chop, and some AHCI problems. Wow, worthy of glowing reviews indeed.
The fan speed problem here is nothing new either. How many releases now have had people seeing temp problems? And, the reason they don't just let it go full bore is because it would be DEAFENING. This things run so crazy hot that they either need giant copper heatpipe coolers or cheap ass heatsink + uber blower. You wouldn't buy these cards if they just let those blowers sound like a hair drier full time.
The answer is all-around better cooling. Bigger heatsink. But I have a big ugly feeling that they don't do that for several reasons:
1) The cards don't pump out max heat full-time so the benefit of more cooler isn't entirely there.
2) Shipping costs due to weight of a big beast cooler.
3) The simple fact that it would cost more to make you a better cooler.
4) That it probably doesn't matter if the card burns up in a year. In a year you will probably have moved on. Ha hah.
EastCoasthandle
6,885 (0.97/day)
System Name MY PC
Storage 2
Display(s) 24"
Case P180
GPU temps at 57C at idle and you believe it's not working? It looks like it's working to me.
My temp is 52C with the stock fan at 65%!!!! I would say that their cooling solution of 57C is working fine if it's done at a lower RPM (whatever that is).
Also, what's being posted is that the fan operates different from the actual graph. Until this is proven conclusively, I remain skeptical about this report.
Red Flags
1. No comparison between reference and non reference cooling solutions.
2. No confirmation of audio or visual inspection of fan speed with new bios.
3. No 4870 utility comparison to confirm fan speed fluctuation.
4. ZipZip noise gone in new bios but no noise heard when fan goes from 100% to 0%
5. No load temps provided in this review
6. No mention if vregs need active cooling or not under load.
7. If the fan does cycle down is it by design? Was the manufacture asked this?
The issue I've seen with Furmark has more to do with the vregs from what I've seen. One thing I notice in their cooling solution is that vregs are passively cooled. ATI/AMD's cooling solution is designed to actively cool the vregs even thought they are of a different design. But I reserve judgment until more information is provided on how hot those vregs get.
Side note:
This article appears to be stacked (ie 2 articles in one). The beginning of it appears to be the old article and page 4 appears to be a new one.
41,430 (6.58/day)
Instead of being a Continuous Speed Increase, its a Pulse, so it speeds up, slows down speeds up higher slows down etc it propbably also sounds like a Whirring Noise. My 1950 Pro Sapphire doesnt suffer from this, the only time i hear the Fan is during powerup (continuous RPM) then once it hits windows it silences.
2,792 (0.39/day)
Tre, Suomi Finland
System Name Ladpot ◦◦◦ Desktop
Processor R7 5800H ◦◦◦ i7 4770K, watercooled
Motherboard HP 88D2 ◦◦◦ Asus Z87-C2 Maximus VI Formula
Cooling Mixed gases ◦◦◦ Fuzion V1, MCW60/R2, DDC1/DDCT-01s top, PA120.3, EK200, D12SL-12, liq.metal TIM
Memory 2× 8GB DDR4-3200 ◦◦◦ 2× 8GB Crucial Ballistix Tactical LP DDR3-1600
Video Card(s) RTX 3070 ◦◦◦ heaps of dead GPUs in the garage
Storage Samsung 980 PRO 2TB ◦◦◦ Samsung 840Pro 256@178GB + 4× WD Red 2TB in RAID10 + LaCie Blade Runner 4TB
Display(s) HP ZR30w 30" 2560×1600 (WQXGA) H2-IPS
Case Lian Li PC-A16B
Power Supply Corsair AX860i
Mouse Logitech MX Master 2S / Contour RollerMouse Red+
Keyboard Logitech Elite Keyboard from 2006 / Contour Balance Keyboard / Logitech diNovo Edge
Software W11 x64 ◦◦◦ W10 x64
Benchmark Scores It does boot up? I think.
Ahhh...
Watercooling saves one from so many nasty headaches.
:D
Mikey242
18 (0.00/day)
Am I right in thinking that this affects all Powercolor 4870 512MB cards? I have one of these and I am also experiencing high temps with it. I went to Powercolor's website but could not find any sign of a bios update. Would I be able to flash this with the bios for another card? Thanks guys, sorry if questions a bit repetitive.
1,664 (0.28/day)
Your can flash a normal bios hd4870 in the current oc cards. I already flashed the Diamond XOC and the Asus Top in my normal Sapphire 4870 card. But keep in mind you will lose your warrenty when the cards gets broken with that bios on it.
You can better use the alternative tools like ATI Tray Tools. You can still use the current bios and the program can set the fan and gpu/ram speeds for you. If you realy want to have a cooler card make a 2D profile (lower gpu/ram speed) and a 3D profile (normal gpu/ram speeds) with ATT and use it with AUTO OVERCLOCKING.
Mikey242
18 (0.00/day)
Thanks VuurVOS for the info. Just checking though, where was the Powercolor bios update posted? I tried to flash the newest one in the download section and it just said vendor mismatch or something to that effect (used winflash). Thanks again guys.
