Blank shortcut icon GPU-Z
18,585 (2.72/day)
System Name AlderLake
Sometime ago I installed the latest version of GPU-Z, started up my laptop the next day and noticed that the GPU-Z shortcut icon was white, I tried to find the icon in GPU-Z.exe but it said: "GPU-Z.exe contains no icons".
I hope I the icon will return in the next version.
18,585 (2.72/day)
Ok I fixed it, last time I updated GPU-Z and that gave me a blank icon, I just uninstalled my current and downloaded/installed the latest version and the icon is back.
18,585 (2.72/day)
It's not fixed, today my GPU-Z icon is a blank shortcut icon again..
And it says GPU-Z.exe does not contain an icon
18,585 (2.72/day)
No one else having this?
W1zzard
Administrator
27,583 (3.70/day)
Processor Ryzen 7 5700X
Memory 48 GB
Video Card(s) RTX 4080
Software Windows 10 64-bit
There is an issue with the way GPU-Z's icon is stored in the compressed binary. Back when it was reported originally (several years ago) there was no way to fix it. I'll check if it can be done now.
18,585 (2.72/day)
Just installed the latest version of GPU-Z and I'm having that blank icon shortcut again...
18,585 (2.72/day)
@W1zzard , is it possible to download the .ico somewhere?
3,629 (0.61/day)
System Name Ultra 64
Processor NEC VR4300 (MIPS R4300i)
Motherboard proprietary design
Cooling Fanless aircooled
Memory 4.5MB 250 MHz RDRAM
Video Card(s) 62.5 MHz Reality Coprocessor
Storage 32 - 512 Mbit ROM Cartridge
Display(s) 720x576
Case Clear Blue Funtastic
Audio Device(s) 16-bit CD quality
Power Supply proprietary design
Mouse N64 mouse for use with N64DD
Keyboard N64 keyboard for use with N64DD
I have i copy of the ico file, not too sure where to upload it for you, or even if W1zzard Would allow it?
W1zzard
Administrator
27,583 (3.70/day)
Memory 48 GB
GPU-Z Icon attached
  • GPU-Z.zip
W1zzard
Administrator
27,583 (3.70/day)
Memory 48 GB
@W1zzard , is it possible the icon to make greater (256x256)? :cool:
I don't have the original icon as vector so I'll have to recreate.
Any good graphics artists that would be interested in helping out?
467 (0.14/day)
South Africa ,Lions Everywhere..
System Name Ground Control
Processor Intel i5 2500k 4 Ghz
Motherboard MSI P67A-GD80 B3
Cooling Cooler Master Hyper 212x
Memory 2 x 4GB DDR3 1600mhz Apacer Black Panther
Video Card(s) Msi GTX 1060 OC 3Gb
Storage 2 x 250Gb WD Blue raid 0 + 1Tb Wd Green
Display(s) Samsung BX2450 24" Led
Case GMC X7 X-Station
Power Supply HEC Raptor 500watt
Mouse Logitech G9
Software Windows 8.1
Benchmark Scores Power Level over 9000
I created a icon but cant upload it ,cant upload bmp/ico files
Print screen the GPUZ logo on the download section
In paint crop the logo
Save as BMP and edit extension to .ico
Done
292 (0.10/day)
I know I am quite late but as I was scrolling through I saw this post which happened to one of friend too. This sometimes happens with Windows. Usually a reboot will solve the problem. However if this doesn't, try setting the icon for the shortcut(right-click pinned icon, right-click program, left-click properties, select "change icon...") or refreshing it by switching to a different icon, applying it, and then reverting back to the original icon. Remove the shortcut from the taskbar and replace it with the start menu shortcut or simply drag the .exe file to the taskbar.
580 (0.10/day)
System Name X-Class MKII
Processor Intel Core i7-6950X Extreme Edition 4.60GHz 25MB Cache 14nm LGA2011-3 Broadwell-E 10-Core Processor
Motherboard EVGA Intel X99 Classified Dual Quad-Channel DDR4 Socket LGA2011-3 E-ATX Motherboard on BIOS v2.09
Cooling BP Summit M CPU WB/BP EVGA K|NGP|N FCWB/Nemesis 480GTR/Nemesis 560GTR/MMRS 150mm/Swiftech MCP655
Memory Corsair Dominator Platinum 128GB (8×16GB) @ 2800MHz 14-16-16-36 DDR4 PC4-22400 Memory Kit
Video Card(s) EVGA nVidia GeForce GTX 1080 Ti K|NGP|N 2139MHz 11264MB @ 12992MHz GDDR5X Video Cards in 2-Way SLI
Storage Samsung 970 PRO M.2 1TB NVMe V-NAND SSD on AquaComputer kryoM.2 PCIe 3.0 ×4 M.2 Adapter
Display(s) LG 34GN850-B 34” UltraGear 21:9 WQHD Nano IPS 1ms 144Hz HDR Gaming Monitor
Case CaseLabs MAGNUM SMA8 Gunmetal Single Wide Full-Tower Chassis with Custom Smoke Window Panel
Audio Device(s) Creative Sound Core3D On-Board 5.1 Surround Sound Quad-Core Audio Processor
Power Supply Corsair Professional Series AX1500i 1500-Watt 80+ TITANIUM Fully-Modular Digital Power Supply Unit
Mouse Logitech G502 PROTEUS SPECTRUM Core 200-12000DPI Laser Gaming Mouse
Keyboard Logitech G19 Gaming Keyboard with Full Color GamePanel LCD
Software Microsoft Windows 10 Professional 64-bit
I created an icon a while back to suggest it for replacement with a black PCB.
18,585 (2.72/day)
With the installation of the latest nvidia graphics driver (436.15), once again the GPU-Z icon went blank.
Tried a reinstall of GPU-Z 2.24.0 still not showing the icon.
I will use the icon posted here again then..
