Brand new Razer Blade 15 Advanced 2021 throttling, crashing, random, errors, unusable
digdug101
3 (0.00/day)
Just got this laptop three days ago and from first power on it was hot as hell. 2minutes into windows setup it got so hot it shut down. since then I've reset, monitored temps and throttling, read countless posts but nothing that helps or is the same problem. now its crashing and i get troubleshooting startup errors, NVidia driver installation failures and its still hottttttttt af even at idle. CPU is around 60c at idle and NVidia gpu at 50-55c at idle when not gaming. i know nothing about computers. I need some help.
Oh yeah, it was purchased from marketplace off a kid that said it wasn't ever used or opened and as far as i could tll the box was still factory sealed. I still paid a shitload for it but I'm to assume no warranty and i cant find anything for razer support anywhere on this planet.
15 advanced mid-2021 the -0409 model
i7 -11800 CPU
165hz QHD
16 GB RAM
1TB SSD
rtx 3070
13,682 (2.02/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Return it! NOW - before you do something, if you have not already :( that voids your warranty!
43,717 (6.78/day)
Nvmd, you bought it from fb which has no buyer protection. Open it up , clean it, replace all thermal pads with correct thickness, verify if cpu has a IHS or direct die.
Next time stick to new
Also those so called thin "laptops" are actually notebooks (weaksauce cooling).
You may need a cooling pad or switch to a Eurocom/Sager thick Desktop Replacement Gaming Laptop.
Perhaps you can talk to @unclewebb on using throttlestop
13,682 (2.02/day)
Nebraska, USA
Mouse Logitech M190
Oops! Sorry! My bad too - I read the first couple sentences then posted my reply.
I may be SOL - unless you can talk the selling into taking it back.
2,261 (0.99/day)
south wales uk
System Name 1.FortySe7en VR rig 2. intel teliscope rig 3.MSI GP72MVR Leopard Pro .E-52699, Xeon play thing
Processor 1.3900x @stock 2. 5950x undervolted . 3. i7 7700hq 4 E5-2699 V3
Motherboard 1.aorus x570 ultra 2. Rog b550 f,4 MR9A PRO ATX X99
Cooling 1.Hard tube loop, cpu and gpu 2. Hard loop cpu and gpu 4 360 AIO
Memory 1.Gskill neo @3600 32gb 2.corsair ven 32gb @3200 3. 16gb hyperx @2400 4 64GB 2133 in quad channel
Video Card(s) 1.GIGABYTE RTX 3080 WaterForce WB 2. Aorus RTX2080 3. 1060 3gb. 4 Arc 770LE 16 gb
Storage 1 M.2 1tb +1tb , 2 3tb HDs 2. 1tb m.2 3tbHD 3. 256 m.2. 1tb ssd 4. 2gb ssd
Display(s) 1.LG 50" UHD , 2 MSI Optix MAG342C UWHD. 3.17" 120 hz display 4. Acer Preditor 144hz 32inch.z
Case 1. Thermaltake P5 2. Thermaltake P3 4. montech king 65
Audio Device(s) 1 Onboard 2 Onboard 3 Onboard 4. onboard.
Power Supply 1.seasonic gx 850w 2. seasonic gx 750w. 4 RM850w
VR HMD rift and rift S and Quest 2. rog ally 2tb m.2 1tb SD.
Software 1. win11 pro 2. win11 pro 3, win11 home 4 win11 pro
Benchmark Scores 1.7821 cb20 ,cb15 3442 1c 204 cpu-z 1c 539 12c 8847
7,762 (2.72/day)
Back in Norway
System Name Hotbox
Storage 2TB Adata SX8200 Pro
Case SSUPD Meshlicious
Mouse Logitech G603
That is perfectly normal for a laptop, as they have limited cooling and loud fans. Unless you want those fans running full pelt all the time, those are the idle temps you'll get.
