Board power draw exceeding whopping 550w
FATAHALI00
1 (1.00/day)
Okay so, i bought a dell m6800 workstation laptop having specs: i7 4900mq, 8 gigs ram, 256 ssd, 512 hdd and a 4 gb nvidia quadro k3100m graphics card. Through it is not a laptop that would run high end modern games but it did the job for me as a student of software engineering and playing simple games in my free time, i ran gta 5 on high setting which was extremely smooth 1920x1080 resolution, moreover i played mortal kombat xl with high graphics and no lag either, other games included, watch dogs, tekken 7, etc etc.
Now, one day i turned on my laptop and all these games started to lag at the point of 2 fps almost i got worried but upon cheling the graphics card showed no issues but still wouldnt run anything. Upon looking at the gpuz screen the graphics card was stuck at 162 memory clock and 135 core clock upon no matter what i did, the perf cap showed "PWR" and was a long green line in that column and i noticed my total power draw was well over exceeding 500w so was the pcie slot draw, i reinstalled windows multiple times, reinstalled drivers, reflashed the bios, tried to put the laptop at the maximum Performance it can provide but nothing improved the graphics cards clock speeds
If someone can tell me what the issue is that would be really helpfull
1,176 (3.50/day)
Nowhere
Processor 14700K
Motherboard Asus TUF Z790
Cooling Air/water/DryIce
Video Card(s) RTX 4070 Super
Storage 980 Pro
Display(s) Some LED 1080P TV
Case Open bench
Keyboard Logitech G910
VR HMD Quest 2
Software Windows
It's a 75w card, but from what you describe, a mosfet might have burnt. (just a guess) Send it in to the repair shop, it's likely a physical defect of some kind.
Toothless
Tech, Games, and TPU!
9,549 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
Memory 2x32 Corsair Dominator
Power Supply Corsair HX850
Mouse Corsair Nightsword
Keyboard Corsair K55
VR HMD HP Reverb G2
Benchmark Scores PEBCAK
Bad sensor. Really nothing wrong with it.
2,851 (2.11/day)
Germany
Case Streacom BC1 V2 Black
Mouse Razer Deathadder V3
VR HMD Oculus Rift S
Software ~2000 Video Games
your motherboard would be dead if that would be even close to real.
if any software sensor shows anything beyond +/- 20% of what's normal it's pretty safe to say it was a readout error.
401 (0.10/day)
I would say a likely faulty GPU, if it was just bad sensor you would have the same performance. Maybe install HWinfo for more info on what the whole system is doing.
21,328 (3.40/day)
System Name Pioneer
Processor Ryzen R9 9950X
Case Thermaltake Core X31
I mean gpus are watt limited based on the sensor readout no?
130 (2.20/day)
Texas, USA
System Name Obliterator
Processor Ryzen 7 7700x PBO
Motherboard ASRock x670e Steel Legend
Cooling Noctua NH-D15 G2 LBC
Memory G.skill Trident Z5 Neo 6000@CL30
Video Card(s) ASRock rx7900 GRE Steel Legend
Storage 2 x 2TB Samsung 990 pro nmve ssd 2 X 4TB Samsung 870 evo sata ssd 1 X 18TB WD Gold sata hdd
Display(s) LG 27GN750-B
Case Fractal Torrent
Audio Device(s) Klipsch promedia heritage 2.1
Power Supply FSP Hydro TI 1000w
Mouse SteelSeries Prime+
Keyboard Lenovo SK-8825 (L)
Software Windows 10 Enterprise LTSC 21H2 / Windows 11 Enterprise LTSC 24H2 with multiple flavors of VM
295 (2.48/day)
I'd trust the clock speed readings.... not so much the power readings - I think they are BS numbers.
More than 500W being pulled in a laptop on the GPU is highly unlikely - even using Dell's 20V adapter standard, that would need to be supplied with over 25 amps - they do not supply that much.
Have you actually checked / blown out the fan+heatsink on it? It could be throttling....
Also, does the laptop use the Intel+Nvidia graphics switching (if it's available)? Have you switched it to just use the Nvidia output only?
Ruru
S.T.A.R.S.
12,443 (2.88/day)
Jyväskylä, Finland
System Name 4K-gaming
Processor AMD Ryzen 7 5800X
Cooling Arctic Freezer 50, GPU with custom loop
Memory 32GB Kingston HyperX Fury DDR4-3200
Storage A pack of SSDs totaling 3.2TB + 3TB HDDs
Display(s) 27" 4K120 IPS + 32" 4K60 IPS + 24" 1080p144
Audio Device(s) Asus TUF H3 Wireless / Corsair HS35
VR HMD Oculus Rift CV1
Check what HWINFO64 says.
992 (0.29/day)
System Name The Banshee
Cooling Asus ROG Strix LC 240
Memory 32GB 4x8 G.SKILL Trident Z 3600 CL16 1.35V
Video Card(s) RTX 3060M 6GB @ 1750-2100MHz Core / 1875MHz Mem
Storage 1TB Kingston NV2 & 1TB Mass Storage HDD
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
It's a fault with the power sensing circuit, it's not too rare of a problem. A repair shop might be able to fix it but more than likely you'll have to replace/upgrade it.
Toothless
9,549 (2.48/day)
Washington, USA
System Name Veral
Processor 7800x3D
VR HMD HP Reverb G2
Ruru
S.T.A.R.S.
12,443 (2.88/day)
Jyväskylä, Finland
Won't matter if the sensor is bad.
Yeah, thought just that maybe GPU-Z misreads it and some other software doesn't. Seen that happen from time to time.
6,348 (4.56/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
It does. If performance is affected, then it's a damaged shunt.
