Branching out to other BOINC projects thread
3,537 (0.68/day)
Netherlands
System Name ap201 | Odroid N2+ | NUC
Processor AMD Ryzen 5 3600 | Amlogic S922X | Intel Core i5-7260
Motherboard Gigabyte B550M DS3H |Odroid N2+ | NUC Board 7
Cooling Inter-Tech Argus SU-200, 3x Arctic P12 case fans | stock heatsink + fan | stock HSF
Memory Gskill Aegis DDR4 32GB | 4 GB DDR4 | 16 GB DDR4
Video Card(s) Sapphire Pulse RX 6600 (8GB) | Arm Mali G52 | Iris Plus 640
Storage SK Hynix 240GB, Sam. 840 + 850 EVO (2x (250 GB)| Samsung 850 Evo 500GB | WD Green 240 GB
Display(s) AOC G2260VWQ6 | LG 24MT57D |
Case Asus Prime 201 | Stock case (black version) | Stock case
Audio Device(s) integrated
Power Supply BeQuiet! Pure Power 11 400W | 12v barrel jack | 19V laptop brick (Asus)
Mouse Logitech G500 |Steelseries Rival 300 | no-name ergo mouse
Keyboard Qpad MK-50 (Cherry MX brown)| Blaze Keyboard
Software Windows 10, EndeavourOS | Gentoo Linux | EndeavourOS
As discussed in this thread, some want to branch out into other BOINC projects again. I commented on that with:
We once had an unofficial TPU team on there, started by me (others had started similarly on other projects). Now it is a locked "team" with only me left in there. I have been looking into getting back into crunching. So I am kind of torn right now between on one hand opening up the team again for others (changing its name to reference TPU again and being at least its admin even when not crunching very actively due to reasons I will not get into now), and on the other just staying out of it while someone else forms the team and I might join in later.
I could also try to see whether I can make other accounts admin of my "team" if you wish to form it (back) into a TPU team.
In this thread we might discuss this. And yes, in my account I can change back to the TPU name again, allow new members again and even add new admins if we see a need (e.g. to let it have the same captain as we have for WCG). Shall I just do that?
hat
Enthusiast
21,745 (3.30/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
Rosetta@Home could use some love... but I'm not sure I could take the position of team captain or anything like that.
3,537 (0.68/day)
Netherlands
That is ok. I have my doubts as well (about myself), although I would not mind as long as members understand I cannot be super active as such.
Update: I went to the account and changed it's name/team info and allow new members again. I will be its captain for a while and see how it goes.
phill
16,927 (3.43/day)
Somerset, UK
Power Supply EVGA 1600W T2
Mouse Corsair thingy
VR HMD No headset yet
If we can get some results up and it's constant I'll be able to add in a small graph for pie and such like I do for WCG and FAH :) I'll need to find the right stats page but I'm very sure that @thebluebumblebee and @mstenholm would be able to help and point me in the right direction :)
4,503 (0.82/day)
Denmark
System Name The work PC /2700x/5950x
Processor 3900X stock/ 2700x stock/ 5950x 4200 MHz fixed @ 1,056-1,08V
Motherboard Gigabyte AORUS Master X570/2xMSI X470 M7 AC
Cooling Custom WC XSPC RX480, Laing DDC, XSPC Laing DDC Top V3 and EK Velocity/NH15/NH-U12S SE
Memory 32 GB Viper 3600/14 /16 GB Trident Z F4-4000C18D-16GTZSW 3600 /32 GB G Skill Flare CL14 3400
Video Card(s) 2070 Super X MSI/GTX 970 MSI/ GTX 970 MSI
Storage 1 TB SSD+500 GB NVMe / 500 GB SSD/ 2 TB 990 Pro
Display(s) Dell UltraSharp U2518D/2408WFP
Case Corsair 800D / Lian test bench/NZXT 500
Power Supply AX 850 Titanium/AX 860i/AX 760
Software Dual boot/Win 10 / Linux / Win 10+Linux
FordGT90Concept
"I go fast!1!11!1!"
26,259 (4.45/day)
IA, USA
System Name BY-2021
Cooling Scythe Mugen (rev 5)
Mouse Nixeus REVEL-X
Keyboard Tesoro Excalibur
I'm in favor a little more diversity than this:
3,537 (0.68/day)
Netherlands
AFAIK BOINCStats and Free-DC should work?
Please let me know if you cannot find the team on Rosetta@Home or have difficulties joining. Team should be open to new members.
4,503 (0.82/day)
Denmark
How far down in the listing do we have to look and for what name? :)
3,537 (0.68/day)
Netherlands
4,503 (0.82/day)
Denmark
3,537 (0.68/day)
Netherlands
I know. It has been a one-member team for far to long and I had different fish to fry than crunching for a while (and WCG has had more "weight" in my client too).
4,503 (0.82/day)
Denmark
I'm playing with the settings. I only want two PCs doing Rosetta, not my Linux. Haven't figured out how to restrict it to my default profile yet.
F..k, I'm out again. 700-900K for each WU and I'm struggling already.
