- Oct 9, 2007
- 46,776 (7.64/day)
- Hyderabad, India
System Name | RBMK-1000 |
Case | Corsair Carbide 100R |
Software | Windows 11 Pro |
BitFenix announced the Alchemy 2.0 sleeving components & modular cables. We wanted to make a difference in the modding world with Alchemy cables and Alchemy cable series helped the modding community immensely. We are now ready to offer you the most customizable sleeving product in the market. Alchemy 2.0 individual wires, Alchemy 2.0 connectors and alchemy 2.0 combs offer extreme customisation with ease of use. All you have to do is plug the wires in any pattern you like and your extension is ready to go.
Alchemy 2.0 Individual wires are manufactured to the highest quality, performance and reliability. 16AWG thick pure copper stranded wires are capable of delivering up to 1500W with minimum resistance, while the new High Current Alloy Terminals minimize the efficiency drop in the extensions. These high performance cables are sleeved with an ultra-dense sleeve that it moulded to the wire through a heat-shrinkless sleeving process. Thus the sleeve does not move and come off when pulled, making them extremely durable. Alchemy 2.0 Individual cables are very flexible but strong allowing you to get small bends and keep the cables aligned.
Connectors
Precision moulded Alchemy 2.0 connectors are manufactured with special rubber to make sure of perfect fitting extensions. Certified by CUL and TUV these connectors are manufactured to comply with safety standards giving you peace of mind. Alchemy 2.0 connectors can operate in a wide range of temperatures from -10 to 150 °C.
Combs
BitFenix Alchemy Cable comb offer a premium user friendly and a unique SoftHold protection for an unparalleled look. These premium cable comb features to fit with a 4mm thick cables and to hold perfectly. In addition, the SoftHold protection design can prevent damage to the sleeve and hold the wire. These higly flexible cable combs can be cut into different sizes to fit various cables.
![](https://www.techpowerup.com/img/16-04-07/24a_thm.jpg)
Connectors
Combs