It's also a thin but very powerful laptop. It will run hot. Most measurement tools will report it as throttling when operating normally. CPU temperatures near 100°C and GPU temps around 80°C if not more are expected. As long as the CPU isn't going below base clock under load (2.3GHz at 45W I think) it isn't actually throttling, just operating at its peak within the capabilities of that laptop design.
I'm definitely not saying your issues don't sound serious, but to me none of that sounds like it's related to thermals, at least not based on the numbers you provided. Have you checked the event log for any reports on why the system shut down when it crashed?
digdug101
3 (0.00/day)
its new. i opened it a few mins ago and its spotless inside. just downloaded throttlestop and ill take your advice on the help there. thanks.
here you go support page. Razer Blade 15" Advanced (2021) | RZ09-0367x Support 60c isnt bad at idle in summer but theres something amiss if its shutting down through heat.
it's acting really strange like a car with a bad computer throwing codes at everything except itself. it hits 90 and 95 when gaming in just a minute or two. the rtx gets to over 90 of course its throttled but still holds those temps and ive got the fans on at 4900rpm, still that hot. does it matter that mine is a RZ09-0409x
651 (0.13/day)
St. Louis, MO
System Name Desktop
Processor AMD Ryzen 7800X3D
Motherboard MSI X670E MEG ACE
Cooling Corsair XC7 Block / Corsair XG7 Block EK 360PE Radiator EK 120XE Radiator 8x EK Vadar Furious Fans
Memory 64GB TeamGroup T-Create Expert DDR5-6000
Video Card(s) MSI RTX 4090 Gaming X Trio
Storage 1TB WD Black SN850 / 4TB Inland Premium / 8TB WD Black HDD
Display(s) Alienware AW3821DW / ASUS TUF VG279QM
Case Lian-Li Dynamic 011 XL ROG
Audio Device(s) Razer Nommo Pro Speakers / Audio-Technica ATH-R70X
Power Supply EVGA P2 1200W Platinum
Mouse Razer Viper, Logitech G600
Keyboard Razer Huntsman Elite
Just a thought.... if the original seller still has the invoice for the original purchase, you could get some help through Razer most likely.
When I have done sales through eBay and even giveaways at my LAN functions, I try to keep that stuff on hand just in case of issues.
43,717 (6.78/day)
Thin and gaming Is a misconception, its designed to throttle, sell the damn thing and get 1 from the makers I stated above. Or build a desktop
Being a Facebook buy, good luck getting anymore from them.
2,261 (0.99/day)
south wales uk
yes just go to support scrol-down and pick your model.
7,762 (2.72/day)
Back in Norway
System Name Hotbox
Mouse Logitech G603
Sounds completely normal to me. Remember: this is a laptop, and a thin one, with high powered components inside. And, crucially silicon chips are perfectly fine running up to (and above) 100°C. Us desktop people are spoiled and picky - laptops don't have spare room for larger fans, so they have to settle for small, noisy fans, meaning they prioritize lower fan speeds over thermals to make the user experience bearable. What is your room temperature like? What power profile is the laptop set to? Have you checked Event Viewer for error logs?
dgianstefani
TPU Proofreader
5,290 (2.03/day)
Swansea, Wales
Benchmark Scores Legendary
Not normal behaviour, I have a 9700hk/2070 razer and it's fine.
digdug101
3 (0.00/day)
i7 -11800 CPU
165hz QHD
16 GB RAM
1TB SSD
rtx 3070
today its so hot i cant touch the keyboard. the battery is so hot i dont see how it has'nt popped yet.
And the damn fans will be on when put on manualright till i start a game then they justgo on vacation.
Support is not support its just q and a from whatever. i want to talk to a frickin PC mechanic. thats what people do with their cars when the come to my shop they dont start asking advice from the GD customers.
43,717 (6.78/day)
You got suckered unfortunately, don't buy from marketplace at all for electronics.
6,246 (2.85/day)
Poland
Video Card(s) RTX3080 Ti FE
Display(s) LG 34GN850P-B
Mouse Endgame Gear XM1R
Keyboard Wooting Two HE
If that kid didn't give you OG proof of purchase along with it you might as well be dealing with stolen goods.
