System Name | Gaming Rig | Uni Laptop |
Processor | Intel Q6600 G0 (2007) @ 3.6Ghz @ 1.45625v (LLC) / 4 GHz Bench @ 1.63v | AMD Turion 64 X2 TL-62 2 GHz |
Motherboard | ASUS P5Q Deluxe (Intel P45) | HP 6715b |
Cooling | Xigmatek Dark Knight w/AC MX2 ~ Case Fans: 2 x 180mm + 1 x 120mm Silverstone Fans |
Memory | 4GB OCZ Platinum PC2-8000 @ 1000Mhz 5-5-5-15 2.1v | 2 x 1GB DDR2 667 MHz |
Video Card(s) | XFX GTX 285 1GB, Modded FTW BIOS @ 725/1512/1350 w/Accelero Xtreme GTX 280 + Scythe sinks| ATI X1250 |
Storage | 2x WD6400AAKS 1 TB Raid 0, 140GB Raid 1 & 80GB Maxtor Basics External HDD (storage) | 160GB 2.5" |
Display(s) | Samsung SyncMaster SM2433BW @ 1920 x 1200 via DVI-D | 15.4" WSXGA+ (1680 x 1050 resolution) |
Case | Silverstone Fortress FT01B-W ~ Logitech G15 R1 / Microsoft Laser Mouse 6000 |
Audio Device(s) | Soundmax AD2000BX Onboard Sound, via Logitech X-230 2.1 | ADI SoundMAX HD Audio |
Power Supply | Corsair TX650W | HP 90W |
Software | Windows 7 Ultimate Build 7100 x64 | Windows 7 Ultimate Build 7100 x64 |
Benchmark Scores | 3DM06: 19519, Vantage: P16170 ~ Win7: -CPU 7.5 -MEM 7.5 -AERO 7.9 -GFX 6.0 -HDD 6.0 |
System Name | Budget AMD System |
Processor | Threadripper 1900X @ 4.1Ghz (100x41 @ 1.3250V) |
Motherboard | Gigabyte X399 Aorus Gaming 7 |
Cooling | EKWB X399 Monoblock |
Memory | 4x8GB GSkill TridentZ RGB 14-14-14-32 CR1 @ 3266 |
Video Card(s) | XFX Radeon RX Vega₆⁴ Liquid @ 1,800Mhz Core, 1025Mhz HBM2 |
Storage | 1x ADATA SX8200 NVMe, 1x Segate 2.5" FireCuda 2TB SATA, 1x 500GB HGST SATA |
Display(s) | Vizio 22" 1080p 60hz TV (Samsung Panel) |
Case | Corsair 570X |
Audio Device(s) | Onboard |
Power Supply | Seasonic X Series 850W KM3 |
Software | Windows 10 Pro x64 |
whenever i try to save my bios with GPU-Z it says "Bios reading not supported on this device" is there any way to get around this? oh and my card is an ATI X1300 mobility radeon.
System Name | ID |
Processor | Q9450 ~3.74Ghz |
Motherboard | ASUS-P5E |
Cooling | Air |
Memory | G.Skill CL4-8GB |
Video Card(s) | ATI/Geforce 5850/9800 |
Storage | A-lot |
Display(s) | BenQ G2400WT |
Case | 900 |
Audio Device(s) | Shitty ASUS FX;P |
Power Supply | OCZ GXS 850W |
Software | - |
Benchmark Scores | too many machines to spec |
WOA Alex, your kinda wrong on that one.
X1300 Mobility is a seperate card entirely.
The X1150, X1200, X1250 are integrated.
Your cards external read/write pins have been cut to prevent improper flashing by ATI.
Video rom from v1.15, hope it helps
If your really confident you can change the Video BIOS how you want it without changing the length then it should just be a case of replacing the Insyde EFI module in the v1.15 BIOS and flashing the whole BIOS. Well, that's the theory anywayBut... how can I write the modified video rom back?
I have same problem
The card is a Mobility Radeon HD 4330 (Acer Aspire 5538G)
OS Windows XP 64 bit, Catalyst 9.12, GPU-Z 0.3.8
