BitFenix Introduces Comrade Cases
47,244 (7.54/day)
BitFenix is pleased to reveal the latest BitFenix case design. Aimed at builders on a budget, Comrade offers premium features at a very competitive price. Aimed squarely at builders on a budget, Comrade delivers high-end features at an incredibly competitive price point. Available in two classic colors, Comrade brings a sleek, no-nonsense design that's ideal for the first-time builder. Dedicated 3.5" and 2.5" drive racks offer ample expansion possibilities, as well as room for long graphics cards up to 30cm in length. Tool-free drive locking mechanisms make installing storage a breeze, while dual dust filters enable quick and easy cleanup. A high-speed USB 3.0 port has also been included to save you time during file transfers. Adorned with premium touches like a powder-coated interior and an aluminum-finish BitFenix badge, Comrade is a trusty mid-tower design and an unprecedented value.
Sleek and streamlined, Comrade's design appeals to those looking for an attractive, no-nonsense housing that fits in any modern environment. Available in both midnight black and arctic white models, users can choose the one that suits their own personal style.
Comrade delivers a surprisingly roomy interior that accommodates a multitude of hardware options. The dedicated 3.5" and 2.5" drive racks provide ample storage, all while allowing room for long graphics cards up to 30cm in length. Along with seven PCI slots and three 5.25" bays, Comrade makes a great base for a modern system.
Your PC should be your friend - not your foe. Comrade comes with multiple friendly features that make the building process a snap. Features like tool-free HDD trays and ODD retention mechanisms make installing your storage virtual child's play. Motherboard standoffs have already been built directly onto the motherboard tray, and the simple pull-off front panel with independent I/O module saves you even more time during installation.
With the proliferation of HD media, files are not getting any smaller. Comrade comes equipped with a high-speed USB 3.0 port, perfect for quickly transferring files from external hard drives, thumb drives, and more.
Despite the low price tag, Comrade is loaded with features that are normally seen in much more pricey cases. Dual removable dust filters help keep the internals of the system dust-free, and are extremely easy to wash. Rolled-edge cable pass-throughs help protect your cabling, and a powder coated interior and aluminum BitFenix logo give Comrade a premium quality look.
Specifications:
  • Materials: Steel, Plastic
  • Color (Int/Ext): Black/Black, White/White
  • Dimensions (WxHxD): 185mm x 428.55mm x 470.5mm
  • Motherboard Sizes: Mini-ITX, Micro-ATX, ATX
  • 5.25" Drive Bays: x 3
  • 3.5" Drive Bays: x 3
  • 2.5" Drive Bays: x 3
  • Cooling Front: 120mm x 2 (optional)
  • Cooling Rear: 120mm x 1 (1 included)
  • PCI Slots: 7
  • 1 x USB3.0, 1 x USB2.0, HD Audio
  • Power Supply: PS2 ATX (bottom, multi direction)
  • Extras: Front Dust Filter, PSU Dust Filter, Tool-Free Drive Locking
2,070 (0.39/day)
System Name iJayo
Processor i7 14700k
Cooling Pearless Assasi
Case O11 mini
Power Supply LIan li 750 mini
Mouse corsair Dark Saber
Keyboard Roccat Vulcan 121
Software Window 11 pro
...looks like they took the merc and gave it a serious upgrade
149 (0.02/day)
It doesn't look like there is enough clearance to hide cables behind the motherboard tray nor is there a cutout for the 4-8pin CPU power cable. Otherwise, this case doesn't look too shabby.
343 (0.07/day)
Ft Stewart
System Name Queen Bee
Processor 3570k @ 4.0GHz
Motherboard Gigabyte UD3 Z77
Cooling Water Loop by EK
Memory 8GB Corsair 1600 DDR3
Video Card(s) MSI GTX 970 Gaming WaterCooled
Storage 1x Western Digital 500GB Black 1x Intel 20GB 311 SSD
Display(s) BenQ XL2420G
Case CoolTek W2
Power Supply Corsair 650Watt
Software Windows 7 Pro
I like how they crammed over $1000+ in hardware with cable sleeve's in a case that probably no more then $50 :roll::roll::roll:
