BIOSTAR Introduces the Hi-Fi A88S3+ FM2+ Motherboard
4,784 (0.99/day)
Still on the East Side
BIOSTAR has released the "Hi-Fi A88S3+" motherboard based on the new AMD FM2+ socket design that will support AMD Multi-Core (x4, x2) socket FM2+/FM2 processors AMD A-series/ E2-series processors.
Using the AMD A88X chipset, the Hi-Fi A88S3+, featuring Puro HiFi audio technology, brings 4 DIMM slots supporting DDR3 RAM. It uses the newest SATA 6 Gb/s bus which is twice the speed of current SATA 3G connections along with USB 3.0. There is also support for AMD Dual Graphics Technology.
The Hi-Fi A88S3+ offers users the 6+ Experience. The first, "Audio+" includes audio features from BIOSTAR which are extensive with the following audio features: 3D Audio, True Blu-Ray Audio, 3D HiFi Amp and 3D Smart Ear.
The "Video+" features support for full HDMI 3D 1080p and the motherboard has a Dual-Link DVI port for resolutions up to 2560x1600.
The "Speed+" features include support for SmartSpeedLAN which is a free software application that monitors and manages your PC's network behavior. There is also Charger Booster is the fastest and most efficient charger solution for apple devices such as iPads and iPhones.
"Protection+" gives the ever important High Quality ESD providing high quality ESD (Electro-Static Discharge) protection for the front I/O panel. This function prevents static electricity and reduces the damage to the motherboard when you are plugging or unplugging your headphones.
"Durability+" gives you 100% solid capacitors with armor-plated Biostar Technology. All capacitors are 100% solid giving a lasting life cycle, durability and stability for crucial components.
Lastly, "DIY+" users are taken care of with BIOSTAR fully supporting the user in many innovative ways such as with UEFI BIOS stands for Unified Extensible Firmware Interface (UEFI) and BIO-Remote 2 which gives users a better Home Theater environment. Rapid Switch 2, engineered by BIOSTAR, is an onboard switch that allows you to easily shut down and restart your system and Rapid Debug 2 is an onboard LED indicator that shows 6 kinds of messages: CPU power, MB power, CPU, memory and PCI-E, SATA for error states.
561 (0.11/day)
System Name Salamander
Processor Ryzen 5 3600 @ 4.325ghz 1.206v
Motherboard Asrock X370 Taichi
Cooling EK Supremacy Evo | Black Ice Nemesis 360GTS XFlow | Noiseblocker BlackSilent Pro 120mm x 3
Memory Team T-Force Xtreem 2x8GB DDR4 3733 @ 3733mhz c16 1.4v | IF @ 1866mhz
Video Card(s) XFX RX-470 RS Single Fan flashed to RX-570 @ stock water-cooled
Storage Samsung 850 Evo 256gb M.2 | Crucial M4 128GB | WD Blue 1TB | WD Blue 500GB 2.5" | Toshiba 2TB 2.5"
Display(s) LG 27MP68VQ 27" 1920x1080 75hz IPS Freesync monitor
Case Fractal Design Define C
Power Supply Seasonic Prime Gold 650w
Mouse Steelseries Kana White
Keyboard Steelseries 6GV2 Cherry MX Black
Software Windows 10 Pro N
for pete's sake why can't they place the 2nd pci-e x16 at the third slot?
887 (0.15/day)
Processor Intel Core i3-8100
Motherboard ASRock H370 Pro4
Cooling Cryorig M9i
Memory 16GB G.Skill Aegis DDR4-2400
Video Card(s) Gigabyte GeForce GTX 1060 WindForce OC 3GB
Storage Crucial MX500 512GB SSD
Display(s) Dell S2316M LCD
Case Fractal Design Define R4 Black Pearl
Power Supply Corsair CX600M
Mouse Logitech M500
Keyboard Lenovo KB1021 USB
Because then you wouldn't buy one of Biostar's more expensive motherboards with an intelligent slot arrangement.... :p
561 (0.11/day)
show me any FM2+ matx board then, not just biostar with an intelligent slot arrangement :p except for AsRock's. They're intelligent enough not to include a vrm sink to what could have been, the board which will suit my needs.
393 (0.09/day)
Processor Ryzen 7 5800x @ 4,85Ghz
Motherboard AORUS MASTER X570
Cooling Costume External Water Loop 1080 Rad
Memory Patriot Viper Steel DDR4-3600 16GB @3800 mhz cl16
Video Card(s) RTX 3090 Water
Storage Raid0 4 x Sasmsung 850 EVo, 980 1TB M.2
Display(s) ASUS Swift
Case Open test bench
Power Supply Be quiet! 850 P10
Mouse G703
Keyboard Old USB Dell Keyboard x2
VR HMD Rift S
DIY
887 (0.15/day)
Cooling Cryorig M9i
Mouse Logitech M500
Sweet. :rockout: Sometimes you just have to take matters into your own hands.
128 (0.03/day)
Betelgeuse
System Name Purity Control
Processor Intel i5 2500
Motherboard ASRock H61 Pro BTC
Cooling Grand Kama Cross 2
Memory 8 GB Corsair XMS 3 1333 Mhz
Video Card(s) Palit GTX 750 Ti Storm X OC
Storage Samsung 840 EVO 120GB, Westen Digital Black 500 GB
Display(s) Asus VX239H-W 24 inch
Case Bitfenix NEOS (All white)
Audio Device(s) Integrated (VIA® VT1705 Audio Codec)
Power Supply Corsair CX 430
Software Windows 7 64bit Ultimate
Check out the
GA-F2A88XM-D3H from Gigabyte
887 (0.15/day)
Cooling Cryorig M9i
Mouse Logitech M500
Check out the GA-F2A88XM-D3H from Gigabyte
Same problem with the slot arrangement:
PCI Express x16
PCI Express x1
PCI
PCI Express x16 (wired as PCIE x4)
You can't get 2 dual-slot video cards on the motherboard when it's mounted in a micro-ATX case. If they swapped places with the PCI slot and the second PCIE x16 slot, it would work fine (except for the miserly x4 bandwidth...). Only ASRock seems to have thought about this (with just 3 boards), and even theirs are wired as x4 in the second full-sized PCIE slot.
561 (0.11/day)
Yey! found one, MSI A88XM Gaming Edition :D
oh wait,
what sorcery? :eek:
887 (0.15/day)
Cooling Cryorig M9i
Mouse Logitech M500
"Optimized For Multiple Graphics Cards"
As long as your second card is a single-slot design. Also, the second x16 slot is only PCIe 2.0 x8. Apparently, it isn't for serious gaming....
561 (0.11/day)
^clearly you are not looking at the image well enough :p
887 (0.15/day)
Cooling Cryorig M9i
Mouse Logitech M500
Oh, but I am looking at the image -- of the bare motherboard:
PCIe x16
PCIe x1
PCIe x1
PCIe x16​
With dual-slot video cards, the slot usage would be:
Video card #1
Overhang
PCIe x1
Video card #2
The second video card has no room for its overhang in a micro-ATX chassis. Either that or MSI plugged it into a PCIe x1 slot, resulting in a wee bit of bandwidth constraint. :wtf:
561 (0.11/day)
^exactly :p MSI, this is beyond lazy at least edit the pic right :p
