[Case Gallery] BitFenix Prodigy Mirror - White and Black blue
20 (0.00/day)
Lithuania, Kaunas
Specs:
BitFenix Prodigy "Mirror" Black_blue
System:
BitFenix Prodigy Midnight Black
EVGA Z77 Stinger, Intel Z77 (111-IB-E692-KR)
WiFi/WiDi 300MBPS/BLUETH4 920119 Gigabyte
EVGA GeForce GTX 670 (02G-P4-2762-KR)
Intel® Core i5-3570K Processor ( BX80637I53570K)
Kingston HyperX 8GB (2 x 4GB) (KHX1866C11D3P1K2/8G)
OCZ Vertex 4 128GB SATA3 (VTX4-25SAT3-128G)
WD Green 3.5'' 2TB SATA3 IntelliPower 64MB AFT (WD20EZRX)
Corsair TX650 V2 650W ATX
Corsair Fan Air Series SP120 High Performance Edition
Scythe Slip Stream Slim 120mm 1600rpm
Water:
Watercool HEATKILLER CPU Rev3.0
Watercool HEATKILLER NSB Rev3.0
Watercool HEATKILLER GPU-X GTX 670
Laing DDC-Pumpe 12V DDC-1Plus
Phobya Laing DDC top Black Nickel Edition
Phobya Balancer 250 Black Nickel
Phobya Temperature Sensor
Koolance Nozzle Single, 3/8" (10mm) G1/4 Angled Threaded
Koolance Nozzle Single, 3/8" (10mm) G1/4 Threaded
Koolance tubing 13/10mm (3/8"ID) UV-active blue
Mayhems Dye Ocean Blue 15ml
Koolance Liquid Fluorescent Blue
Black ICE Radiator GT Stealth 120
Black ICE Radiator GTS-Lite 240
Phobya Touch 6 Controller
Other:
LBM x4 series LED Module x2
RGB LED Strip
BitFenix 24-Pin ATX
BitFenix 4-Pin ATX12V
BitFenix 8-Pin PCIe
BitFenix 6-Pin PCIe
BitFenix Prodigy Window Side Panel
Front mirror glass
Side mirror glass
Mods:
BitFenix Prodigy "Mirror" White_blue
System:
BitFenix Prodigy Midnight White
Gigabyte GA-Z77N-WIFI, Z77 (GA-Z77N-WIFI)
Gigabyte Radeon HD 7970 (GV-R797OC-3GD)
Intel Core i5-3570K Processor ( BX80637I53570K)
Corsair Dominator Platinum 8GB (2x4GB) (CMD8GX3M2A1866C9)
SSD Intel 330 Series 120GB SATA3 (SSDSC2CT120A3K5 921607)
Corsair Fan Air Series SP120 High Performance Edition x2 (CO-9050008-WW)
Scythe Slip Stream Slim 120mm 1600rpm (LSCA0003/ SY1212SL12)
Water:
Koolance CHC-125
Koolance CPU-370 (CPU)
Koolance VID-AR797
Laing DDC-Pump 12V Ultra HF
Phobya Balancer 250 black nickel
Phobya temperature sensor
Alphacool NexXxoS ST30 Full Copper 120mm
Alphacool NexXxoS ST30 Full Copper 240mm
Alphacool 1046/1048 Eheim inlet adaptor
Alphacool 1046 Eheim outlet adaptor 90
Mayhems concentrate UV Blue 15ml
Koolance Liquid Coolant UV blue
Masterkleer tubing UV-reactive white
Other:
RGB LED Strip
BitFenix 24-Pin ATX
BitFenix 8-Pin PCIe
BitFenix 6-Pin PCIe
Front mirror glass
Side mirror glass
http://www.youtube.com/watch?v=2WYOjNgeJ-o ,
http://www.youtube.com/watch?v=lbg9tn0GvT8 ,
http://www.youtube.com/watch?v=spEv01mYCsE ,
http://www.youtube.com/watch?v=3H2wW2nR3oQ .
3,842 (0.91/day)
System Name Zotan
Processor i9-10850K
Motherboard Gigabyte Z490 Gaming X AX
Cooling H100
Memory 32GB Viper 3200
Video Card(s) Zotac RTX3080
Case Airflow 275R
Power Supply RMX850
Benchmark Scores d1nky@hwbot.org
About time someone done some mirror glass/perspex
i love this mod!
HammerON
The Watchful Moderator
8,398 (1.49/day)
Up North
System Name Aki
Processor AMD 7800X3D
Motherboard ASUS ROG STRIX X670E-A
Cooling EK-Quantum Velocity² D-RGB - AM5 White Edition
Memory Patriot Viper Elite 5 32GB 6200
Video Card(s) PNY RTX 4090 Water Cooled
Case Corsair 5000D Airflow
Audio Device(s) On-board
Mouse Roccat Kone Pure
Keyboard Corsair K70
Software Win 11 Pro
453 (0.11/day)
St. Louis MO
System Name Devil Red
Processor Intel i7 3820 @ 4.7GHz
Motherboard ASUS Rampage IV Formula x79
Cooling Water cooling CPU, MOSFET,SLI GTX 690
Memory Corsair 32GB DDR3 1866 MHz
Video Card(s) (SLI) ASUS GTX 690
Storage 120GB Corsair SSD/WD 300GB VRaptor
Display(s) HP ZR30w Pro 30" LCD
Case Corsair 900d Modded
Audio Device(s) X-FI
Power Supply Corsair AX1200i
Software 3DsMax, Maya, ZBrush, Photoshop Master Collection, and some more software
I like how small it is but you were about to fit so much water cooling it the small case and make it look great at the same time.
Justdub18
1 (0.00/day)
Awesome Mod I want it
I love this mod do you have a tutorial for it i would buy the black one without hesitation please post more and a build log please.
1,177 (0.20/day)
System Name KOV
Processor AMD 5900x
Cooling H100i Cappellix White
Memory Corsair 3600kHz 32GB
Video Card(s) RX 7900XT
Storage Samsung 970 evo 500gb, Corsair 500gb ssd, 500GB 840 pro & 1TB samsung 980pro. M2.SSD 960 evo 250GB
Case Corsair 680x
Power Supply AX1200i Corsair
Software windows 11
very very nice and clean