3,537 (0.68/day)
Netherlands
What you could do, is only attaching to the project on the boxes you want to run it on. Before you attach, you basically set (in the client) to use local settings (which should be equal to your last used WCG settings).
4,503 (0.82/day)
Denmark
The two Windows PC that I want to run Rosetta both have 8 GB RAM, F@H and WCG can run up to 4-5 GB. I hit 99.5% RAM usage today. I will have second look, later.
3,537 (0.68/day)
Netherlands
I only know that for 2 threads in BOINC, my BOINC-related RAM usage is roughly 700MB according to Task Manager.
4,503 (0.82/day)
Denmark
I just had two ARP (315K each, folding 2M) plus 7 more WCG jobs and that is on my daily driver and I hit the ceiling (WIN7, 12MB installed but for some reason only 8 MB available). That is not working for me. I will try on a dedicated PC instead.
Edit: I had had a look at the last WU you did:
Peak working set size1,328.55 MB
3,537 (0.68/day)
Netherlands
Well spotted. I did not realise it peaked that high.
4,503 (0.82/day)
Denmark
My cure is to set WCG to 200 weight and leave Rosetta at 100 (one third and two third running). The jobs that I got all had shorter deadline than my running WCG jobs so WCG stopped (and stayed in the memory) and all the new Rosetta job "took over" to the set memory limit.
phill
16,927 (3.43/day)
Somerset, UK
I think there's options in Boinc that you can select as it will go and change between the different work loads you give it?? I think that's correct, as I signed up for the Milkway one ages back (that one uses the GPU as well if I recall correctly...)
Normally now for any crunching PC, I try to give it at least 1GB of RAM per thread just to make sure it has enough. 8GB even for a quad and HT CPU (2600k or 6700k as example) would soon eat that up running Linux. Had no end of problems with 4GB installed...)
If anyone would be able to put out a joining link, anyone who wishes to, can join the Rosetta work set as well :)
3,537 (0.68/day)
Netherlands
4,503 (0.82/day)
Denmark
Team list so far: https://boinc.bakerlab.org/rosetta/team_email_list.php?teamid=12537
Joining is possible by having an account on the R@H site, than (I think) choose to join a team in your account settings (in the "community" column). The team page can be found here, perhaps there is a join button too if you are logged in but haven't joined a team yet.
You need to be logged in to use the link.
If you already are doing WCG, just add the project. Two things - the jobs are long per default (8 hours) and they have a 3 day deadline. Far from all job are pure Corvid-19.
Team Techpowerup
phill
16,927 (3.43/day)
Somerset, UK
Well guys, count me in....
I've just updated my Boinc client as well... Here's hoping I can get helping :D
As I've got the power meter hooked up to my 3900X at the moment, pulls slightly less juice than WCG which is resulting in lower temps (always nice to see...) But happy to be member number 3 :D :D
Just as a question, how often do you guys run the Rosetta? Have you left them to default?
4,503 (0.82/day)
Denmark
The problem is the short deadlines. Starting from fresh it downloads a wcg/rosetta mix and start all the Rosetta units. That is all good if you have plenty RAM. I only have Rosetta on my daily rig and as you know I only got 4 operating RAM slot, 8 GB. Include up to 2 GB F@H and I see 99.9% usage. So I joggle 3-4 WUs in, the rest are suspended. The memory footprint off these units goes up and down, up to 1.4 GB. You have 64 so you are good. Once SCC is done I will switch a Linux rig to Rosetta.
4,666 (0.71/day)
Washington, US
System Name Rainbow
Processor Intel Core i7 8700k
Motherboard MSI MPG Z390M GAMING EDGE AC
Cooling Corsair H115i, 2x Noctua NF-A14 industrialPPC-3000 PWM
Memory G. Skill TridentZ RGB 4x8GB (F4-3600C16Q-32GTZR)
Video Card(s) ZOTAC GeForce RTX 3090 Trinity
Storage 2x Samsung 950 Pro 256GB | 2xHGST Deskstar 4TB 7.2K
Display(s) Samsung C27HG70
Case Xigmatek Aquila
Power Supply Seasonic 760W SS-760XP
Mouse Razer Deathadder 2013
Keyboard Corsair Vengeance K95
Benchmark Scores 4 trillion points in GmailMark, over 144 FPS 2K Facebook Scrolling (Extreme Quality preset)
I'll throw some threads on that too. Why not.
phill
16,927 (3.43/day)
Somerset, UK
I noticed that as I think say 50 downloaded and only 2 days to finish... Bit of a pain so I've just told it no more downloading and I'll let these do.. I'm no sure it's switching between WCG and Rosetta so I'm not sure my 3900X did many WCG today....
I have tried to aim for 1GB of RAM per CPU thread simply because we have so many cores now, not having enough RAM between them is going to cause issues later on, so 32GB kit was great, I had a spare, that went in as well :D
That said, I was using 20GB+ of RAM with Chrome open, WCG + Rosetta and FAH running... It was having a good work out!! :)
