- Jan 14, 2023
- 5 (0.01/day)
Processor | Ryzen 7 1800X |
Motherboard | Asrock B450M Pro4-F |
Cooling | Deepcool GAMMAXX 400 |
Memory | Corsair Vengeance LPX DDR4-2400 (2x8GB) |
Video Card(s) | Sapphire NITRO RX470 8GB |
Storage | WD Green 500GB SATA + Walton M.2 256GB SATA + Toshiba 7200RPM 1TB |
Display(s) | Dell E1916HV 1366x768 TN Panel |
Case | Potato Case |
Audio Device(s) | Moondrop Chu ii IEM + CX Pro DAC |
Power Supply | Corsair CX450 |
Mouse | Aorus M2 |
Keyboard | Dell KB216 |
Every time I boot my PC, the BIOS settings revert to default. After changing the BIOS settings (disabling CSM, enabling 4G Decoding and Resize BAR), I save and exit. AMD Adrenalin then shows that Resize BAR is enabled. However, after the second boot, Resize BAR is disabled again, and CSM is re-enabled by default. AMD Adrenalin shows that Resize BAR is disabled. I've tried multiple times (disabling CSM, enabling 4G Decoding and Resize BAR) and saving, but it always returns to default after the first boot, and by the second boot
Motherboard: asrock b450m pro4-f
