I recently bought a broken RX 580 for a pretty sweet price, mostly looking for a project to work on. Long story short, I cleaned out the card, confirmed that the GPU was alive (GPU die heats up when booted, fans spin too), and have spent the past few days trying to figure out how to fix the main problem, which seems to be the bios. I've tried flashing using amdvbflash/atiflash on windows and also on a flash drive (DOS). I always get
Failed to read ROM
ERROR 0FL01 : Press '1' to continue
Or something similar. I've tried the 1+8 pin method using a paperclip, but atiflash -i always comes up the same, with the GPU failing. atiflash -ai is similar, listing "No VBIOS". This also using -unlockrom, which says that the ROM unlocks, but does not change anything. Using pixel patcher doesn't seem to do anything. I'm also a little concerned that the flash size of the rom is only 64KB (when bios size is 256KB), is this normal? Windows is also picking up the card as an RX 590, pretty weird (although it has code 43 in device manager). Is there anything else I can try to do to save the card?
Failed to read ROM
