black screen and fans 100%
yassa
13 (0.03/day)
hello, i have rtx 3060ti aorus elite and 750w gold seasonic FOCUS and i didn't face this problem before but suddenly i started facing the problem ,the problem is sometimes especially while idle or browsing doesn't happen while gaming suddenly screen turn off and gpu fans go to 100% i tried updating my gpu to latest driver didn't fix the problem i stress tested my gpu it didn't happen while stress testing so it doesn't happen while getting high temps or stressing gpu can you find pls solution for this cause i can't till now find a solution and its really annoying
sneekypeet
not-so supermod
29,632 (4.33/day)
System Name EVA-01
Processor Intel i7 13700K
Case Thermaltake Core P3 TG
Nothing shows up in event viewer?
Off the top of my head, could be CPU overheating, could be RAM not setup properly, could be a GPU heat problem, nonetheless its a system crash.
Help us help you, full specs of the system?
4,693 (0.95/day)
in a van down by the river
Cooling frostier than yours
Storage more ample than yours
Case fancier than yours
Benchmark Scores up yours
check to see your cables are well seated going to your PSU and GPU
check your temps as well just in case
yassa
13 (0.03/day)
cpu is i5 12400f and its temp doesn't go more than 56 ram is set up properly gpu heat doesn't go more than 60 or 65 and when this problem happen its always under 50 ram are xpg 3200mhz 8x2 ddr4
temps are very good cpu always under 60 gpu at stress in games go to 65 but when i am playing on my usual games like now gow ragnarok its 46 so its not temp problem and cables i can't check them right now i will check them tomorrow i tried now to remove my bluetooth usb cause i think its the problem and the hdmi cable if it happened again i will check the cables
