Broken power supply switch
hat
Enthusiast
21,750 (3.27/day)
Ohio
Cooling Cryorig M9 :: Stock
Benchmark Scores >9000
So, the switch on my secondary computer's power supply is borked. It's essentially stuck in the off position. If I try to turn it on, it doesn't click over, and flops back to the off position. What are my options? I'm planning on upgrading the entire thing eventually, so I'm not in a rush to just buy a whole new power supply right now.
120 (0.09/day)
System Name Black Diamond
Processor AMD Ryzen 5 3600X 6-Core Processor 3.80 GHz
Motherboard msi a320 a pro max
Cooling Default
Memory 32 GB ddr4 3200mhz
Video Card(s) Rtx 2070, 86 F no extra fans or stuff.
Storage nvme samsung (the fastest one) 1tb
Display(s) Some sceptre monitor and a tv
Case rosewill
Power Supply rosewill
Mouse Verbatim
Keyboard Magic wings
Software Lots
Benchmark Scores IDk
You could just buy a new switch? I mean there like cheap, and just replace the old one and solder the contacts of the 2 wires that were connected to the old one to the new one.
I took electronics class before. Basic of what a switch looks like. Lmao solved?
13,617 (2.01/day)
Nebraska, USA
Case Fractal Design Define R4
Mouse Logitech M190
Software W10 Pro 64-bit
Can we assume the warranty has expired?
I agree with IrishChrispy. It should not be too hard to find a switch. The challenge is to make sure it is physically identical but they really are very common so that should not be hard. The electrical characteristics should be printed on the old switch but typically they are rated for 125 to 250V. Current capability varies depending on PSU size. You can always go bigger - do not go smaller. They are all "single pole" (hence the two wire connectors). See: Power Supply Rocker Switches | Products & Suppliers | Engineering360 (globalspec.com)
As seen by the image above, most just snap in. So to remove the old you have to squeeze the retainer clips, then push it out.
Obviously, unplug from the wall before doing anything. "In theory", any residual voltages inside the PSU "should" be bled off to safe levels after just a couple seconds. But never assume theory and real-world jive. So once unplugged from the wall and you open the PSU case, BEFORE sticking your fingers in there, I recommend taking a long screwdriver and short each of the big filter capacitor's terminals to each other and/or to the case. Then you can proceed.
Though NOT recommended, you don't really need that switch and you can just join (solder then shrink-wrap the joint) the two wires together. Many early and budget PSUs don't even have those master power switches. To completely power off and remove power from your computer, you just unplug from the wall. However, if you go this route, I recommend you up your priority/time table and buy your new replacement PSU now. Then just use this PSU as a temporary spare until the new one arrives, then save this one as a temporary spare/test PSU you keep on the shelf.
43,414 (6.76/day)
If out of warranty, Buy a toggle that is rated for the current and voltage of the psu and have it soldered
1,901 (0.32/day)
Processor 5930K
Motherboard MSI X99 SLI
Cooling WATER
Memory 16GB DDR4 2132
Video Card(s) EVGAY 2070 SUPER
Storage SEVERAL SSD"S
Display(s) Catleap/Yamakasi 2560X1440
Case D Frame MINI drilled out
Power Supply Corsair TX750
Mouse DEATH ADDER
Keyboard Razer Black Widow Tournament
Software W10HB
Benchmark Scores PhIlLyChEeSeStEaK
Check on E bay for the same model but not working (make sure to ask if the switch is good) there a dime a dozen....
