BROKEN MSI GTX 1050 TI OC 4GT ANYONE HELP!
JAYNX7
4 (0.01/day)
I have this problem with this GTX 1050 ti OC 4GT GPU, during routine maintenance and mishandling, the GPU suffered damage to one of its electronic components on the back side, being removed due to mishandling when removing it and I only noticed it when reassembling the GPU to the motherboard resulting in no video signal on the screen.
Because of this, I ask for the help of any user of the same graphics card or a technician or an administrator send me a photo with good resolution and focus to determine the name and function of the component in question or whoever who has a scheme that allows me to see in detail please be so kind, this is only for repair purpose, because where I live there is no local MSI support which makes it even more complicated.
I will leave a photo of the location of the component damaged and removed by the blow and also of the card model to avoid confusion.
I hope you understand my problem and the urgency to solve it, thank you!
142 (0.21/day)
Processor AMD Ryzen 2700X
Motherboard MSI X470 Gaming Pro Carbon
Cooling NH-D15 SE-AM4
Memory 4x Kingston 8GB DDR4-2666
Video Card(s) 2x EVGA GTX 960
Storage Kingston SA400 480GB, LSI 9260-8I RAID[2x WD4005 4TB, 3x Kingston SA400 480GB]
Display(s) Scepter P30, Samsung T22B350
Case Phanteks Enthoo Pro
Power Supply Seasonic Prime Titanium 650w
Mouse Logitech MX Master 3
Keyboard Corsair K60 RGB Pro RGP01110
Hugis
823 (0.15/day)
Spain(Living) / UK(Born)
System Name Office / Gamer Mk IV
Processor i5 - 12500
Motherboard TUF GAMING B660-PLUS WIFI D4
Cooling Themalright Peerless Assassin 120 RGB
Memory 32GB (2x16) Corsair CMK32GX4M2D3600C18 "micron B die"
Video Card(s) UHD770 / PNY 4060Ti (www.techpowerup.com/review/pny-geforce-rtx-4060-ti-verto)
Storage P41Plat - SN770 - 980Pro - BX500
Display(s) Philips 246E9Q 75Hz @ 1920 * 1080
Case Corsair Carbide 200R
Audio Device(s) Realtek ALC897 (On Board)
Power Supply Cooler Master V750 Gold v2
Mouse Cooler Master MM712
Keyboard Logitech S530 - mac
Best i can do for better pictures of said chip, hope someone else can help you out :)
996 (0.29/day)
System Name The Banshee
Cooling Asus ROG Strix LC 240
Memory 32GB 4x8 G.SKILL Trident Z 3200 CL14 1.35V
Video Card(s) Nvidia RTX 3060 6GB Laptop GPU + AMD WX 9100 16GB
Storage 1TB Kingston NV2
Case Fractal Design Arc XL
Audio Device(s) ATH-M20x
Mouse Evga Torq X3
Software Win 10 Pro 64-Bit
Looks like an 2N7002DW (7002/702/K72) dual N-Channel mosfet. My Evga 1050 has the same part.
Repairing it looks like it'd be a bit interesting from the look of it since one of the pads is pulled off.
6,495 (4.62/day)
São Paulo, Brazil
Motherboard ASUS ROG MAXIMUS Z790 APEX ENCORE
Display(s) 55-inch LG G3 OLED
Keyboard Generic PS/2
Looks like there's damage to the PCB, with one of the surface mount pads being forced out. Soldering an equivalent part in may or may not work. You just may be out of luck, between sourcing the component, reinstalling it and hoping that the damage on the PCB hasn't affected the trails, if you have any real urgency, you should purchase another GPU. The RX 6400 is the closest equivalent, and should be faster as well.
Not to mention this isn't a repair you will be able to do at home, unless you're highly skilled with this sort of thing (and if you're asking, you're not), and that this graphics card isn't worth the fee of any qualified technician.
JAYNX7
4 (0.01/day)
Thanks bro that's really helpfull
